Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Samsung > QUALCOMM Models (3G)
QUALCOMM Models (3G) SGH-Z105x, SGH-Z107x, Z110, Z130, Z140, Z300, Z320i, Z500, Z510, ZM60, ZV10, ZV30, ZX10.
Old 01-09-2010, 02:58   #1 (permalink)
K1n
Member: 237887
Thanks Meter: 3
Question how to correctly flash f480 with multiloader
hi! i have a problem with my f480 and i flash it with multiloader 5.56 and F480XXHD9 firmware the flash finish successfully and i can do everything with my phone without sim card. Now if i turn it off and still turn it on this message appears "DEMSBL BOOT Loader for MSM6280 Downloader Ver 5.32" i reflash it the flash finish with success but if i return it off to put sim card the same message appears. Pls help me how can i do?
Old 01-09-2010, 03:05   #2 (permalink)
JHUNpanabO's Avatar
Member: 265729
Thanks Meter: 128
try reflash in gsm box.....
Old 01-09-2010, 03:46   #3 (permalink)
Frenzy_2020's Avatar
Member: 789089
Sonork: 100.1617***
Thanks Meter: 266
Multiloader also works nice...tried with several phones
Procedure to do flashing for F480:
First you need to download the firmware you want and then Multiloader V5.33(there is a newer multiloader out plz search)
Preparing your phone:
NOTE: Flashing your phone will delete all your contacts, calender, settings ringtones etc.
You probably want to back up all your files and contacts. I recommend syncing your contacts etc. with Samsung PC Studio and copying over your files on your phone to your memory card or PC (your memory card will not be touched).
Once that's done remove any memory card you may have and then remove the SIM card. Put you battery back in. Your phone shoul be off at this point. Hold down the 'Volume down' key (The bottom rocker button on the left side of your phone) and the camera button and press the power on button. Your phone should start up into a wierd screen with downloader v.5.32 or something and some boxes. It's now ready to be flashed.
Using Multiloader:
* Select the second option from the top (MSM6275/MSM6280).
* Press the AMSS button on the left side and browse to the firmware files you want to flash (unzip/rar them as necessary). Go to the binary folder and then select amss_compressed.
* Do the same for Rsrc1,Rsrc2 and FSS selecting the appropiate files
You should now be ready to flash. Connect your phone to your comp and then click download in multiloader. AT THIS POINT DO NOT TOUCH YOUR PHONE/DETATCH THE CABLE/SWITCH OFF YOUR COMP. Your phone should have a status indicator with percentages and this should be reflected in multiloader. The process should tkae about 5 minutes thgouh I'm not sure about that. Once it's done your phone will restart twice by itself. Once this is done it should start up as normal into the widgets page. It's now complete.
Ps: this is not my work.....I dont want to take credit whatsoever
Frenzy
The Following 2 Users Say Thank You to Frenzy_2020 For This Useful Post:
Old 01-09-2010, 04:34   #4 (permalink)
K1n
Member: 237887
Thanks Meter: 3
thank my brod but i've done all u said but the problem is already there
Old 01-11-2010, 15:16   #5 (permalink)
Member: 81701
hi i have phone freeze will this cure the problem .thanks in advance pat.
Old 01-11-2010, 23:10   #6 (permalink)
Member: 690027
Thanks Meter: 7
GUIDE: How to flash your F480 Tocco
Downloading the software:
First off you need to download the firmware you want and then Multiloader V5.33 which is the program you're going to be using to flash your phone.
F480XEHE1
http://www.mediafire.com/download.php?uykac2jjusd
F480XEHE2
http://www.mediafire.com/?ylcthnu0tyy
F480XEHF2
http://www.mediafire.com/?9w2u40e9m4z
F480XEHF3
http://rapidshare.com/files/12658213...XEHF3.rar.html
F480XXHD9
http://www.mediafire.com/?ttg0mybtzie
This appears to be the latest firmware F480XXHF7
http://www.mediafire.com/download.php?xyyheqh2jkw
F480BOHE3 (branded FW t-mobile) deutsch,english,french
http://www.file-upload.net/download-...BOHE3.zip.html
http://rapidshare.com/files/124143899/F480BOHE3.zip
http://www.dongnamass.com/Samsung/Fl.../F480BOHE3.zip
F488ZHHE8 (chinese)
http://rapidshare.com/files/12588987...ZHHE8.rar.html
MultiLoader_V5.33.exe
http://www.mediafire.com/?czizm9zg32w
Make sure you remember where you've put these files as you'll need to browse to them when using multiloader.
I am assuming here that you've already installed Samsung PC Studio and it works fine with your supplied USB cable.
Once that's done remove any memory card you may have and then remove the SIM card. Put the battery back in. Your phone should be off at this point. Hold down the 'Volume down' key (The bottom rocker button on the left side of your phone) and the camera button and press the power on button. Your phone should start up into a wierd screen with downloader v.5.32 or something and some boxes. It's now ready to be flashed.
Using Multiloader:
Open multiloader. It should look something like this without all the settings selected (The middle section should be blank!):
Originally Posted by .:Morpheus:.
Ok, Morpheus originally selected the wrong option in the top box, you should select the second option from the top (MSM6275/MSM6280). Try firmware F480XXHF7
Then press the AMSS button on the left side and browse to the firmware files you want to flash (unzip/rar them as necessary). Go to the binary folder and then select amss_compressed. Do the same for Rsrc1,Rsrc2 (Rsrc2 MID or LOW? – many use LOW) and FSS selecting the appropriate files as shown in the above pic.
You should now be ready to flash. Connect your phone to your comp and then click download in multiloader. AT THIS POINT DO NOT TOUCH YOUR PHONE/DETATCH THE CABLE/SWITCH OFF YOUR COMP. Your phone should have a status indicator with percentages and this should be reflected in multiloader. The process should take about 5 minutes though I'm not sure about that. Once it's done your phone will restart twice by itself. Once this is done it should start up as normal into the widgets page. It's now complete.
Congratulations on flashing your phone. You can now replace your SIM and Memory card and set up your phone the way you like it.
The Following 3 Users Say Thank You to Damsl123 For This Useful Post:
Old 01-11-2010, 23:23   #7 (permalink)
Member: 690027
Thanks Meter: 7
I'm sorry but I couldn't add any screenshots to the above post so I hope it makes sense.
It was a long while ago when I did this so I'm not even sure the links will work either but maybe you google some of the link names i.e. multiloader v5.33.
Oh may I add I do think you need to use multiloader v5.33 and NOT v5.56 - well I would just to be sure I'm using the right one, i don't know - just a thought!!
Sorry I couldn't be of more help
The Following User Says Thank You to Damsl123 For This Useful Post:
Old 01-14-2010, 12:25   #8 (permalink)
LEENO's Avatar
Member: 38084
Thanks Meter: 86
F480XEHE1
F480XEHE2
F480XEHF2
F480XEHF3
F480XXHD9
F488ZHHE8 (chinese)
Using Multiloader:
Then press the AMSS button on the left side and browse to the firmware files you want to flash (unzip/rar them as necessary). Go to the binary folder and then select amss_compressed. Do the same for Rsrc1,Rsrc2 (Rsrc2 MID or LOW? many use LOW) and FSS selecting the appropriate files as shown in the above pic.
Thanks friend but
LINK FOR F480XXHF7 and downloader not work, please reupload
The Following User Says Thank You to LEENO For This Useful Post:
Old 09-17-2010, 15:45   #9 (permalink)
Member: 72515
Thanks Meter: 27
Info
Can any body re-upload?
Regards
Old 03-17-2011, 17:34   #10 (permalink)
Super Moderator
axecom's Avatar
Member: 1424719
Sonork: 100.1619833
Thanks Meter: 2,191
F480XXHF7.rar
Old 04-07-2014, 08:15   #11 (permalink)
Member: 1930384
Sonork: 100.1638377
Thanks Meter: 8
thanks bro
Old 01-26-2015, 09:15   #12 (permalink)
Member: 1062495
Sonork: Niraj Thapa 9841450574
Thanks Meter: 12
f480 flash ok this file F480XXHF7
How to find flash with correct language S302, W205,..etc? mtmobiltech Cruiser Suite 0 12-02-2009 11:00
How to Read Flash D900i with HWK2.08 GsmBest-Wei HWK 1 10-29-2008 15:01
How to read flash 2 with 2cpu 2flash phone ? Ahahahaaaa SpiderMan 6 09-29-2008 09:49
How to unlock/Flash LG with Dongle.plz help. unitedtelecom Z3X-Team Products 1 03-12-2008 12:25
HOW TO FULL FLASH DB2020 With Setool PLZZZ HELP mobileunlockers Sony Ericsson 2 07-09-2007 18:26
Page generated in 0.37582 seconds with 8 queries
