QUALCOMM Models (3G) SGH-Z105x, SGH-Z107x, Z110, Z130, Z140, Z300, Z320i, Z500, Z510, ZM60, ZV10, ZV30, ZX10. |
03-07-2009, 20:39 | #4 (permalink) |
No Life Poster Join Date: Apr 2006 Location: Hong Kong | USA Age: 35
Member: 258172 Status: Offline Thanks Meter: 10,367 | Samsung I560 flash/update Instructions 1- Download the program to update the firmware – Apollo 2- Download I560 firmware 3- Download the SS60_Downloader_Driver.zip 4- Turn the phone off and then hold down the 4 and 7 keys on your phone and turn it on, This starts the phone in the “All Download” mode Connect the USB cable from you computer to your mobile and when is asks for a driver use “SS60_Downloader_Driver” that you downloaded. Once it has installed both the phone and PDA drivers, Start the Apollo program and connect the USB cable from you computer to your mobile. A COM port should appear in “No. 1 Modem”. Select the *.bin file by hitting the “Modem Code” button and the *.img file by hitting the “PDA Image” button then hit the “All Download” button to flash your phone. Once the update is complete the phone will reboot. Unplug the USB cable. br |
The Following 12 Users Say Thank You to ::.::RAMJAN::.:: For This Useful Post: |
09-16-2009, 11:20 | #5 (permalink) |
Freak Poster Join Date: May 2007 Location: South Africa Age: 44
Member: 505446 Status: Offline Thanks Meter: 45 | Sir!i had one !560v.it switches on with start up display screen but after couple of moments it just go blank.and cant be switched off from power swtch.so i tried to flash it with appolo according to ur instructions and with the firmware you suggested in given link.flash was done 100%.but phone is just stucked at startup screen.i also tried to use different firmware but problem still persists. when i press 4+7+p.button phone shows all download,but automatically install the drivers of modem only.And does not detect the pda drivers.But if i press 4+1 then only it detects PDA and i should install them manualy.it was done. so flashed it in two sessions, 1-PDA download 2-modem download please let me know the reason of my failuare and the solution.thanks |
09-16-2009, 13:18 | #6 (permalink) |
09-18-2009, 09:45 | #7 (permalink) | |
No Life Poster Join Date: Aug 2006 Location: gsmchaudhrayarshad Age: 43
Member: 328688 Status: Offline Thanks Meter: 2,282 | Quote:
thanx lot to help but i hve this problem wht to do nw*+7 modem download mode dont detect driver 4+7 all download mode driver detected 1+4 pda mode driver detected | |
09-18-2009, 21:03 | #8 (permalink) |
No Life Poster Join Date: Oct 2007 Location: South Africa/Pakistan
Member: 619308 Status: Offline Sonork: 100.1591829 Thanks Meter: 243 | try to put phone in modem mode and open apollo and conect i560 with orignal usb and see if its detect port. coz some its happen some time driver alrealy instald and when u conect phone its dont show new hareware found and also dont show in device manger. so try as i said if its dont detect remove and put cable again if its detect thats mean modem prat is ok. and them put pone in all download mode and select file presss all download . |
09-19-2009, 06:52 | #9 (permalink) | |
brother i try on 3 pc but no luck it show this i can,t see any thing on applo where fone conected *+7 modem download mode dont detect driver 4+7 all download mode driver detected 1+4 pda mode driver detected | |
how to flash a52? | fuadgsm | E-Gold Based Phones | 1 | 03-29-2010 18:48 |
How to flash SGH B520.-URGENT- | prashantvrm | Samsung Flashers, Software, Firmware. | 1 | 03-29-2010 13:24 |
how to flash e250i | adda2004 | Samsung Flashers, Software, Firmware. | 0 | 03-29-2010 12:26 |
how to flash 1st cpu & how to flash 2nd cpu | kasim | Infinity-Box | 4 | 03-15-2008 11:09 |
