QUALCOMM Models (3G) SGH-Z105x, SGH-Z107x, Z110, Z130, Z140, Z300, Z320i, Z500, Z510, ZM60, ZV10, ZV30, ZX10. |
10-07-2005, 17:21 | #1 (permalink) |
Junior Member Join Date: Oct 2005 Age: 35
Member: 186829 Status: Offline Thanks Meter: 6 | Unlock and/or unfreeze Samsung Z??? phones (Z140/V, Z300/M, Z500/V, ZM60, ZV30, ZX10) The explanation for how to do is already on this forum but to make it easier for everyone to find it, I'm making my 1 for all (Z series phones) post. The supported phones for this process are (the Z series phones): (as listed in the program) SGH-Z140 SGH-Z140V SGH-Z300 SGH-Z300M SGH-Z500 SGH-Z500V SGH-ZM60 SGH-ZV30 SGH-ZX10 To unlock and/or unfreeze these phones you must follow the next steps: - Download and install QUALCOMM UNLOCKER (http://www.megaupload.com/?d=39RITNDZ) - Install the propper USB drivers for your mobile (if it comes with CD, if that CD has the USB drivers, it's those ones that you should use, otherwise, download: http://org.downloadcenter.samsung.co...USBDriver.exe). - Have the proper USB cable for your mobile (if it comes with one, it's that one that you should use). - After having your phone correctly connected to your computer (using the USB cable) and turned ON (with or without the SIM inserted), set the mobile modem COM port as one between port 2 to port 9 (ports 2 and 9 included). [Note] - Connect (with something like a metallic wire for example) the 2nd and 3rd pins of the COM1 port (behind your computer), like the example below (imagine it like a COM - 9 pinned - port): ... ______ ( · · · ) ...\ · · · · / ' ... ŻŻŻŻŻ - Before attempting to unlock your mobile (though everything looks OK), click on the "Read Settings" to be completely sure that the program is completely detecting your mobilephone and to make it able to unlock it (by reading the phone's internal codes). - After all the previous steps... Press UNLOCK. It will remove all the phone locks and the phone freeze (if needed). [Note]: To set the COM port, run the QUALCOMM UNLOCKER program and click on "Check Modem", then, in the "Phone and Modem Options" menu, click on the "Modem" tab, select your mobilephone on the modem list and then click proprieties. In the modem proprieties menu, you must click on the "Advanced" tab and then click on "Advanced Port Settings". In the "Advanced Port Settings menu, there should be a dropdown list, in the bottom of the window, to select the desired COM port for your mobile. The port must not have 2 digits - like COM10 or above - and it's not convenient to be set as COM1. Select one of the unused and confirm everything by clicking all "OK" buttons. Then you'll have your phone completely free of lockings and freezings. I did it with my own Z300 and, after doing it just like I described, it finally worked. Hope this thread was usefull and enjoy your phones without restrictions. Last edited by -minorKa-; 10-07-2005 at 17:36. |
The Following 6 Users Say Thank You to -minorKa- For This Useful Post: |
10-07-2005, 17:31 | #2 (permalink) |
No Life Poster Join Date: Jun 2005 Location: Computer Age: 41
Member: 154696 Status: Offline Thanks Meter: 16 | Thanks you very much ! I think you should post pinout, coz Z500 & Z140V have different cable connector. Another way : *7465625*28782# *7465625*28638# (NOTE: When you change sim to other operator repeat this process to unlock it for that operator also) |
The Following User Says Thank You to BMobile For This Useful Post: |
10-07-2005, 17:57 | #3 (permalink) |
Member: 186829 Status: Offline Thanks Meter: 6 | Yeah, that trick should work. I never tested it 'cause I never wanted to and now I don't need it anymore. The reason I never used it is that it doesn't exactly unlock the phone; it works because there probably is a bug on the programming of the phones that makes them ignore the other type of network locking by auto-locking the actual SIM's network. So it's not the real unlocking of the phone; it's just a way of making the phone work with the SIM you want by locking the phone to the SIM's network with an different type of locking that seems to work by itself beside the other lockings. I'm also not sure that those codes remove "phone freeze" and I guess not because it's not their function to remove it (but it could also happen as it isn't even supposed to unlock any phone... just some, in some operators). It's an illusionall unlock, but for ocasional situations it's probably more usefull because it's quick. If anyone really wants to unlock and/or unfreeze the phone, it should do it the way I did and that it's explained above. About the cable connector, I just said above that the person should have the proper USB cable for it's phone. I did not said which cable is, but I guess all the phones bring it in it's box (at least they should, just like mine). |
10-07-2005, 18:57 | #4 (permalink) | |
No Life Poster Join Date: Aug 2003 Location: Town City Age: 54
Member: 37735 Status: Offline Sonork: 100.103255 Thanks Meter: 205 | Quote:
Thanks, But what the difference with the Z105 Unlocker??? I always unlock Z500 with it. | |
10-12-2005, 09:52 | #13 (permalink) |
No Life Poster Join Date: Dec 2004 Location: Dublin Age: 44
Member: 100436 Status: Offline Thanks Meter: 57 | I'll have two Samsung Z140v's within the next hour so I need to know if the LG U8120 USB/Com cable can help me, or the USB cable that comes with the phone ? TIA :-) |
10-12-2005, 11:37 | #14 (permalink) |
Member: 100436 Status: Offline Thanks Meter: 57 | I couldn't get the above program working for me . But I have successfully unlocked two Samsung Z104v's . I used the Samsung_Z105_Z107_Z300_Code_Reader_2_0_2 program with the USB cable that comes with the phone, the LG U8120 USB/Com cable didn't seem to work for me with the Samsung_Z105_Z107_Z300_Code_Reader_2_0_2 program. Anyway I'm happy , one was locked to Vodafone UK the other to Vodafone Ireland. BR Unlock_Ireland |
10-17-2005, 07:13 | #15 (permalink) | |
Product Manager Join Date: Feb 2003 Location: Your Exclusive Source
Member: 20645 Status: Offline Sonork: 100.1579175 Thanks Meter: 635 | Quote:
REGARDS GSM MIND STAND ALONE | |
Samsung Qualcomm tool 4.1 release! Direct unlock and repair IMEI all MSL2 phones!!! | mk | Z3X-Team Products | 34 | 12-26-2008 18:19 |
please Mr.Elco support unlock and flash for samsung A727 ASAP | tsarkh | NSPRO | 2 | 06-26-2008 10:20 |
Free unlocker and flasher for samsung D600 | jignesh_1000 | Samsung Flashers, Software, Firmware. | 20 | 03-30-2007 08:35 |
Cruiser doubt... does unlocking and/or changing language erases memory? | UnlockBR | Cruiser Suite | 9 | 12-29-2004 18:40 |
