QUALCOMM Models (3G) SGH-Z105x, SGH-Z107x, Z110, Z130, Z140, Z300, Z320i, Z500, Z510, ZM60, ZV10, ZV30, ZX10. |
09-16-2010, 06:03 | #1 (permalink) |
Junior Member Join Date: Sep 2010
Member: 1394556 Status: Offline Thanks Meter: 1 | Samsung S3653 Security Code I sincerely thank you. Sincerely: nguyenducbg |
09-16-2010, 17:34 | #2 (permalink) |
Freak Poster Join Date: Nov 2006 Location: Ireland
Member: 384012 Status: Offline Thanks Meter: 28 | All code's of samsung attached here *2767*688# = Unlocking Code *#8999*8378# = All in one Code *#4777*8665# = GPSR Tool *#8999*523# = LCD Brightness *#8999*3825523# = External Display *#8999*377# = Errors #*5737425# = JAVA Something{I choose 2 and it chrashed}] *#2255# = Call List #*536961# = Java Status Code #*536962# = Java Status Code #*536963# = Java Status Code #*53696# = Java Status Code #*1200# = AFC DAC Val #*1300# = IMEI #*1400# = IMSI #*2562# = ??? White for 15 secs than restarts. #*2565# = Check Blocking #*3353# = Check Code #*3837# = ??? White for 15 secs than restarts. #*3849# = ??? White for 15 secs than restarts. #*3851# = ??? White for 15 secs than restarts. #*3876# = ??? White for 15 secs than restarts. #*7222# = Operation Typ (Class C GSM) #*7224# = I Got !! ERROR !! #*7252# = Oparation Typ (Class B GPRS) #*7271# = Multi Slot (Class 1 GPRS) #*7274# = Multi Slot (Class 4 GPRS) #*7276# = Dunno #*7337# = EEPROM Reset (Unlock and Resets Wap Settings) #*2787# = CRTP ON/OFF #*3737# = L1 Dbg data #*5133# = L1 Dbg data #*7288# = GPRS Attached #*7287# = GPRS Detached #*7666# = SrCell Data #*7693# = Sleep Act/DeAct (Enable or Disable the Black screen after doing nothing for a while) #*7284# = Class : B,C or GPRS #*2256# = Calibration Info #*2286# = Battery Data #*2527# = GPRS Switching (set to: class 4, class 8, class 9 or class 10) #*2679# = Copycat feature (Activate or Deactivate) #*3940# = External loop test 9600 bps #*4263# = Handsfree mode (Activate or Deactivate) #*4700# = Half Rate (Activate or Deactivate) #*7352# = BVMC Reg value #*8462# = Sleeptime #*2558# = Time ON #*3370# = EFR (Activate or Deactivate) #*3941# = External looptest 115200 bps #*5176# = L1 Sleep #*7462# = SIM phase #*7983# = Voltage/Frequenci (Activate or Deactivate) #*7986# = Voltage (Activate or Deactivate) #*8466# = Old time #*2255# = Call ??? #*5187# = L1C2G trace (Activate or Deactivate) #*5376# = ??? White for 15 secs than restarts. #*6837# = Official Software Version #*7524# = KCGPRS #*7562# = LOCI GPRS #*7638# = RLC allways open ended TBF (Activate or Deactivate) #*7632# = Sleep mode Debug #*7673# = Sleep mode RESET #*2337# = Permanent Registration Beep #*2474# = ??? #*2834# = Audio Path #*3270# = DCS support (Activate or Deactivate) #*3282# = Data (Activate or Deactivate) #*3476# = EGSM (Activate or Deactivate) #*3676# = Flash volume formated #*4760# = GSM (Activate or Deactivate) #*4864# = Dunno doesn't work on newer versions #*5171# = L1P1 #*5172# = L1P2 #*5173# = L1P3 #*7326# = Accessory (I got Vibrator) #*7683# = Sleep variable (Cool #*7762# = SMS Brearer CS (Activate or Deactivate) #*8465# = Time in L1 #*9795# = wtls key #*2252# = Current CAL #*2836# = AVDDSS Management (Activate or Deactivate) #*3877# = Dump of SPY trace #*7728# = RSAV done# (Everything went to standart but nothing was deleted) #*2677# = ARM State (None or Full Rate) *#8999*636# = Have no clue what it is, i see 20 lines *#9999# = Software version *#8999*8376263# = HW ver, SW ver and Build Date *#8888# = HW version *#8377466# = Same HW/SW version thing *#7465625# = Check the locks *7465625*638*Code# = Enables Network lock #7465625*638*Code# = Disables Network lock *7465625*782*Code# = Enables Subset lock #7465625*782*Code# = Disables Subset lock *7465625*77*Code# = Enables SP lock #7465625*77*Code# = Disables SP lock *7465625*27*Code# = Enables CP lock #7465625*27*Code# = Disables CP lock *7465625*746*Code# = Enables SIM lock #7465625*746*Code# = Disables SIM lock *7465625*228# = Activa lock ON #7465625*228# = Activa lock OFF *7465625*28638# = Auto Network lock ON #7465625*28638# = Auto Network lock OFF *7465625*28782# = Auto subset lock ON #7465625*28782# = Auto subset lock OFF *7465625*2877# = Auto SP lock ON #7465625*2877# = Auto SP lock OFF *7465625*2827# = Auto CP lock ON #7465625*2827# = Auto CP lock OFF *7465625*28746# = Auto SIM lock ON #7465625*28746# = Auto SIM lock OFF *2767*3855# = E2P Full Reset *2767*2878# = E2P Custom Reset *2767*927# = E2P Wap Reset *2767*226372# = E2P Camera Reset #*6420# = MIC Off #*6421# = MIC On #*6422# = MIC Data #*6428# = MIC Measurement #*3230# = Trace enable and DCD disable #*3231# = Trace disable and DCD enable #*3232# = Current Mode #7263867# = RAM Dump (On or Off) *2767*49927# = Germany WAP Settings *2767*44927# = UK WAP Settings *2767*31927# = Netherlands WAP Settings *2767*420927# = Czech WAP Settings *2767*43927# = Austria WAP Settings *2767*39927# = Italy WAP Settings *2767*33927# = France WAP Settings *2767*351927# = Portugal WAP Settings *2767*34927# = Spain WAP Settings *2767*46927# = Sweden WAP Settings *2767*380927# = Ukraine WAP Settings *2767*7927# = Russia WAP Settings *2767*30927# = GREECE WAP Settings *2767*73738927# = WAP Settings Reset *2767*49667# = Germany MMS Settings *2767*44667# = UK MMS Settings *2767*31667# = Netherlands MMS Settings *2767*420667# = Czech MMS Settings *2767*43667# = Austria MMS Settings *2767*39667# = Italy MMS Settings *2767*33667# = France MMS Settings *2767*351667# = Portugal MMS Settings *2767*34667# = Spain MMS Settings *2767*46667# = Sweden MMS Settings *2767*380667# = Ukraine MMS Settings *2767*7667#. = Russia MMS Settings *2767*30667# = GREECE MMS Settings *335# = Delete all MMS Messages *663867# = Dump Mm file #*536961# = WAPSAR enable / HTTP disable #*536962# = WAPSAR disable / HTTP enable #*536963# = Serial eable / Others disable #*53696# = Java Download Mode #*5663351# = Wap Model ID [Your Model] #*5663352# = Wap Model ID [SEC-SGHXXXX/1.0] #*566335# = Wap Model ID [SEC-SGHXXXX/1.0] *2767*66335# = Check on which model it is *2767*7100# = SEC-SGHS100/1.0 *2767*8200# = SEC-SGHV200/1.0 *2767*7300# = SEC-SGHS300/1.0 *2767*7650# = Nokia7650/1.0 *2767*2877368# = Reset WAP Model reset |
Help: Forgot my 6110 user lock code!! | GByte9 | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 02-26-2016 14:52 |
PIN1/PIN2 CODE | Jon | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 12-26-2012 04:40 |
5110 Security Code Help! | cahrisma | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 6 | 07-05-2010 09:04 |
Orange IL, Nokia 5110 GSM codes... | rosso11 | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 11-05-1999 21:38 |
