Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Samsung > QUALCOMM Models (3G)
QUALCOMM Models (3G) SGH-Z105x, SGH-Z107x, Z110, Z130, Z140, Z300, Z320i, Z500, Z510, ZM60, ZV10, ZV30, ZX10.
Old 11-13-2008, 23:11   #1 (permalink)
Member: 900085
Samsung F480 Touching problem...Pls help.
My F480 stop working, touch screen seem not function at all. 3 buttons at bottom still work. Already flash to newest version ( F480xxhf7) couple times still no go... Any ideas here !! or someone has any schematic for this.... Many thanks...
The Following User Says Thank You to td99 For This Useful Post:
Old 11-14-2008, 19:56   #2 (permalink)
Member: 900085
Is there any body out here got the same problem or it's just me ???
Old 11-18-2008, 15:07   #3 (permalink)
Member: 883667
Hi, i seem to have the same problem! Once a while my touchscreen doesn't react at all... The only thing what helps then is to remove the battery...
My phone came with the firmware F480xxhf7... could it be due to this firmware? Did you have this problem also wit an older version firmware?
Old 03-05-2009, 00:21   #4 (permalink)
dragosgsm's Avatar
Member: 148032
Thanks Meter: 387
I am facing same problem after unlock with a new F480 phone!!!!!
I had used search and didn't find any solution for this...
There's no one who knows what's wrong??????????
Old 03-21-2009, 16:49   #5 (permalink)
Member: 733637
Hey Guys,
Same probleme over here,
After simlock removal the touch screen stopped working, I still can use the buttoms on the phone but the touch screen doesn't react to anything anymore!!
Does any-one know a solution ?
Grtzzzz...
The Following User Says Thank You to DarkDemon For This Useful Post:
Old 03-22-2009, 16:37   #6 (permalink)
Member: 938611
Thanks Meter: 43
Try updating to a firmware released in 2009 such as F48FXEIA3 or F48OXEIB1
Both can be found at www.samsungflash****
along with tools and tutorials to help you with everything
The Following User Says Thank You to jtaylor06 For This Useful Post:
Old 03-22-2009, 20:47   #7 (permalink)
Member: 733637
I allready did !!
But the probleme stays the same.
Can anyone tell me what that symbol of a blue policelight in the left upper corner of my screen means ?
Grtzz...
Old 03-23-2009, 09:03   #8 (permalink)
Member: 938611
Thanks Meter: 43
Originally Posted by DarkDemon View Post
I allready did !!
Grtzz...
SOS Mode.
You can find out about it by going to Messages then SOS Messages.
Old 10-05-2011, 09:04   #9 (permalink)
Member: 32705
Thanks Meter: 40
i have tried flashing and replacing the touch screen but i still have the same problem. any suggestions will be most welcome. i have two with the same problem.
Old 10-06-2011, 12:31   #10 (permalink)
Member: 1645045
Thanks Meter: 23
What tools are you lot using???
Samsung i900 Omnia Touch problem, plz help Pid-Handy-FIt Samsung Hardware Repair 0 03-26-2010 17:31
help plz samsung f480 touch screen stopped working deemonh1157 Samsung Hardware Repair 0 02-17-2010 14:39
Samsung f480 touch not work properly tutu1982 Samsung Hardware Repair 1 12-26-2009 23:59
Samsung r220 flashing problem..pls. Help amit123 Samsung Hardware Repair 1 06-12-2009 08:32
samsung x520 ringer problem pls help rkinfo_imran Samsung Hardware Repair 0 11-29-2007 10:04
Page generated in 0.33753 seconds with 8 queries
