Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Samsung > QUALCOMM Models (3G)
QUALCOMM Models (3G) SGH-Z105x, SGH-Z107x, Z110, Z130, Z140, Z300, Z320i, Z500, Z510, ZM60, ZV10, ZV30, ZX10.
Old 10-24-2008, 09:23   #1 (permalink)
zeel_zeel's Avatar
Member: 205427
Sonork: 100.1580937
Thanks Meter: 1,159
*** Samsung i900 Omnia Hard Reset Solution ***
Samsung i900 Omnia can be hard reset / format can be done >>>
Hold the End and Send button lightly at the same time press Soft-Reset button with slylus and you will get hard reset menu. Just press call key and its done..
The Following 55 Users Say Thank You to zeel_zeel For This Useful Post:
Old 10-29-2008, 15:46   #2 (permalink)
Member: 283222
Thanks Meter: 17
can i ask a s2pid question??? brother did u already try this one???
The Following User Says Thank You to BoooM For This Useful Post:
Old 11-05-2008, 06:43   #3 (permalink)
Member: 840255
Thanks Meter: 2
I900 Hard reset
it is working....tried..
The Following User Says Thank You to symech For This Useful Post:
Old 11-08-2008, 15:44   #4 (permalink)
Member: 139718
Thanks Meter: 3
I tried this solution but did not work. anybody with a better soluton i need it urgently.
The Following User Says Thank You to blueprint For This Useful Post:
Old 11-10-2008, 14:47   #5 (permalink)
Crazy Poster
Member: 307854
Thanks Meter: 29
its wrong i tired other solution i share with you my gsm friends
1st switch off mobile 1st hold send and call end button than turn on power button also hold after few seconds you see on the screen yes or no you want format and and remove your password or user code so press call recieve button its done. i check today.
B.R
The Following 27 Users Say Thank You to hearthacker73 For This Useful Post:
Old 11-10-2008, 15:44   #6 (permalink)
Member: 627108
Thanks Meter: 11
i tried and it performed.thanks zeel zeel
The Following User Says Thank You to M_ABRISHAMI For This Useful Post:
Old 11-11-2008, 16:45   #7 (permalink)
Member: 898206
Hi guys,
Ive got a similar problem with my Omnia (locked out of it because I forgot my password!) but neither of the above methods have been successful for some reason.. Any ideas why? Or any different methods to reset the phone or password?
Thanks very much,
Cam
The Following User Says Thank You to Notty04 For This Useful Post:
Old 11-12-2008, 09:07   #8 (permalink)
Member: 311455
B.R
This solution works 4 me. tx
The Following User Says Thank You to lumi For This Useful Post:
Old 11-19-2008, 11:10   #9 (permalink)
Member: 45985
Thanks Meter: 96
Ive done it making soft reset and immediately after that pressing and holding call+end for few secs.
The Following User Says Thank You to gjurobrod For This Useful Post:
Old 11-20-2008, 21:23   #10 (permalink)
SLIPLOCK's Avatar
Member: 86301
Thanks Meter: 107
for hard reset, press one time reset (not hold) and when you see the first logo press both SEND and END , the format menu appears instantly.press SEND for format.
WBR
The Following 17 Users Say Thank You to SLIPLOCK For This Useful Post:
Old 11-20-2008, 22:14   #11 (permalink)
Member: 114797
Thanks Meter: 23
Yup this methods mentioned here works all the time. Tried and tested on a lot of Omnias.
The Following User Says Thank You to kiwiboi For This Useful Post:
Old 11-21-2008, 06:20   #12 (permalink)
Member: 45985
Thanks Meter: 96
Not for me,maybe i was to slow
Old 11-22-2008, 06:01   #13 (permalink)
zeel_zeel's Avatar
Member: 205427
Sonork: 100.1580937
Thanks Meter: 1,159
May be you need be a little quick. Try for a few time and you will succeed..
The Following 2 Users Say Thank You to zeel_zeel For This Useful Post:
Old 11-22-2008, 06:15   #14 (permalink)
Member: 45985
Thanks Meter: 96
I have done it as i described in previous post
Old 03-25-2009, 21:33   #15 (permalink)
Member: 105522
Thanks Meter: 31
you can do it like that :
enter to menu > setting > restart > erase memory, then enter 1234
that's all
The Following User Says Thank You to Emir For This Useful Post:
Help!!! i900 omnia phone off solution. abote didier QUALCOMM Models (3G) 3 11-16-2010 05:47
OMNIA hard reset another trick Rise QUALCOMM Models (3G) 0 06-30-2009 10:18
Page generated in 0.37009 seconds with 8 queries
