QUALCOMM Models (3G) SGH-Z105x, SGH-Z107x, Z110, Z130, Z140, Z300, Z320i, Z500, Z510, ZM60, ZV10, ZV30, ZX10. |
06-05-2011, 08:29 | #31 (permalink) |
Banned Join Date: Jan 2008 Location: Pune India
Member: 687840 Status: Offline Thanks Meter: 12 | 1] phone should be on then 2] press and hold green and red buttons then press reset button for 5 sec then release reset button. 3] It will ask u to Formate and cancel then for Formate press green button phone will restart automatically...done and enjoy |
10-05-2011, 19:56 | #32 (permalink) |
Junior Member Join Date: Apr 2010 Location: Philippines Age: 41
Member: 1286387 Status: Offline Sonork: Buns27 Thanks Meter: 5 | it works!!! nice bro.... just press call and end call together power button den a menu will appear press call to format or end call to cancel...... |
11-21-2011, 21:25 | #34 (permalink) |
No Life Poster Join Date: Jan 2009 Location: SPAIN
Member: 938547 Status: Offline Sonork: 100.1591926 Thanks Meter: 481 | this is old poste but may be will help new unlocker if use searcg button Samsung Omnia (I900) Hard Reset - YouTube |
05-23-2012, 11:55 | #37 (permalink) |
Insane Poster Join Date: Sep 2009
Member: 1116099 Status: Offline Sonork: [email protected] Thanks Meter: 4 | take off the battery and put in the battery back and press and hold send button+end button then press power button you will see format and cancel so just press the send key again the job is done |
08-03-2012, 15:39 | #38 (permalink) |
Freak Poster Join Date: Apr 2003 Location: Dublin Age: 43
Member: 25852 Status: Offline Thanks Meter: 31 | Solution for all which say not working..... when you holding send and cancel button make shure that you presing them on outside ends otherwhise midle button is pressed as well thats why sollution not working for you cheers. |
09-08-2012, 17:34 | #39 (permalink) | |
Junior Member Join Date: Sep 2012
Member: 1808102 Status: Offline Thanks Meter: 0 | Quote:
Thank you a million times, you post save my phone from getting into the trash can. I was dying on how to hard reset it with out going into the GUI, because one of the theme i installed damage my system which cause the GUI unusable. Worst thing is the last time its working the USB mode was set to Mass Storage making it imppossible for me to flash the ROM again unless i can switch it back to active sync. So i need to find a way to hard reset it and your post work just like a magic, because after the reset everything was restored to the original default configuration of the custom rom, so i dont have to flash is again. Thanks again. | |
09-09-2013, 12:15 | #41 (permalink) |
Registered User Join Date: Sep 2008 Location: HardWare+Software & Unlocking
Member: 865598 Status: Offline Sonork: 100.1609492 Thanks Meter: 465 | Samsung i900 Omnia hard reset You can select this function under Main menu -> Settings -> System -> Hard Reset or With the phone turned ON press and hold the send and end buttons then use the stylus to reset Samsung i900 Omnia. Note: Your phone / battery must be fully charged! (or the phone will not do anything) |
09-17-2013, 17:03 | #42 (permalink) |
Freak Poster Join Date: Oct 2008 Location: ********** Age: 36
Member: 881000 Status: Offline Sonork: 100.1614181 Thanks Meter: 9 | 1 Turn off phone 2 Hold the End and Send button lightly at the same time press press power button 3 Release power button after samsunlg logo 4 On phone screen you have showing this message 5 Are you sure you want to format ? 6 Green call button for format and red End call button for cancell Press green button 7 done |
09-24-2013, 12:01 | #43 (permalink) |
Insane Poster Join Date: Sep 2006
Member: 344146 Status: Offline Thanks Meter: 1 | working............1st hold send and call end button than turn on power button also hold after few seconds you see on the screen yes or no you want format and and remove your password or user code so press call receive button its done. |
11-11-2014, 15:14 | #44 (permalink) |
Junior Member Join Date: Nov 2014 Location: pakistan
Member: 2288376 Status: Offline Sonork: 1668442 Thanks Meter: 1 | firrs on phone then presss reset phone will restart quick press call and end key same time he ask formate then press call .thats it phone will reset .10000000% i try. |
11-17-2014, 01:30 | #45 (permalink) | |
Freak Poster Join Date: Feb 2005 Location: Ukraine, Chernivtsy region Age: 39
Member: 112820 Status: Offline Thanks Meter: 75 | Quote:
And an answer!!!! I`ve flashed i900 ///// now it showing something about wrorng software,, bla bla bla , then restart,,,,,//////......What to do? Last edited by mihaser; 11-17-2014 at 01:35. | |
Help!!! i900 omnia phone off solution. | abote didier | QUALCOMM Models (3G) | 3 | 11-16-2010 05:47 |
OMNIA hard reset another trick | Rise | QUALCOMM Models (3G) | 0 | 06-30-2009 09:18 |
