QUALCOMM Models (3G) SGH-Z105x, SGH-Z107x, Z110, Z130, Z140, Z300, Z320i, Z500, Z510, ZM60, ZV10, ZV30, ZX10. |
05-30-2014, 09:41 | #1 (permalink) |
Junior Member Join Date: Jan 2007
Member: 432786 Status: Offline Thanks Meter: 2 | Samsung S8300c anycall camera failed |
The Following User Says Thank You to ahlkapon For This Useful Post: |
05-31-2014, 10:19 | #4 (permalink) |
Junior Member Join Date: Mar 2014
Member: 2156003 Status: Offline Thanks Meter: 0 | Try this solution. type *#6984125*# then select INTERNALS then tpye again *#9072641*# then pres done-confrim-test mode then press key 6 (video) then press key 3 (camera update) wait and enjoy if not work try this; -Type *#197328640# in the Idle mode, then you can reach the test mode. -Select [6] Video -Select [3] Camera Firmware update -[Please Wait] will be displayed -Wait a few minutes then [Please Wait] will be changed to [SUCCESS] If still doesn't fix,flash with latest available version. Tried and tested,maybe unit is patched to unlock. Gudluck. |
