QUALCOMM Models (3G) SGH-Z105x, SGH-Z107x, Z110, Z130, Z140, Z300, Z320i, Z500, Z510, ZM60, ZV10, ZV30, ZX10. |
10-15-2008, 21:17 | #1 (permalink) |
Junior Member Join Date: Oct 2008
Member: 876842 Status: Offline Thanks Meter: 1 | Samsung SGH-A737 bootfile or firmware fix request My phone communicates with my computer. The only function I have is to go through the download screen on the phone. Which is [ * + power on ]. The phone just cycles through the intro start routine now on normal mode. So I would like to get this repaired. I do not have any flash programs. So any help and directions in this would be thankfull. I do appreciate the help. I will write up my details if I am able to get my phone repaired this way. I am shure others would be interested in this knowledge. Thank you for any help. I am using the qualcomm usb driver function on the phone. |
10-15-2008, 21:36 | #2 (permalink) |
Member: 876842 Status: Offline Thanks Meter: 1 | Sorry to double post. I did not see an edit button. Here is my phone info. Samsung SGH-A737 Software: SW Version "A737.003" Firmware: SW Version "A737UCHD2" I do appreciate the help. |
10-16-2008, 03:05 | #3 (permalink) |
Member: 876842 Status: Offline Thanks Meter: 1 | Post number three. Will I install the older version "A737UCGI2" firmware on my phone. Everything works well. However, I am shure there are differences. I am unable to use my old method of add games with this firmware as it imediately goes to download to pc screen after reboot because of an IO error with the usb. So I am hoping the "A737UCHD2" firmware shows up. As this is a superior product firmware. Or at least it worked with my old method of adding games. |
The Following User Says Thank You to 72da9 For This Useful Post: |
10-16-2008, 23:57 | #4 (permalink) |
Member: 876842 Status: Offline Thanks Meter: 1 | Post four. Am I just not seeing an edit button. My old method may work, but I am not going to find out. I went with the wap method where charges may occur. One game did break the phone. At least this time when I turned it off then on. The phone worked without having to redo the firmware. I am still looking for the newer version of the firmware if it is out here. That would make the phone original again. It does appear that my antenna reception is better with this older firmware. There are more bars and stronger signals showing on the phone. |
Java Unlock code for Samsung SGH-A737 | bradpeterson2 | Samsung Flashers, Software, Firmware. | 0 | 08-03-2008 22:23 |
Samsung SGH A737 Phone Freeze Deactivation | baazigar4u | Samsung Flashers, Software, Firmware. | 8 | 06-25-2008 08:16 |
need help unlocking samsung sgh-a737 | buckwheat | QUALCOMM Models (3G) | 2 | 05-20-2008 11:51 |
Samsung SGH-A737 ANYTHING | Dougz13 | Samsung Media, Games, Ringtones | 0 | 05-20-2008 04:20 |
Locked out of Samsung SGH-A737 | BigTom3007 | Samsung Flashers, Software, Firmware. | 2 | 05-13-2008 05:45 |
