QUALCOMM Models (3G) SGH-Z105x, SGH-Z107x, Z110, Z130, Z140, Z300, Z320i, Z500, Z510, ZM60, ZV10, ZV30, ZX10. |
05-14-2010, 03:25 | #1 (permalink) |
Junior Member Join Date: May 2008 Location: phil.
Member: 767376 Status: Offline Sonork: 12345 Thanks Meter: 4 | U700 grounded help.... |
05-31-2010, 02:14 | #3 (permalink) |
Junior Member Join Date: Feb 2010 Location: Sultan Kudarat
Member: 1227890 Status: Offline Sonork: 100.1612890 Thanks Meter: 15 | Done w/ no error Blingking Getting MCU ID MCU ID: 0x2201 FLASH ID0: 88280020 <=> ST -> Type not in database Addr0: 0x01000000 - 0x01FFFFFF, SectorSize0: 10 FLASH ID1: 00010000 <=> Flash -> not used Addr1: 0x02000000 - 0x02FFFFFF, SectorSize1: 0 First 16 bytes: AD 7E B6 1A 1B BE 0B E2 7D 58 6B E4 DB EE 65 14 Checking RAM for ALGO... Algo is ready... Checking FAID calculation... P-key nokia module version 01.02 Done! Phone Restarted... FILES SET FOR FLASHING: MCU Flash file: NONE PPM Flash file: NONE CNT Flash file: NONE ADSP Flash file: NONE APE Variant file: NONE APE User Flash file: NONE Switching to serial... Powering the phone... Reading... MCU SW version: V 5.10 17-11-06 RM-189 (c) NMP HW version: 0501 PCI version: UEM version: 1314 UPP version: 8705 RFIC version: 0500 DSP version: P05w06.v39 LCD version: SEID:S31va1 PPM version: V 5.10 17-11-06 RM-189 (c) NMP AA ADSP SW version: V 5.10\n17-11-06\nRM-189\n(c) NMP\naa Production serial number: DDO073735 Product code: 0535491 Module code: 0203013 Basic production code: 0531456 Flash code: Order number: Product specific data: Long production SN: ATO: Default SN type: IMEI plain: 353655015709482 IMEI spare to net: 3A 35 56 05 51 07 49 08 IMEI SV to net: 33 35 56 05 51 07 49 28 F3 Master Code: 7657512243 Phone type: RM-189, Software version: 5.10, Language Pack: AA User code: rh0 Block 1: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 2: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 3: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 4: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 5: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 6: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 7: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Searching for saved ini... Checking for file C:\Program Files\ODEON\JAF\JAF_RM-189.ini Saved INI not found, loading INI list... Setting local mode... Reading product code... Product Code: 0535491 Checking path: C:\Program Files\Nokia\Phoenix\Products\RM-189\ Searching for default location of ini... Checking path: C:\Program Files\Common Files\Nokia\DataPackage\Products\RM-189\ Searching for JAF saved location of ini... Checking path: C:\Program Files\Nokia\Phoenix\Products\RM-189\ No ini files found... FILES SET FOR FLASHING: MCU Flash file: NONE PPM Flash file: NONE CNT Flash file: NONE ADSP Flash file: NONE APE Variant file: NONE APE User Flash file: NONE Done! FILES SET FOR FLASHING: MCU Flash file: NONE PPM Flash file: NONE CNT Flash file: NONE ADSP Flash file: NONE APE Variant file: NONE APE User Flash file: NONE FILES SET FOR FLASHING: MCU Flash file: NONE PPM Flash file: NONE CNT Flash file: NONE ADSP Flash file: NONE APE Variant file: NONE APE User Flash file: NONE Flashing Done! Operation took 0 minutes 0 seconds... After flash processing... Waiting for phone to boot... Reading... Phone type: RM-189, Software version: 5.10 IMEI: 353655015709482 Product Code: 0535491 Resetting PPC... Setting FULL FACTORY......Setting test mode... Setting FULL FACTORY... Operation took 0 minutes 8 seconds... Done! Done! Done! |
The Following User Says Thank You to denrich24 For This Useful Post: |
06-23-2010, 06:47 | #4 (permalink) |
Junior Member Join Date: Oct 2009
Member: 1149465 Status: Offline Sonork: [email protected] Thanks Meter: 1 | sir pls tell me about samsung u700 fone temprature is very low or very high... pls tell me about this problem.... phone does not charge. charging is suspended.. help me sir.. |
Winlock 1.10 - Help | rdmfs | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 06-25-1999 08:21 |
