-   QUALCOMM Models (3G) (http://forum.gsmhosting.com/vbb/f352/)
-   -   Unlock and/or unfreeze Samsung Z??? phones (Z140/V, Z300/M, Z500/V, ZM60, ZV30, ZX10) (http://forum.gsmhosting.com/vbb/f352/unlock-unfreeze-samsung-z-phones-z140-v-z300-m-z500-v-zm60-zv30-zx10-239111/)
-minorKa- 10-07-2005 18:21
This is a post to help everyone that has a Samsung Z serie mobile that is locked and/or freezed.
The explanation for how to do is already on this forum but to make it easier for everyone to find it, I'm making my 1 for all (Z series phones) post.
The supported phones for this process are (the Z series phones):
(as listed in the program)
SGH-Z140
SGH-Z140V
SGH-Z300
SGH-Z300M
SGH-Z500
SGH-Z500V
SGH-ZM60
SGH-ZV30
SGH-ZX10
To unlock and/or unfreeze these phones you must follow the next steps:
- Download and install QUALCOMM UNLOCKER (http://www.megaupload.com/?d=39RITNDZ)
- Install the propper USB drivers for your mobile (if it comes with CD, if that CD has the USB drivers, it's those ones that you should use, otherwise, download: http://org.downloadcenter.samsung.co...USBDriver.exe).
- Have the proper USB cable for your mobile (if it comes with one, it's that one that you should use).
- After having your phone correctly connected to your computer (using the USB cable) and turned ON (with or without the SIM inserted), set the mobile modem COM port as one between port 2 to port 9 (ports 2 and 9 included). [Note]
- Connect (with something like a metallic wire for example) the 2nd and 3rd pins of the COM1 port (behind your computer), like the example below (imagine it like a COM - 9 pinned - port):
…………………………………………... ______
'…………………………………………... ŻŻŻŻŻ
- Before attempting to unlock your mobile (though everything looks OK), click on the "Read Settings" to be completely sure that the program is completely detecting your mobilephone and to make it able to unlock it (by reading the phone's internal codes).
- After all the previous steps... Press UNLOCK. It will remove all the phone locks and the phone freeze (if needed).
[Note]: To set the COM port, run the QUALCOMM UNLOCKER program and click on "Check Modem", then, in the "Phone and Modem Options" menu, click on the "Modem" tab, select your mobilephone on the modem list and then click proprieties. In the modem proprieties menu, you must click on the "Advanced" tab and then click on "Advanced Port Settings". In the "Advanced Port Settings menu, there should be a dropdown list, in the bottom of the window, to select the desired COM port for your mobile. The port must not have 2 digits - like COM10 or above - and it's not convenient to be set as COM1. Select one of the unused and confirm everything by clicking all "OK" buttons.
Then you'll have your phone completely free of lockings and freezings. I did it with my own Z300 and, after doing it just like I described, it finally worked.
Hope this thread was usefull and enjoy your phones without restrictions.
BMobile 10-07-2005 18:31
Thanks you very much !
I think you should post pinout, coz Z500 & Z140V have different cable connector.
Another way :
*7465625*28782#
*7465625*28638#
(NOTE: When you change sim to other operator repeat this process to unlock it for that operator also)
-minorKa- 10-07-2005 18:57
Yeah, that trick should work. I never tested it 'cause I never wanted to and now I don't need it anymore. The reason I never used it is that it doesn't exactly unlock the phone; it works because there probably is a bug on the programming of the phones that makes them ignore the other type of network locking by auto-locking the actual SIM's network. So it's not the real unlocking of the phone; it's just a way of making the phone work with the SIM you want by locking the phone to the SIM's network with an different type of locking that seems to work by itself beside the other lockings. I'm also not sure that those codes remove "phone freeze" and I guess not because it's not their function to remove it (but it could also happen as it isn't even supposed to unlock any phone... just some, in some operators). It's an illusionall unlock, but for ocasional situations it's probably more usefull because it's quick.
If anyone really wants to unlock and/or unfreeze the phone, it should do it the way I did and that it's explained above.
About the cable connector, I just said above that the person should have the proper USB cable for it's phone. I did not said which cable is, but I guess all the phones bring it in it's box (at least they should, just like mine).
blaiseid 10-07-2005 19:57
SGH-Z140
SGH-Z140V
SGH-Z300
SGH-Z300M
SGH-Z500
SGH-Z500V
SGH-ZM60
SGH-ZV30
SGH-ZX10
Thanks,
But what the difference with the Z105 Unlocker??? I always unlock Z500 with it.
-minorKa- 10-07-2005 20:41
There is pratically no difference... but this version has more data so it is more specific and so is safer.
amitks_in 10-08-2005 16:07
and cable ?? coz customers will not provide cable to us !!!
Jass2mail 10-08-2005 16:20
same lg 3g cable
dear use lg 3g cable it will work on z500 100% tested..................
dishxpert 10-10-2005 08:50
The link to the USB driver doesnt work. All chinese gibbersih to me.
Kanwalgee 10-10-2005 09:23
i unlock z500 with lg 3g cabel 100% thanks for share:)
Unlocking_Master 10-11-2005 12:10
its worked my friend??????
Patrick 10-11-2005 21:04
Will the LG U8120 USB/Com cable work to unlock the Samsung Z140v ?
TIA
adomshima 10-12-2005 10:48
it works right?????????? using lg usb cable it is a greate gamble!!
Patrick 10-12-2005 10:52
I'll have two Samsung Z140v's within the next hour so I need to know if the LG U8120 USB/Com cable can help me, or the USB cable that comes with the phone ? TIA :-)
Patrick 10-12-2005 12:37
1 Attachment(s)
I couldn't get the above program working for me :( . But I have successfully unlocked two Samsung Z104v's ;) .
I used the Samsung_Z105_Z107_Z300_Code_Reader_2_0_2 program with the USB cable that comes with the phone, the LG U8120 USB/Com cable didn't seem to work for me with the Samsung_Z105_Z107_Z300_Code_Reader_2_0_2 program.
Anyway I'm happy :D , one was locked to Vodafone UK the other to Vodafone Ireland.
Unlock_Ireland ;)
GSM MIND 10-17-2005 08:13
SGH-Z140
SGH-Z140V
SGH-Z300
SGH-Z300M
SGH-Z500
SGH-Z500V
SGH-ZM60
SGH-ZV30
SGH-ZX10
HELLO MATE SAMSUNG UMTS Z140 ,ETC WHEN SOFTWARE OPEN IT ASK FROM ME USER ID AND PASSWORD HOW TO SLOVE THIS PROBLEM???
REGARDS
GSM MIND
STAND ALONE
Page generated in 0.39634 seconds with 5 queries
