QUALCOMM Models (3G) SGH-Z105x, SGH-Z107x, Z110, Z130, Z140, Z300, Z320i, Z500, Z510, ZM60, ZV10, ZV30, ZX10. |
10-08-2006, 17:12 | #198 (permalink) |
Major Poster Join Date: Apr 2005 Location: UK, North Kent
Member: 141482 Status: Offline Thanks Meter: 0 | Minorka done good I just wanted to confirm that the routine presented by Minorka at the start of this thread worked just fine with a new Samsung SGH-Z500V from Vodafone UK. The handset was originally SIMlocked to the Vodafone network. After following Minorka's script the handset is now accepting SIMs from any of the UK network providers - I tested it with T-Mobile, easyMobile, O2 and 3. If anyone is having difficulty with the routine please make absolutely certain that you have successfully made a good electrical link between COM1 pins 2 and 3. Someone suggested the jumper plug from a hard disk drive, that worked fine for me as a temporary solution. A more permanent arrangement would be a DB9 connector with pins 2 and 3 soldered across. I had to get the Z500's CDMA drivers from the Samsung UK website - you will probably have to register before being allowed to the download page in this link. The Qualcomm link in Minorka's post worked well, as did a quick search on eMule, again that someone else on this thread suggested. An excellent posting - a golden find on here |
10-27-2006, 10:54 | #202 (permalink) | |
Junior Member Join Date: Oct 2006
Member: 379130 Status: Offline Thanks Meter: 0 | Quote:
please i need the different software we must use to unlocked and unfreezed my phone. i have a sgh z140v. the links give in the forum doesn't work. thanks for your help. you can send their at this mail. [email protected] | |
11-28-2006, 23:21 | #208 (permalink) |
Junior Member Join Date: May 2006
Member: 275203 Status: Offline Thanks Meter: 0 | Followed all the instructions but say "read master control lock fail" The phone is z140v on vodaphone SpainTried some codes from other posts but now phone is frozen.I used lg8120 cable is this the problem.Please help as need to correct this phone and unlock it. |
12-01-2006, 14:59 | #209 (permalink) |
Junior Member Join Date: Dec 2006
Member: 402832 Status: Offline Thanks Meter: 0 | this method worked for me used jumper on the pins used a samsung usb cable and the Qualcomm Unlocker and 20050804143823625_CDMA_Driver this was for my samsung sgh-z140v which was freezing and also unlocked it at the same time, now works with orange and 02 sims. phone was on vodafone uk , once had right cable and pluggedoin jumper to pins at back cable worked fine. |
Samsung Qualcomm tool 4.1 release! Direct unlock and repair IMEI all MSL2 phones!!! | mk | Z3X-Team Products | 34 | 12-26-2008 18:19 |
please Mr.Elco support unlock and flash for samsung A727 ASAP | tsarkh | NSPRO | 2 | 06-26-2008 10:20 |
Free unlocker and flasher for samsung D600 | jignesh_1000 | Samsung Flashers, Software, Firmware. | 20 | 03-30-2007 08:35 |
Cruiser doubt... does unlocking and/or changing language erases memory? | UnlockBR | Cruiser Suite | 9 | 12-29-2004 18:40 |
