Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Samsung > QUALCOMM Models (3G)
QUALCOMM Models (3G) SGH-Z105x, SGH-Z107x, Z110, Z130, Z140, Z300, Z320i, Z500, Z510, ZM60, ZV10, ZV30, ZX10.
Old 12-09-2006, 06:36   #211 (permalink)
Member: 100450
pl, unlock soft for Samsung Z 560...
Old 12-11-2006, 13:30   #212 (permalink)
Member: 243687
i have z500v from vodafone uk. plz anybody tell the proper way to unlock
this. which software and cable is used.
thanx
Old 12-14-2006, 14:27   #213 (permalink)
Member: 401002
Thanks Meter: 1,045
There is new update for all this models and more.
You can check it in http://www.easy-unlocker.net
Old 12-14-2006, 16:36   #214 (permalink)
ZoHaiB_(FoneGSM)'s Avatar
Member: 82666
Sonork: 100.108210
Thanks Meter: 283
any solution for Z400 Freezing problem
Old 12-14-2006, 18:23   #215 (permalink)
Member: 401002
Thanks Meter: 1,045
@infozohaib con Easy Unlocker box you can unlock and unfreeze.
Regards!
Old 12-15-2006, 10:59   #216 (permalink)
aErOm's Avatar
Member: 7900
Sonork: 100.78126
Thanks Meter: 4,990
Hello to all Users in trouble with NEW SAMSUNG 3G phones, please take a look at EASY UNLOCKER section in this forum, this box have the full features you need for the Samsung 3G models and some more brands.
Here you have some screenshot results of the box test:
Some Screenshots of tested phones
and here are full features:
Easy Unlocker Full Features at 12/14/2006
Best Regards too all and Enjoy !
Old 12-17-2006, 11:15   #217 (permalink)
Member: 212350
Unhappy e398 lcd blank
i change lcd but is also blank..........
Old 01-09-2007, 11:50   #218 (permalink)
imran tec's Avatar
Member: 135718
Thanks Meter: 5
hey experts can i unlock zv40 wid this way reply hurry
Old 01-10-2007, 19:51   #219 (permalink)
Member: 56884
Zv40
Pls...
Zv40 Unfreeze Software Help...
Old 01-12-2007, 09:57   #220 (permalink)
Member: 169579
Thanks Meter: 10
Originally Posted by Jass2mail View Post
dear use lg 3g cable it will work on z500 100% tested..................
work with which software?
Old 03-03-2007, 14:54   #221 (permalink)
phone_abuser's Avatar
Member: 58817
How to unfreeze Z107v using LG3 usb cable(U8130) or santel 18in1 cables??
tried LG3G cable but XP doesnt find any new hardware...
Old 04-27-2007, 23:18   #222 (permalink)
Member: 497156
No COM port on my laptop
Hi, I have a SGH-Z300, I did all the procedures as suggested... the fact is that I don't have the COM port on my mobile PC... Anyway, this shall be the suggested procedure and what I did....
__________________________________________________ ___________
To unlock and/or unfreeze these phones you must follow the next steps:
- Download and install QUALCOMM UNLOCKER ( done! When running the program, at first a message box says: "cannot find COM1...").
- Install the propper USB drivers for your mobile ( done!)
- Have the proper USB cable for your mobile (if it comes with one, it's that one that you should use).
- After having your phone correctly connected to your computer (using the USB cable) and turned ON (with or without the SIM inserted), set the mobile modem COM port as one between port 2 to port 9 (ports 2 and 9 included). ( done!) [Note]
- Connect (with something like a metallic wire for example) the 2nd and 3rd pins of the COM1 port (behind your computer), like the example below (imagine it like a COM - 9 pinned - port):
…………………………………………... ______
'…………………………………………... ŻŻŻŻŻ
( I don't have the COM port on the PC!!! Just USB!)
- Before attempting to unlock your mobile (though everything looks OK), click on the "Read Settings" to be completely sure that the program is completely detecting your mobilephone and to make it able to unlock it (by reading the phone's internal codes).
- After all the previous steps... Press UNLOCK. It will remove all the phone locks and the phone freeze (if needed).
[Note]: To set the COM port, run the QUALCOMM UNLOCKER program and click on "Check Modem", then, in the "Phone and Modem Options" menu, click on the "Modem" tab, select your mobilephone on the modem list and then click proprieties. In the modem proprieties menu, you must click on the "Advanced" tab and then click on "Advanced Port Settings". In the "Advanced Port Settings menu, there should be a dropdown list, in the bottom of the window, to select the desired COM port for your mobile. The port must not have 2 digits - like COM10 or above - and it's not convenient to be set as COM1. Select one of the unused and confirm everything by clicking all "OK" buttons.
__________________________________________________ _____________
Anyway, final message from the Qualcomm software is: SERIAL COM = NG"
Can somebody help me please?
Old 04-29-2007, 06:24   #223 (permalink)
Member: 140808
Thanks Meter: 2
I had the same problem, could not use laptop without serial com port, had to use my desktop pc. The program will not work unless you have the serial port pins bridged.
Old 04-30-2007, 19:02   #224 (permalink)
Member: 79592
Exclamation
Help please!
My Z560 shows "phone freeze", how do I unfreeze it?
Thanks.
Old 04-30-2007, 22:24   #225 (permalink)
Member: 79592
Oops, sorry, double post, this one can be deleted.
Samsung Qualcomm tool 4.1 release! Direct unlock and repair IMEI all MSL2 phones!!! mk Z3X-Team Products 34 12-26-2008 17:19
please Mr.Elco support unlock and flash for samsung A727 ASAP tsarkh NSPRO 2 06-26-2008 10:20
Free unlocker and flasher for samsung D600 jignesh_1000 Samsung Flashers, Software, Firmware. 20 03-30-2007 08:35
Cruiser doubt... does unlocking and/or changing language erases memory? UnlockBR Cruiser Suite 9 12-29-2004 17:40
Page generated in 0.46004 seconds with 9 queries
