Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Samsung > QUALCOMM Models (3G)
QUALCOMM Models (3G) SGH-Z105x, SGH-Z107x, Z110, Z130, Z140, Z300, Z320i, Z500, Z510, ZM60, ZV10, ZV30, ZX10.
Old 05-03-2007, 17:50   #226 (permalink)
ringtons's Avatar
Member: 97600
Thanks Meter: 97
Originally Posted by sajid_acm View Post
i have z500v from vodafone uk. plz anybody tell the proper way to unlock
this. which software and cable is used.
thanx
use usb cable that comes with phone connect phone and it should switch itself on you need top install drivers if you have not already done that then check the comport in control panel modems
then run this program and make sure you select the same com port
http://www.iwant1.pwp.blueyonder.co.uk/sam.exe
Old 05-06-2007, 18:36   #227 (permalink)
Member: 500210
Originally Posted by sparkiepete View Post
used this and cleared phone freeze and unlocked phone works on all simms
I tried and cant get it to work with my z140v, how did you do it?
Old 06-02-2007, 06:43   #228 (permalink)
Member: 67927
Thanks Meter: 108
Would this work on a707?
Old 06-02-2007, 06:59   #229 (permalink)
yashtel's Avatar
Member: 170589
Thanks Meter: 1,848
thanks but how to run this software
Old 08-07-2007, 12:00   #230 (permalink)
Member: 560346
whats about z510... somebody could help with these phone.
thnks
Old 08-25-2007, 04:17   #231 (permalink)
Member: 272034
Thanks Meter: 8
zx20 is not suppoted???
do u have a solution for zx20 phonefreeze???plz help me....
thankz...
BR,
Old 08-27-2007, 13:54   #232 (permalink)
Member: 4842
MERCI MON FRERE
Old 08-27-2007, 22:37   #233 (permalink)
damabib's Avatar
Member: 106026
Sonork: 100.77890
Thanks Meter: 127
Will Try And Post If Can Work With Zv10 Frreesed
Old 08-31-2007, 02:30   #234 (permalink)
Member: 573614
Unhappy
Originally Posted by -minorKa- View Post
This is a post to help everyone that has a Samsung Z serie mobile that is locked and/or freezed.
The explanation for how to do is already on this forum but to make it easier for everyone to find it, I'm making my 1 for all (Z series phones) post.
The supported phones for this process are (the Z series phones):
(as listed in the program)
SGH-Z140
SGH-Z140V
SGH-Z300
SGH-Z300M
SGH-Z500
SGH-Z500V
SGH-ZM60
SGH-ZV30
SGH-ZX10
To unlock and/or unfreeze these phones you must follow the next steps:
- Download and install QUALCOMM UNLOCKER (http://www.megaupload.com/?d=39RITNDZ)
- Install the propper USB drivers for your mobile (if it comes with CD, if that CD has the USB drivers, it's those ones that you should use, otherwise, download: http://org.downloadcenter.samsung.com/downloadfile/ContentsFile.aspx?CDSite=HQ&CttFileID=380589&CDCtt Type=SW&ModelType=N&ModelName=SGH-Z500&VPath=SW/200505/20050526174209031_USBDriver.exe).
- Have the proper USB cable for your mobile (if it comes with one, it's that one that you should use).
- After having your phone correctly connected to your computer (using the USB cable) and turned ON (with or without the SIM inserted), set the mobile modem COM port as one between port 2 to port 9 (ports 2 and 9 included). [Note]
- Connect (with something like a metallic wire for example) the 2nd and 3rd pins of the COM1 port (behind your computer), like the example below (imagine it like a COM - 9 pinned - port):
…………………………………………... ______
'…………………………………………... ŻŻŻŻŻ
- Before attempting to unlock your mobile (though everything looks OK), click on the "Read Settings" to be completely sure that the program is completely detecting your mobilephone and to make it able to unlock it (by reading the phone's internal codes).
- After all the previous steps... Press UNLOCK. It will remove all the phone locks and the phone freeze (if needed).
[Note]: To set the COM port, run the QUALCOMM UNLOCKER program and click on "Check Modem", then, in the "Phone and Modem Options" menu, click on the "Modem" tab, select your mobilephone on the modem list and then click proprieties. In the modem proprieties menu, you must click on the "Advanced" tab and then click on "Advanced Port Settings". In the "Advanced Port Settings menu, there should be a dropdown list, in the bottom of the window, to select the desired COM port for your mobile. The port must not have 2 digits - like COM10 or above - and it's not convenient to be set as COM1. Select one of the unused and confirm everything by clicking all "OK" buttons.
Then you'll have your phone completely free of lockings and freezings. I did it with my own Z300 and, after doing it just like I described, it finally worked.
Hope this thread was usefull and enjoy your phones without restrictions.
hey!!!
i just got this major problem that is that the phone is only detected for some seconds, I switch in the usb, everything ok, but after the messages of confirmation, it simply disconnects. but it continues active in the com port. i just don't now what else to do, already reinstalled the phone drives, changed the com port, from 2 to 5 and 5 to 2, different usb (all 6) and it continues shooting down the usb ports, only by rebooting the pc they accept the phone again, but only for some sec...
Old 09-01-2007, 12:47   #235 (permalink)
Member: 549349
hello,
http://org.downloadcenter.samsung.co...USBDriver.exe
The page cannot be found
need help please and thanks a lot.
Old 09-06-2007, 12:05   #236 (permalink)
Member: 110065
Thanks Meter: 25
Thx, gr8 soft. It worked for me first time round.
Old 09-08-2007, 10:15   #237 (permalink)
Member: 582013
I have z560 and usb cabLe but i dont have modem.Can some1 teLL me how to unlock my phone using just usb and to teLL me some program that have unlock codes.
PLs heLp
thx
Old 09-08-2007, 12:08   #238 (permalink)
Member: 485983
Thanks Meter: 25
How To Unlock Z400?!
Old 09-14-2007, 13:07   #239 (permalink)
Member: 585148
z140
hi is there any way of unlocking a z140 with just codes cheers
Old 10-01-2007, 09:54   #240 (permalink)
FNV
Member: 599643
SGH-Z140
SGH-Z140V
SGH-Z300
SGH-Z300M
SGH-Z500
SGH-Z500V
SGH-ZM60
SGH-ZV30
SGH-ZX10
- Install the propper USB drivers for your mobile (if it comes with CD, if that CD has the USB drivers, it's those ones that you should use, otherwise, download: http://org.downloadcenter.samsung.co...USBDriver.exe).
I have a sgh Z140
when i click on "Read Settings", on the right say "fail" and on the left say "serial COM. -NG" what could I do wrong?
(sorry for my english. I'm Portuguese)
Samsung Qualcomm tool 4.1 release! Direct unlock and repair IMEI all MSL2 phones!!! mk Z3X-Team Products 34 12-26-2008 18:19
please Mr.Elco support unlock and flash for samsung A727 ASAP tsarkh NSPRO 2 06-26-2008 10:20
Free unlocker and flasher for samsung D600 jignesh_1000 Samsung Flashers, Software, Firmware. 20 03-30-2007 08:35
Cruiser doubt... does unlocking and/or changing language erases memory? UnlockBR Cruiser Suite 9 12-29-2004 18:40
Page generated in 0.30402 seconds with 10 queries
