Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Samsung > QUALCOMM Models (3G)
QUALCOMM Models (3G) SGH-Z105x, SGH-Z107x, Z110, Z130, Z140, Z300, Z320i, Z500, Z510, ZM60, ZV10, ZV30, ZX10.
Old 02-01-2006, 13:47   #91 (permalink)
Member: 117836
her is solution to unlock samsung zv10 under xp with Qualcomm Unlocker
1-use lg 3g data cable (ringtone usb cable)
2-install usb driver
3-run the program after forcing to run under windows 98
4-select zx10 and correct usb port and com
5-read phone info
6-press unlock
thats all
Old 02-02-2006, 11:44   #92 (permalink)
Member: 79221
Thanks Meter: 8
Hello!
I have a samsung Z 140 with SFR operator.
I would'like dl the program for unlock this model but I can't find a good link.
I can use LG 3g cable but I have'nt the program:
"QUALCOMM UNLOCKER" or "SAMSUNG CODE READER"
Have you a good link please.
Thanks
Old 02-03-2006, 02:12   #93 (permalink)
mickle1's Avatar
Member: 228253
Thanks Meter: 19
The Codes From Bmobile Unlocked My Z500
Old 02-03-2006, 15:59   #94 (permalink)
Member: 208325
Thanks Meter: 3
thank you minorka for the unlocking idea of the samsung z 140
it works 100% no defeculties and like you said for every one on the forum
you must use the data cable that comes with the fone otherwise it won't work thanks again minorka
Old 02-04-2006, 16:35   #95 (permalink)
Member: 228984
Unlock Samsung Z105
Hi! Doe´s anywone have the lock up code to a Samsung Z105 .
When i turn on the fhone it says PHONE FREEZ .Is it possible to lock up the phone?
Help me .
Old 02-04-2006, 19:42   #96 (permalink)
Tetouan Gsm's Avatar
Member: 190492
Sonork: 100.01010100
Thanks Meter: 187
USB cable samsung c100 can read code Z105...? anyone test it with Samsung_Z105_Z107_Z300_Code_Reader_2_0_2 ..program ?
Old 02-06-2006, 13:07   #97 (permalink)
Member: 228984
Succsese!I have locked upp my Z105 with help of -minorka- program.I used same program as to Z140.Now i can use my phone as i wont.
Thank you -minorka-
Old 02-12-2006, 15:21   #98 (permalink)
Member: 57534
z500
thanks minorka your help was great i have just un frozen my phone and unlocked it to boot good job
Old 02-12-2006, 16:08   #99 (permalink)
gsm3005's Avatar
Member: 120740
Thanks Meter: 3
good work keep it up
Old 02-14-2006, 17:49   #100 (permalink)
Member: 141164
Thanks Meter: 36
Originally Posted by -minorKa-
This is a post to help everyone that has a Samsung Z serie mobile that is locked and/or freezed.
The explanation for how to do is already on this forum but to make it easier for everyone to find it, I'm making my 1 for all (Z series phones) post.
The supported phones for this process are (the Z series phones):
(as listed in the program)
SGH-Z140
SGH-Z140V
SGH-Z300
SGH-Z300M
SGH-Z500
SGH-Z500V
SGH-ZM60
SGH-ZV30
SGH-ZX10
To unlock and/or unfreeze these phones you must follow the next steps:
- Download and install QUALCOMM UNLOCKER (http://www.megaupload.com/?d=39RITNDZ)
- Install the propper USB drivers for your mobile (if it comes with CD, if that CD has the USB drivers, it's those ones that you should use, otherwise, download: http://org.downloadcenter.samsung.co...USBDriver.exe).
- Have the proper USB cable for your mobile (if it comes with one, it's that one that you should use).
- After having your phone correctly connected to your computer (using the USB cable) and turned ON (with or without the SIM inserted), set the mobile modem COM port as one between port 2 to port 9 (ports 2 and 9 included). [Note]
- Connect (with something like a metallic wire for example) the 2nd and 3rd pins of the COM1 port (behind your computer), like the example below (imagine it like a COM - 9 pinned - port):
…………………………………………... ______
- Before attempting to unlock your mobile (though everything looks OK), click on the "Read Settings" to be completely sure that the program is completely detecting your mobilephone and to make it able to unlock it (by reading the phone's internal codes).
- After all the previous steps... Press UNLOCK. It will remove all the phone locks and the phone freeze (if needed).
[Note]: To set the COM port, run the QUALCOMM UNLOCKER program and click on "Check Modem", then, in the "Phone and Modem Options" menu, click on the "Modem" tab, select your mobilephone on the modem list and then click proprieties. In the modem proprieties menu, you must click on the "Advanced" tab and then click on "Advanced Port Settings". In the "Advanced Port Settings menu, there should be a dropdown list, in the bottom of the window, to select the desired COM port for your mobile. The port must not have 2 digits - like COM10 or above - and it's not convenient to be set as COM1. Select one of the unused and confirm everything by clicking all "OK" buttons.
Then you'll have your phone completely free of lockings and freezings. I did it with my own Z300 and, after doing it just like I described, it finally worked.
Hope this thread was usefull and enjoy your phones without restrictions.
Thanks FOR All ur effort regarding this mater i Followed ur instrution and its work for me 100%.Thank so much for help budy ur a good man like all those guys who help this forum.
Old 02-15-2006, 17:28   #101 (permalink)
Member: 220143
Thanks Meter: 103
Unlocked z105
I have a Z105 that was unlocked using NSdongle. It was unlocked sucessfully but phone could not make any calls. I was told by elco to flash the phone . Can this program be used to do so.
PS I have used QUALCOMM UNLOCKER to unlock it again and now the phone menu moves slower (like sony ericsson slow) and the phone still cant make calls. There was no z105 in the model option so I used Z140.
Please Elco or any one can you help ???
Old 02-15-2006, 19:39   #102 (permalink)
Member: 232995
Exclamation
I have ZM 60.I can not use BT.
HOW to set BD address?
Old 02-15-2006, 22:53   #103 (permalink)
Member: 233423
Z500 Dutch branded!
It workt for me perfectly!
But!...
You have to make sure that you something connect to the 2 pins something like a coper wire from a bike-light or something :S, it works!
And also the problem was on my path, that he didn't accept the unlock if i put the sim in the phone, so maybe you have to make sure the sim is out, before you do the "unlock thing" or "read setting"
Restart the program and phone and it shall work!
i got an PASS on everyting!
Thanks to the TopicStarter, now i can spend 15 euro's (EXTRA) on bear in the weekend!!!!!
On the rest:
Don't Give UP!!!!!, that was my succes!
Old 02-16-2006, 19:32   #104 (permalink)
Member: 232995
Arrow ZM60 boot animation change
Is it posseble to change boot animation?
For example: instead of T-Mobile other animation.
I have ZM60. Thanks.
Old 02-27-2006, 14:56   #105 (permalink)
Member: 237923
And with The SGH-Z107 it's work perfectly ????????????
Samsung Qualcomm tool 4.1 release! Direct unlock and repair IMEI all MSL2 phones!!! mk Z3X-Team Products 34 12-26-2008 18:19
please Mr.Elco support unlock and flash for samsung A727 ASAP tsarkh NSPRO 2 06-26-2008 11:20
Free unlocker and flasher for samsung D600 jignesh_1000 Samsung Flashers, Software, Firmware. 20 03-30-2007 09:35
Cruiser doubt... does unlocking and/or changing language erases memory? UnlockBR Cruiser Suite 9 12-29-2004 18:40
Page generated in 0.48779 seconds with 9 queries
