Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Samsung > QUALCOMM Models (3G)
QUALCOMM Models (3G) SGH-Z105x, SGH-Z107x, Z110, Z130, Z140, Z300, Z320i, Z500, Z510, ZM60, ZV10, ZV30, ZX10.
Old 02-28-2006, 01:23   #106 (permalink)
jusluke's Avatar
Member: 26867
Thanks Meter: 3
this solutions works perfect for qualcomm 3G phones, if problem finding prog you can also try searching winimei for certain models yesterday unlocked z140v with winimei z140v 100% working with this procedure...
Old 03-04-2006, 16:42   #107 (permalink)
Member: 238923
Smile Z 140V unblocked and unfreezed thanks Minorka
My Z140 V on French SFR was blocked then on SFR (I want to use Orange) then freezed when I tried some numbers (#xxxx* etc..) found on the web to unblock it (after 3 times it was freezed).
proredure run very well (11 s!) with QualcomUnlocker and the strap on the PC Com plug.
Thanks a lot, one week I was hesitating on the different solutions I found on the web
Old 03-04-2006, 17:02   #108 (permalink)
shami's Avatar
Member: 158181
Thanks Meter: 74
yes
it works perfect
Old 03-09-2006, 15:35   #109 (permalink)
Member: 241519
Unhappy Z500v
Originally Posted by -minorKa-
This is a post to help everyone that has a Samsung Z serie mobile that is locked and/or freezed.
The explanation for how to do is already on this forum but to make it easier for everyone to find it, I'm making my 1 for all (Z series phones) post.
The supported phones for this process are (the Z series phones):
(as listed in the program)
SGH-Z140
SGH-Z140V
SGH-Z300
SGH-Z300M
SGH-Z500
SGH-Z500V
SGH-ZM60
SGH-ZV30
SGH-ZX10
To unlock and/or unfreeze these phones you must follow the next steps:
- Download and install QUALCOMM UNLOCKER (http://www.megaupload.com/?d=39RITNDZ)
- Install the propper USB drivers for your mobile (if it comes with CD, if that CD has the USB drivers, it's those ones that you should use, otherwise, download: http://org.downloadcenter.samsung.co...USBDriver.exe).
- Have the proper USB cable for your mobile (if it comes with one, it's that one that you should use).
- After having your phone correctly connected to your computer (using the USB cable) and turned ON (with or without the SIM inserted), set the mobile modem COM port as one between port 2 to port 9 (ports 2 and 9 included). [Note]
- Connect (with something like a metallic wire for example) the 2nd and 3rd pins of the COM1 port (behind your computer), like the example below (imagine it like a COM - 9 pinned - port):
…………………………………………... ______
'…………………………………………... ŻŻŻŻŻ
- Before attempting to unlock your mobile (though everything looks OK), click on the "Read Settings" to be completely sure that the program is completely detecting your mobilephone and to make it able to unlock it (by reading the phone's internal codes).
- After all the previous steps... Press UNLOCK. It will remove all the phone locks and the phone freeze (if needed).
[Note]: To set the COM port, run the QUALCOMM UNLOCKER program and click on "Check Modem", then, in the "Phone and Modem Options" menu, click on the "Modem" tab, select your mobilephone on the modem list and then click proprieties. In the modem proprieties menu, you must click on the "Advanced" tab and then click on "Advanced Port Settings". In the "Advanced Port Settings menu, there should be a dropdown list, in the bottom of the window, to select the desired COM port for your mobile. The port must not have 2 digits - like COM10 or above - and it's not convenient to be set as COM1. Select one of the unused and confirm everything by clicking all "OK" buttons.
Then you'll have your phone completely free of lockings and freezings. I did it with my own Z300 and, after doing it just like I described, it finally worked.
Hope this thread was usefull and enjoy your phones without restrictions.
Can this be used on windows 98 ?
Old 03-11-2006, 22:41   #110 (permalink)
alru111's Avatar
Member: 45477
Thanks Meter: 22
what cable is used for zx10 and zv10?
Old 03-11-2006, 23:00   #111 (permalink)
Member: 243355
its worked my friend
Old 03-12-2006, 22:52   #112 (permalink)
Member: 243003
how i could unfreeze my z500v
plz help !!!!!!!!!!!!!!!!!!11
thanks
Old 03-14-2006, 08:58   #113 (permalink)
Member: 244008
Thanks Meter: 3
man i gat love for this site thank Bro.
Old 03-15-2006, 02:49   #114 (permalink)
chuckzster's Avatar
Member: 139924
Thanks Meter: 6
thanks
just do a little reading my friend
Old 03-15-2006, 04:11   #115 (permalink)
jerieves's Avatar
Member: 239484
Thanks Meter: 14
when i used lg cable which i used to twisterbox, how could i convert it to usb?
Old 03-15-2006, 20:04   #116 (permalink)
Member: 243003
plz help how i can unfreeze my mobile
[email protected]
thanks
Old 03-15-2006, 22:46   #117 (permalink)
Member: 57534
[email protected]
thanks
SGH-Z140
SGH-Z140V
SGH-Z300
SGH-Z300M
SGH-Z500
SGH-Z500V
SGH-ZM60
SGH-ZV30
SGH-ZX10
- Install the propper USB drivers for your mobile (if it comes with CD, if that CD has the USB drivers, it's those ones that you should use, otherwise, download: http://org.downloadcenter.samsung.co...D=380589&CDCtt Type=SW&ModelType=N&ModelName=SGH-Z500&VPath=SW/200505/20050526174209031_USBDriver.exe).
just follow all the script it works very well i did it ok
Old 03-16-2006, 11:49   #118 (permalink)
jerieves's Avatar
Member: 239484
Thanks Meter: 14
helo brothers, do you have any unlocking codes for my z105 samsung
Old 03-19-2006, 03:50   #119 (permalink)
Member: 243003
hi , well i have 1 samsung z500v but it now its freeze
how i can unfreeze it, i try to install Qualcomm Unlocker but i dont know how i can install it
plzzzz help !!!
thanks
Old 04-06-2006, 00:43   #120 (permalink)
Member: 255682
Great, try it on my ZM60, unlock in seconds. Thank U minorka!!! U r genius. Hope you post more handy stuff like this.
Samsung Qualcomm tool 4.1 release! Direct unlock and repair IMEI all MSL2 phones!!! mk Z3X-Team Products 34 12-26-2008 17:19
please Mr.Elco support unlock and flash for samsung A727 ASAP tsarkh NSPRO 2 06-26-2008 10:20
Free unlocker and flasher for samsung D600 jignesh_1000 Samsung Flashers, Software, Firmware. 20 03-30-2007 08:35
Cruiser doubt... does unlocking and/or changing language erases memory? UnlockBR Cruiser Suite 9 12-29-2004 17:40
Page generated in 0.54218 seconds with 9 queries
