QUALCOMM Models (3G) SGH-Z105x, SGH-Z107x, Z110, Z130, Z140, Z300, Z320i, Z500, Z510, ZM60, ZV10, ZV30, ZX10. |
06-15-2005, 17:07 | #1 (permalink) |
Junior Member Join Date: Jan 2005
Member: 106017 Status: Offline Thanks Meter: 0 | z105 usb cable |
06-16-2005, 14:52 | #3 (permalink) | |
Freak Poster Join Date: Mar 2005
Member: 122814 Status: Offline Thanks Meter: 13 | Quote:
Download: http://org.downloadcenter.samsung.co..._USBDriver.exe | |
06-18-2005, 15:33 | #7 (permalink) | |
Freak Poster Join Date: Dec 2000 Location: Burkina Faso , Bobo Dioulasso Age: 53
Member: 2920 Status: Offline Thanks Meter: 21 | Quote:
-If your computer have a serial port ( for example COM1), take any femal db9 connector , short circuit pin2 and pin3 and connect this "dongle" to COM port. -Connect 105/Z107 with your USB cable ,power on it ,Windows will ask you the drivers , select the folder who contains drivers ( Z105/Z107 use same drivers). - you should have software Winimei Version 1.16(Qualcomm write System) - Be sure you see on screen a symbol of top screen (means you have modem on) -Check Modem port, use the one you says ON USE - In Winimei press Unlock Will also solve freezing problem. Good luck | |
06-20-2005, 18:06 | #8 (permalink) |
Member: 106017 Status: Offline Thanks Meter: 0 | Thanks for the answers but i still can't unlock the phone. I installed some drivers (cdma drivers and the ones lion box gave me above) on winxp, but as soon as i connect the phone to the computer it says it doesn't recognise the usb device that was connected. I've tried several times by reinstalling the drivers but the same happens. Maybe my cable needs some others drivers ( because it's only usb), or maybe the dirvers don't function correctly on xp? By the way, i didn't tried that thing about shorting the pins,but it really doesn't matter for now because the computer doesn't even recognise the phone..... or does it matter? Sorry for the trouble |
06-20-2005, 18:30 | #9 (permalink) |
Freak Poster Join Date: May 2004 Age: 45
Member: 64262 Status: Offline Thanks Meter: 0 | You need original samsung cable or cable with original samsung schematic to unlock z105, cheap *******s using wrong pinout will give you problem and ask for the cable driver and not the phone driver. Once you have right cable search forum for z105 unlock. Once you have software short pins, i think 2/3 or maybe 3/4 on com port and then run win imei and just press unlock. |
i-Pmart BX Series RJ45 + USB Cable Compatible For Samsung Z105 For UST PRO | IPMART | ipmart WebShop | 0 | 03-25-2009 09:10 |
SAMSUNG Z105 USB+COM Pinout | mariocipolla | QUALCOMM Models (3G) | 14 | 01-24-2006 11:38 |
bought unlock usb cable for z105, but can't find comport in device manager | ashvin | QUALCOMM Models (3G) | 1 | 10-31-2005 21:01 |
Wanted----3 Samsung Z105 USB cables | Elco | Wanted Products | 0 | 09-10-2004 11:20 |
