Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Samsung > QUALCOMM Models (3G)
QUALCOMM Models (3G) SGH-Z105x, SGH-Z107x, Z110, Z130, Z140, Z300, Z320i, Z500, Z510, ZM60, ZV10, ZV30, ZX10.
Old 02-26-2009, 13:01   #1 (permalink)
Member: 328688
Thanks Meter: 2,282
How to flash i560
hi just wan know can we flash it i560 with ns pro r any other tool support tht model
Old 02-26-2009, 16:24   #2 (permalink)
Member: 951015
Thanks Meter: 3
try here http://share4gsm.com/forum/index.php?topic=5.0
Old 02-27-2009, 09:45   #3 (permalink)
Member: 328688
Thanks Meter: 2,282
Originally Posted by idkhannes View Post
where flasher r loder can u upload here
Old 03-07-2009, 20:39   #4 (permalink)
::.::RAMJAN::.::'s Avatar
Member: 258172
Thanks Meter: 10,367
Samsung I560 flash/update Instructions
1- Download the program to update the firmware – Apollo
2- Download I560 firmware
3- Download the SS60_Downloader_Driver.zip
4- Turn the phone off and then hold down the 4 and 7 keys on your phone and turn it on, This starts the phone in the “All Download” mode Connect the USB cable from you computer to your mobile and when is asks for a driver use “SS60_Downloader_Driver” that you downloaded. Once it has installed both the phone and PDA drivers, Start the Apollo program and connect the USB cable from you computer to your mobile. A COM port should appear in “No. 1 Modem”. Select the *.bin file by hitting the “Modem Code” button and the *.img file by hitting the “PDA Image” button then hit the “All Download” button to flash your phone. Once the update is complete the phone will reboot. Unplug the USB cable.
br
The Following 12 Users Say Thank You to ::.::RAMJAN::.:: For This Useful Post:
Old 09-16-2009, 11:20   #5 (permalink)
Member: 505446
Thanks Meter: 45
Sir!i had one !560v.it switches on with start up display screen but after couple of moments it just go blank.and cant be switched off from power swtch.so i tried to flash it with appolo according to ur instructions and with the firmware you suggested in given link.flash was done 100%.but phone is just stucked at startup screen.i also tried to use different firmware but problem still persists.
when i press 4+7+p.button phone shows all download,but automatically install the drivers of modem only.And does not detect the pda drivers.But if i press 4+1 then only it detects PDA and i should install them manualy.it was done.
so flashed it in two sessions,
1-PDA download
2-modem download
please let me know the reason of my failuare and the solution.thanks
Old 09-16-2009, 13:18   #6 (permalink)
Member: 505446
Thanks Meter: 45
1-PDA download
2-modem download
Old 09-18-2009, 09:45   #7 (permalink)
Member: 328688
Thanks Meter: 2,282
br
thanx lot to help but i hve this problem wht to do nw*+7 modem download mode dont detect driver
4+7 all download mode driver detected
1+4 pda mode driver detected
Old 09-18-2009, 21:03   #8 (permalink)
sameenshah123's Avatar
Member: 619308
Sonork: 100.1591829
Thanks Meter: 243
try to put phone in modem mode and open apollo and conect i560 with orignal usb and see if its detect port. coz some its happen some time driver alrealy instald and when u conect phone its dont show new hareware found and also dont show in device manger. so try as i said if its dont detect remove and put cable again if its detect thats mean modem prat is ok. and them put pone in all download mode and select file presss all download .
Old 09-19-2009, 06:52   #9 (permalink)
Member: 328688
Thanks Meter: 2,282
brother i try on 3 pc but no luck it show this i can,t see any thing on applo
where fone conected
Old 09-19-2009, 19:45   #10 (permalink)
Member: 619308
Sonork: 100.1591829
Thanks Meter: 243
thats mean phone modem part is dead. u have to fix with jatag or send it to Elco to fix it
Old 09-21-2009, 07:28   #11 (permalink)
Member: 328688
Thanks Meter: 2,282
wht jatag u talking about i hve 1 it only repair old fone new fone is not supporting yet
Old 02-15-2011, 18:00   #12 (permalink)
XHouser's Avatar
Member: 151737
Sonork: 100.1595988
Thanks Meter: 91
link for apollo not Work!
Uoloaded HERE!
Old 03-06-2012, 16:15   #13 (permalink)
Member: 220595
Thanks Meter: 355
Need teh usb drivers for PDA mode
not posted on 4shared, the posted link has died.
Old 03-06-2012, 16:30   #14 (permalink)
Member: 220595
Thanks Meter: 355
Ok new link here:
Apollo-4.21--SS60_Downloader_Driver.rar - 4shared.com - online file sharing and storage - download
Old 03-06-2012, 16:30   #15 (permalink)
Member: 220595
Thanks Meter: 355
Ok new link here:
how to flash a52? fuadgsm E-Gold Based Phones 1 03-29-2010 18:48
How to flash SGH B520.-URGENT- prashantvrm Samsung Flashers, Software, Firmware. 1 03-29-2010 13:24
how to flash e250i adda2004 Samsung Flashers, Software, Firmware. 0 03-29-2010 12:26
how to flash 1st cpu & how to flash 2nd cpu kasim Infinity-Box 4 03-15-2008 11:09
Page generated in 0.26904 seconds with 10 queries
