QUALCOMM Models (3G) SGH-Z105x, SGH-Z107x, Z110, Z130, Z140, Z300, Z320i, Z500, Z510, ZM60, ZV10, ZV30, ZX10. |
08-16-2005, 00:49 | #17 (permalink) |
Junior Member Join Date: Aug 2005 Age: 45
Member: 171136 Status: Offline Thanks Meter: 0 | Hi, ...and for Z300, the process is the same? Can i use the original samsung cable with no complications? Does the IMEI became different after the unlock operation or no? Changes only the firmware. Does anyone know where i can find an unbranded firmware for Portugal? If i want to use the codes that i can easiely find in the forum, the phone became unlocked too but with the operator logos. This operation will change the IMEI? Regards |
08-16-2005, 01:27 | #18 (permalink) | |
Junior Member Join Date: Jun 2005 Age: 40
Member: 156881 Status: Offline Thanks Meter: 0 | Quote:
The procedure should be valid for a Z300 aswell. Successful flash will not change your IMEI. I would recommend you to try http://www.anvi.it/forum/index.php?showtopic=20637 to find an appropriate firmware. Z300MMEG1 or Z300AIEG3 would be a recommended choice but I cannot wouch for how clean the firmware is. Regarding the language it seems like most firmwares contains many languages. But to be sure open the firmware files in a hex editor and search for the text strings. You can use the original cable assuming it's the same kind of cable as a Z500. But it probably is. Using the unlock codes did not change my Z500 IMEI. I cannot wouch for a Z300 yet they should operate the same. Nicon | |
08-23-2005, 23:31 | #20 (permalink) |
Insane Poster Join Date: Dec 2004 Age: 44
Member: 95076 Status: Offline Thanks Meter: 1 | Finally! 100% NON-BRANDED Firmware! Made by RexNet. I do not known italian so i just used babelfish to convert the following text. Z500REX02 Characteristics of this version: 1) Based on the Z500MMEG1; 2) No MIX to firmware used in order to obtain it; 3) disposed Keys like the Z500MMEG1 (Messages/Menu/Phonebook); 4) Size maximum MMS 300KB; 5) adopted a position Profiles cancellabili; 6) Duration of increased battery (+5% compared to Z500AIEG1); 7) Also works with SOME not compatible sims in the Z500AIEG1; 8) Text corrected in "Battery Discharge"; 9) Field increased of -20db regarding the Z500AIEG1; 10) Volume and I listen improves to you regarding the Z500AIEG1; 11) Completely no-brand (after removed the adopted a position logons); 12) Predefined Video and not removable Samsung Images. DOWNLOAD LINK: http://www.savefile.com/files/6172389 or: http://www.rexnet.it/firmware/sgh-z500/z500rex02.zip Last edited by reefer45; 08-24-2005 at 12:16. |
08-24-2005, 19:27 | #25 (permalink) |
Junior Member Join Date: Aug 2005 Location: Portugal
Member: 174009 Status: Offline Thanks Meter: 0 | OK, it works. But only after I apply the codes for unblocking the phone. And I need to repeat this procedure every time I turn off the phone! Can some one help!!??? |
08-25-2005, 20:27 | #29 (permalink) | |
Major Poster Join Date: Jul 2005 Age: 44
Member: 161452 Status: Offline Thanks Meter: 0 | Quote:
Try unlocking it that way, maybe its more permanent. | |
08-26-2005, 00:37 | #30 (permalink) |
Member: 95076 Status: Offline Thanks Meter: 1 | tientje: There is currently no tool that can read/backup your old firmware. Also there is no point to backup your firmware anyway. If something goes wrong so bad you can't flash it again then your backup wont help you, right? And if everything goes ok, or at least ok enough to put the phone in download mode you can flash again with another new firmware, what would you need your old firmware for? If you are so concerned i suggest you do not flash at all. Leave it for upgrade at an authorized samsung service spot. |
Is there a complete newbie guide anywhere? Trying to unlock a W350i. | OM2 | Cruiser Suite | 5 | 08-17-2008 21:52 |
nokia complete repair guide | ahamed imran | Nokia Hardware & Hardware Repair | 0 | 08-04-2008 12:15 |
[z500] Complete FLASH guide | Nicon | QUALCOMM Models (3G) | 2 | 08-12-2005 19:47 |
What happened to the Z500 complete unlock solution thread? | reefer45 | QUALCOMM Models (3G) | 3 | 08-04-2005 21:43 |
Samsung SGH-Z500 complete unlock solution | reefer45 | QUALCOMM Models (3G) | 92 | 07-29-2005 23:25 |
