QUALCOMM Models (3G) SGH-Z105x, SGH-Z107x, Z110, Z130, Z140, Z300, Z320i, Z500, Z510, ZM60, ZV10, ZV30, ZX10. |
12-14-2005, 10:13 | #61 (permalink) |
Major Poster Join Date: Dec 2004 Age: 46
Member: 95133 Status: Offline Thanks Meter: 0 | please email me to [email protected] thanks |
12-19-2005, 21:47 | #62 (permalink) |
Insane Poster Join Date: Jun 2005 Age: 38
Member: 151397 Status: Offline Thanks Meter: 0 | z140v spanish Vodafone flashed with Z140DTEK4 ok i flashed successfuly the pohone it works with no probz :P (i forgot to make back up,but no probz,dont forget urs!) but im wondering can i edit the FW ? |
12-21-2005, 19:14 | #63 (permalink) | |
Junior Member Join Date: Nov 2005
Member: 203898 Status: Offline Thanks Meter: 0 | Quote:
Witch Firmware do you need?!! | |
01-18-2006, 12:44 | #64 (permalink) |
Junior Member Join Date: Jan 2006
Member: 222337 Status: Offline Thanks Meter: 0 | Hi all, I came across these forums when looking to debrand my Z500. I have only had it for one week and have unlocked it so I can use TESCO mobile (they are cheap). Will the USB cable that came with the phone be able to be used to flash it? I am quite new to the "phones scene" but have been reading up. A lot of the links seem to be dead and I was hoping somebody could email me a firmware and the files needed to update my phone. I would like the phone debranded really, so I can get rid of the stupid voda logo's. Thanks My email is [email protected], I will host any files I am sent for other people to download. Also, I have tried looking at http://www.samsungseriez.com but I cant understand the language Thanks |
01-20-2006, 13:31 | #65 (permalink) | |
01-26-2006, 22:04 | #67 (permalink) |
Junior Member Join Date: Aug 2005 Age: 44
Member: 167653 Status: Offline Thanks Meter: 0 | So. What's the newest firmware for a Z500 nowadays ? =) the latest one i flashed was the Z500REX02 and that works like a charm =) Though i've always wondered if there weren't meant to be some themeing capabilities in the software for this phone. Any ideas about this ? Thanks ! |
01-30-2006, 22:54 | #68 (permalink) | |
02-17-2006, 02:40 | #70 (permalink) |
Member: 222337 Status: Offline Thanks Meter: 0 | I manage to flash my phone now i have another problem, it asks me to set bluetooth device address when i activate bluetooth, can anyone tell me how to fix this as I have lost my bluetooth now and would really like back. Thanks |
02-20-2006, 09:58 | #71 (permalink) | |
P.S. Please note that some of these codes mite not work on your phone due to there for use with all samsung phone models !!! ("Different phones use different codes") By the way if your reading this "alireza13165" Great job!!! All Samsung Phone Codes!!!! I´ve type here all samsung unlock and options codes ! *2767*688# = Unlocking Code *#8999*8378# = All in one Code *#4777*8665# = GPSR Tool *#8999*523# = LCD Brightness *#8999*3825523# = External Display *#8999*377# = Errors #*5737425# = JAVA Something{I choose 2 and it chrashed}][/b] *#2255# = Call List #*536961# = Java Status Code #*536962# = Java Status Code #*536963# = Java Status Code #*53696# = Java Status Code #*1200# = AFC DAC Val #*1300# = IMEI #*1400# = IMSI #*2562# = ??? White for 15 secs than restarts. #*2565# = Check Blocking #*3353# = Check Code #*3837# = ??? White for 15 secs than restarts. #*3849# = ??? White for 15 secs than restarts. #*3851# = ??? White for 15 secs than restarts. #*3876# = ??? White for 15 secs than restarts. #*7222# = Operation Typ (Class C GSM) #*7224# = I Got !! ERROR !! #*7252# = Oparation Typ (Class B GPRS) #*7271# = Multi Slot (Class 1 GPRS) #*7274# = Multi Slot (Class 4 GPRS) #*7276# = Dunno #*7337# = EEPROM Reset (Unlock and Resets Wap Settings) #*2787# = CRTP ON/OFF #*3737# = L1 Dbg data #*5133# = L1 Dbg data #*7288# = GPRS Attached #*7287# = GPRS Detached #*7666# = SrCell Data #*7693# = Sleep Act/DeAct (Enable or Disable the Black screen after doing nothing for a while) #*7284# = Class : B,C or GPRS #*2256# = Calibration Info #*2286# = Battery Data #*2527# = GPRS Switching (set to: class 4, class 8, class 9 or class 10) #*2679# = Copycat feature (Activate or Deactivate) #*3940# = External loop test 9600 bps #*4263# = Handsfree mode (Activate or Deactivate) #*4700# = Half Rate (Activate or Deactivate) #*7352# = BVMC Reg value #*8462# = Sleeptime #*2558# = Time ON #*3370# = EFR (Activate or Deactivate) #*3941# = External looptest 115200 bps #*5176# = L1 Sleep #*7462# = SIM phase #*7983# = Voltage/Frequenci (Activate or Deactivate) #*7986# = Voltage (Activate or Deactivate) #*8466# = Old time #*2255# = Call ??? #*5187# = L1C2G trace (Activate or Deactivate) #*5376# = ??? White for 15 secs than restarts. #*6837# = Official Software Version #*7524# = KCGPRS #*7562# = LOCI GPRS #*7638# = RLC allways open ended TBF (Activate or Deactivate) #*7632# = Sleep mode Debug #*7673# = Sleep mode RESET #*2337# = Permanent Registration Beep #*2474# = ??? #*2834# = Audio Path #*3270# = DCS support (Activate or Deactivate) #*3282# = Data (Activate or Deactivate) #*3476# = EGSM (Activate or Deactivate) #*3676# = Flash volume formated #*4760# = GSM (Activate or Deactivate) #*4864# = Dunno doesn't work on newer versions #*5171# = L1P1 #*5172# = L1P2 #*5173# = L1P3 #*7326# = Accessory (I got Vibrator) #*7683# = Sleep variable (8) #*7762# = SMS Brearer CS (Activate or Deactivate) #*8465# = Time in L1 #*9795# = wtls key #*2252# = Current CAL #*2836# = AVDDSS Management (Activate or Deactivate) #*3877# = Dump of SPY trace #*7728# = RSAV done# (Everything went to standart but nothing was deleted) #*2677# = ARM State (None or Full Rate) *#8999*636# = Have no clue what it is, i see 20 lines *#9999# = Software version *#8999*8376263# = HW ver, SW ver and Build Date *#8888# = HW version *#8377466# = Same HW/SW version thing *#7465625# = Check the locks *7465625*638*Code# = Enables Network lock #7465625*638*Code# = Disables Network lock *7465625*782*Code# = Enables Subset lock #7465625*782*Code# = Disables Subset lock *7465625*77*Code# = Enables SP lock #7465625*77*Code# = Disables SP lock *7465625*27*Code# = Enables CP lock #7465625*27*Code# = Disables CP lock *7465625*746*Code# = Enables SIM lock #7465625*746*Code# = Disables SIM lock *7465625*228# = Activa lock ON #7465625*228# = Activa lock OFF *7465625*28638# = Auto Network lock ON #7465625*28638# = Auto Network lock OFF *7465625*28782# = Auto subset lock ON #7465625*28782# = Auto subset lock OFF *7465625*2877# = Auto SP lock ON #7465625*2877# = Auto SP lock OFF *7465625*2827# = Auto CP lock ON #7465625*2827# = Auto CP lock OFF *7465625*28746# = Auto SIM lock ON #7465625*28746# = Auto SIM lock OFF *2767*3855# = E2P Full Reset *2767*2878# = E2P Custom Reset *2767*927# = E2P Wap Reset *2767*226372# = E2P Camera Reset #*6420# = MIC Off #*6421# = MIC On #*6422# = MIC Data #*6428# = MIC Measurement #*3230# = Trace enable and DCD disable #*3231# = Trace disable and DCD enable #*3232# = Current Mode #7263867# = RAM Dump (On or Off) *2767*49927# = Germany WAP Settings *2767*44927# = UK WAP Settings *2767*31927# = Netherlands WAP Settings *2767*420927# = Czech WAP Settings *2767*43927# = Austria WAP Settings *2767*39927# = Italy WAP Settings *2767*33927# = France WAP Settings *2767*351927# = Portugal WAP Settings *2767*34927# = Spain WAP Settings *2767*46927# = Sweden WAP Settings *2767*380927# = Ukraine WAP Settings *2767*7927# = Russia WAP Settings *2767*30927# = GREECE WAP Settings *2767*73738927# = WAP Settings Reset *2767*49667# = Germany MMS Settings *2767*44667# = UK MMS Settings *2767*31667# = Netherlands MMS Settings *2767*420667# = Czech MMS Settings *2767*43667# = Austria MMS Settings *2767*39667# = Italy MMS Settings *2767*33667# = France MMS Settings *2767*351667# = Portugal MMS Settings *2767*34667# = Spain MMS Settings *2767*46667# = Sweden MMS Settings *2767*380667# = Ukraine MMS Settings *2767*7667#. = Russia MMS Settings *2767*30667# = GREECE MMS Settings *335# = Delete all MMS Messages *663867# = Dump Mm file #*536961# = WAPSAR enable / HTTP disable #*536962# = WAPSAR disable / HTTP enable #*536963# = Serial eable / Others disable #*53696# = Java Download Mode #*5663351# = Wap Model ID [Your Model] #*5663352# = Wap Model ID [SEC-SGHXXXX/1.0] #*566335# = Wap Model ID [SEC-SGHXXXX/1.0] *2767*66335# = Check on which model it is *2767*7100# = SEC-SGHS100/1.0 *2767*8200# = SEC-SGHV200/1.0 *2767*7300# = SEC-SGHS300/1.0 *2767*7650# = Nokia7650/1.0 *2767*2877368# = Reset WAP Model ID to standart Last edited by Mr.compaqnet; 02-22-2006 at 09:03. | |
02-23-2006, 13:16 | #72 (permalink) |
Member: 222337 Status: Offline Thanks Meter: 0 | Thanks for your reply mate, I did never recieve anything via email my email is: dizzyegg (at) gmail (dot) com The problem is when I go to turn bluetooth on it says: "No bluetooth address!!! Set the BD address or it will do the wrong action" This has made the bluetooth worthless, can anyone help? Also I am having trouble with the manager, it wont find my phone. |
Is there a complete newbie guide anywhere? Trying to unlock a W350i. | OM2 | Cruiser Suite | 5 | 08-17-2008 21:52 |
nokia complete repair guide | ahamed imran | Nokia Hardware & Hardware Repair | 0 | 08-04-2008 12:15 |
[z500] Complete FLASH guide | Nicon | QUALCOMM Models (3G) | 2 | 08-12-2005 19:47 |
What happened to the Z500 complete unlock solution thread? | reefer45 | QUALCOMM Models (3G) | 3 | 08-04-2005 21:43 |
Samsung SGH-Z500 complete unlock solution | reefer45 | QUALCOMM Models (3G) | 92 | 07-29-2005 23:25 |
