can anybody show how to load games on samsung L700 hi, just wanted to know if any body has installed java games or any other format of games in samsung L700. br gsmindia |
i m also facing problem to install java games in l700,any working solution for his mobile? REGARDS |
Try this one to install Java games on the Samsung L700 without any software or drivers In the phone Menu select 'Settings' Then select 'Phone settings' Then 'USB settings' And choose 'Ask on connection' Plug the Phone in to the PC with the USB cable On the phone selct 'Media player' On the PC wait until it detects the phone and select 'Open the device to view files' Open the folder 'Phone' You should see the folders: Images, Other files, Sounds, Videos Create a new folder and name it 'Games' Put any game you want to install in that 'Games' folder Two things need to made sure of when copying over the games. Firstly make sure you have the *.jar and *.jad files for each game, if you don't have the *.jad file, you can download a jad creator pretty easily, just type it in Google. Secondly each game has to be in it's own folder, if you just dump all the *.jar and *.jad files directly into the 'Games' folder only the first game installed will work (Poorly too). Unplug the phone Now on the phone dial the code: *#6984125*# Select 'Internals' (Number 4) It will ask for a master key it is: *#9072641*# Select 'Storage settings' (Number 7) Update Java DB (Number 2) Turn the phone off Turn it back on The games should now be installed with no problems, I know it's bit repetitive but this has worked the best for me http://wiki.answers.com/Q/How_can_yo...msung_SGH_L700 |
try to search in google with this words -- L700 install jar |
