Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Nokia > Nokia CDMA
Old 07-05-2009, 04:17   #1 (permalink)
gsmsikar's Avatar
Member: 28004
Sonork: 100.1601142
Thanks Meter: 766
3125 contact service
i have a 3125 which i converted to ruim
but now it is showing only contact service .. please help me ..
MCU SW : V J190V0600.nep 17-09-04 RH-46 (c)NMP
PPM SW : V J190_03w24_23_22.nbr 12-07-2004 R L
Prd.Code: 0516634
Bpr.Code: 0523532
Prod.Sn : M4D658743
HW Vers : 6000
PCI Vers: 0
UEM : 8
UPP : 8512 [2140]
RFIC Ver: DSP400_WAN_03w48_03_UP3
DSP Vers: DSP400_WAN_03w48_03_UP3
LCD Type: SED15G10
ESN : 033-02607336 (2127C8E8)
SPC : 000000
XTKSL : 000000
PDC : NTTJP 123456
[/QUOTE]
Old 07-05-2009, 09:59   #2 (permalink)
shashankmobile's Avatar
Member: 800668
Sonork: 100.1590720
Thanks Meter: 882
write pm and unlock it
here is pm link http://depositfiles.com/files/zd2gv4ubc
Br.
Shashank
The Following User Says Thank You to shashankmobile For This Useful Post:
Old 07-08-2009, 04:44   #3 (permalink)
CakbungA's Avatar
Member: 893849
Thanks Meter: 76
Re-hot cpu................
Old 07-11-2009, 04:51   #4 (permalink)
~AKSingh~'s Avatar
Member: 65063
Thanks Meter: 2,360
no doubt in 99% cases cs in dc4 cdma sets are due to hardware failure
mostly cpu is dry soldered
imagin how old are these pcb
in dry solder case flashing will result in 00000000 esn
so better to do hardware b4 u proceed to flash.
wbr
Old 07-12-2009, 18:39   #5 (permalink)
gsmsikar's Avatar
Member: 28004
Sonork: 100.1601142
Thanks Meter: 766
wbr
sir u r right but in this case the set was working OK before i flashed it , i only wanted to make it RUIM , but after flashing RUIM firmware it now comes to CONTACT SERVICE ..
and u can see that the esn is also not 0000000 after many tried ..
so now what do u say ?
Old 07-12-2009, 20:56   #6 (permalink)
~AKSingh~'s Avatar
Member: 65063
Thanks Meter: 2,360
ok lets start with >
do full factory and ui by mt box
if set remain in same condition its 100% sure its hardware
otherwise 1 more step
use jaf >
press CHK
now Erase Fls
check mark full erase > and proceed
now flash the set with non uim firmware
do all type of factory defaults > now
write this pm
u il find a working ,dailing and connecting operator handset
now simply load ruim nfp and flash it
never ever write pm
hope this time if hardware problem is not there u il find working set
i forget > after ruim flash unlock it by jaf/mt/universal
A D BEST
br
5130 contact service (ANSWERED) vishal123123 MXKEY Nokia Flasher and Unlocker (by Alim Hape) 3 08-10-2011 11:05
nokia 6303c contact service help.............. RABIULSK MXKEY Nokia Flasher and Unlocker (by Alim Hape) 3 04-09-2010 21:18
nokia 6303c contact service help...... RABIULSK Universalbox 5 03-30-2010 11:31
3125 contact service gsmsikar HWK 2 07-05-2009 04:24
3125 contact service vishal123123 Nokia CDMA 4 05-29-2009 07:51
Page generated in 0.34023 seconds with 9 queries
