04-12-2006, 13:24 | #1 (permalink) |
Freak Poster Join Date: Feb 2004 Age: 45
Member: 54900 Status: Offline Thanks Meter: 11 | 6255 restart i have a 6255 handsets when switched on it gets restart as it enters network and after restating again as it enters netwok it gets again switch off. please members your help required. thanks |
04-13-2006, 07:39 | #2 (permalink) | |
Banned Join Date: Nov 2005
Member: 204243 Status: Offline Thanks Meter: 67 | Quote:
04-13-2006, 12:55 | #4 (permalink) | |
Product Supporter Join Date: May 2004 Location: INDIA Age: 55
Member: 65063 Status: Offline Thanks Meter: 2,419 | Quote:
-now flash it with:-TNZ_N100V1700_6255_02_NFP -restore back the saved pm, -if u find any lock,unlock it and it will work 100% wbr aksingh | |
04-14-2006, 01:22 | #6 (permalink) | |
04-20-2006, 01:39 | #8 (permalink) |
Junior Member Join Date: Apr 2006 Age: 44
Member: 257815 Status: Offline Thanks Meter: 2 | Are you using Diego or Phoenix? Either which way, try getting the the product code and then doing an advanced flash in Phoenix, and use the Revive option, putting in the product code you read and picking the flash file you want to use. |
04-22-2006, 07:17 | #9 (permalink) |
Member: 54900 Status: Offline Thanks Meter: 11 | i had flashed the phone with ub box since i had a diffrent version i have solved the problem of non ruim phones aslo just change the phone mode to local mode using ufs or other then connect to deigo, read all information and save it(pri,prl), now flash the phone with non ruim flash file write all data back the phone work fine.. enjoy |
04-28-2006, 09:14 | #10 (permalink) |
Freak Poster Join Date: Apr 2003 Age: 47
Member: 25763 Status: Offline Thanks Meter: 18 | Hello All I have flashed a reliance 6255 handset with restart problem.Now the phone asks "Insert UIM Card". Somebody please help me out. I have read and write the PM also, But the condition remained the same.If possible somebody please upload proper flash file here alongwith procedure with JAF. Thanks & Regards |
04-28-2006, 20:24 | #11 (permalink) | |
UNC_N175V0403_6255_03[1].NFP wbr aksingh | |
04-30-2006, 15:23 | #13 (permalink) | |
Member: 257815 Status: Offline Thanks Meter: 2 | Quote:
That's the easy way to do it. The hard way is saving the PRI off the other phone into an excel file and manually editing the new phone to match the settings. It can be time consuming, I've done it before | |
05-03-2006, 00:31 | #15 (permalink) | |
Try this: http://rapidshare.de/files/8965622/Diego.rar.html Download and install the MSI file, copy the files in the "crack2" part to your windows\system32 directory. It should then let you load Diego and read the settings files. Just don't try to flash with it, it'll kill the phone | |
need help master manole n95-8gb write screen restart | haslyn | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 15 | 03-30-2010 10:56 |
Nokia 6255 Restart Prob. | smartvickey | Nokia CDMA | 33 | 05-27-2009 07:38 |
Nokia 6255 Restart Solution TESTED ON UFS | vikas1 | Nokia CDMA | 5 | 12-14-2006 18:31 |
6255.... restart help me | .::NaNTeC::. | Nokia CDMA | 13 | 10-13-2006 13:55 |
nokia 6255 restart problem | niceguylove | Nokia CDMA | 4 | 05-11-2006 06:03 |
