Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Nokia > Nokia CDMA
Old 04-23-2008, 17:47   #1 (permalink)
gsmpointhrp's Avatar
Member: 416286
Sonork: 100.1622339
Thanks Meter: 749
All CDMA Secert Codes
<<SAMSUNG>>
Samsung sph-n240, n400, a460, a500, etc Nam Programming :
Nam Set: ##Spc
Test Mode: 47*869#1235
Debug Menu: ##33284,ok
Service Menu: Menu+8+0 (#889)
Reset (Life time, Clear Memory, etc): ##786,ok
A-key: ##2539,ok
Label Selection: ##3882,ok
Label(Home, Work, etc) : **523,ok
NGG Setting (Gateway, etc.): ##2769737,ok
Vocoder: ##8626337,ok
CAI Change: ##7738,ok
Enable TTY: ##889,ok
Samsung a530, a610, a620, a660, a670, etc Nam Programming :
Nam Set: Menu, 6, *
Nam Set: ##3238, ok
Nam Set: ##SPC (##000000), ok
Service Menu: Menu, 9, *
Test Mode: 47*68#13580
Samsung X, E, V, S-series (korean models), e250, v420, s350, etc Nam Programming :
Nam Set: 6548#0**4#6
Nam Set: 47*869#08#9
Nam Set: 74153697193
Test Mode: 5809540*45680 (88 - EFS reset)
Debug Menu: Menu(hold 2sec)+0, 6725 or 9720 or 1973 or 0415
Debug Menu: Menu+0(hold 2sec), 6725 or 9720 or 1973 or 0415
Debug Menu: Home(top of keypad)+0, 6725 or 9720 or 1973 or 0415
Samsung sch-411, 611, n105, a100, a300, a2000, etc Nam Programming :
Nam Set: Menu+60
Test Mode: *759#813580
A-key: Menu+0, 25##
External Audio: Menu+0, ####
Debug Menu: Menu+8, 0415 or Spc
Debug Menu: Menu+9, 0415 or Spc
Brief NAM Programing: Menu+40,626 (not all version)
LCD Contrast: Menu+45 (not all version)
SIO Mode: Menu+49
SIO Mode: Menu+69
Samsung N356 (India version) Nam Programming :
Test Mode: Menu, 5, down arrow, *
Test Mode: **00## (in some flashes)
Samsung i700, etc Nam Programming :
Nam Set: Go to start and select "PHONE" from the drop down menu, dial #83587
Samsung i300, etc Nam Programming :
1. Tap on the Phone Icon with stylus
2. Press #907*9#0 ENTER LOCK should appear on screen
3. Enter OTKSL
4. SVC MENU will appear press 1
5. Enter 10 digit MIN and then press SAVE
6. Press SAVE again
7. Press 3 and then press SAVE 6 times
8. Enter the HOME SID and press SAVE once
9. Press END key twice
<<KYOCERA>>
Kyocera 2345, 3035, 5135, 6035, Se47, KX, KE - series, etc Nam Programming :
Nam Set: 111111+Jog Dial(Ok)
Life Timer: ##786,ok
A-key: ##2539,ok
Tips:
On some kyocera handsets the factory service module has not been disabled
and the phone can be programmed without the Spc by inputting:
Nam Set: ##333333 menu (service)
Qualcomm qcp-800 Nam Pogramming :
Nam Set: Menu+3+0+Spc
Field Test: Menu+7+0+Fsc
<<SANYO>>
Sanyo 4900, 5150, 5300, 8100, etc Nam Programming :
Nam Set: ##Spc+Ok+Key Down+Ok
Advanced Setup: ##3282+Ok+Key Down+Ok+Msl
A-key: ##2539+Ok+Key Down+Ok
Version: ##**837+Ok+Key Down+Ok
Debug Menu: ##FSC+Ok+Key Down+Ok
Airtime menu: ##8463+Ok+Key Down+Ok
Change CAI: ##7738+Ok+Key Down+Ok
Vocoder: ##8626337+Ok+Key Down+Ok
Reverse Logistic: ##786+Ok+Key Down+Ok
Set IP Address: ##2769737+Ok+Key Down+Ok
TTY On/Off: ##889+Ok+Key Down+Ok
Ready Link: ##4636+Ok+Key Down+Ok
Browser Init On/Off: ##4682+Ok+Key Down+Ok
Picture Token: ##25327+Ok+Key Down+Ok
Unknown Code: ##5282277+Ok+Key Down+Ok
(SPC=000000, FSC=040793)
Sanyo scp-A011, smp-A017, etc Nam Programming :
Nam Set: F9(3 beep) + 0*72696#767
<<AUDIOVOX / UTSTARCOM>>
Audiovox 4000, 9000, 9100, 9155, 9500, etc Nam Programming :
Power the phone ON and wait until the little light on top goes out, then press:
Nam Set: 289,Fcn, #,1
Service menu: Fcn,0,0, FSC
Power the phone ON and press:
Test Mode: Hold (2,*,Rcl) + Power
Test Mode Commands:
99 - download - flash phone
124 - inam data write
125 - version
126 - get ESN
127 - get SPC
128 - get User lock
129 - is WFTV data write
137 - get FSC code
138 - NPcode (nam program code)
139 - dscode
141 - restart
218 - Read_Addr
000 - is cdma mode
001 - is fm mode
002 - is pcs mode
008 - is reg read addr
020 - is lna_range
Audiovox (Hyundai) cdm-100, 130, 135, 8300, 8500, 8600, 8910, etc Nam Programming :
Nam Set: ##20022002, end
Read user lock: #5625*, end
Port settings: ##7678, end
DM baud rate: ##2283, end
DM mode enable: **1004, end
DS mode enable: **1005, end
Misc. Test: ##27752345, end
S/W Test1: ##27732726, end
S/W Test2: ##2240, end
Debug screen: ##2773, end
Clear MRU: ##6782, end
Rfnu_Contents: ##2250, end
?????: ##1133, end
?????: ##1144, end
P_Rev: ##7738, end
GPS Test: ##4771, end
A-Key: 2538**
SMS Eng: ##767364, end
Battery_adc: ##2768, end
Tests: ##1122, end
Audiovox 8610, 8910, etc Nam programming :
Name Set: ##847446, end, 111111
Audiovox pcx-3500xl Nam Programming :
Nam Set: ##2726+Send+1998+1+Spc+1
Audiovox-107 Nam Programming :
Nam Set: 45680*47*869#1
Audiovox CMP-3 Nam Programming :
Dm Mode: Menu, 6, 6
Audiovox 9950 Nam Programming :
Nam Set: ##3282
Audiovox Z800 (Audiovox 7900, Sharp) Nam Programming :
Nam Set: m + # + envelope key + * + 1
Audiovox Thera (Toshiba 2032) Nam Programming :
Thera Nam Programming User Manual - nam_thera.pdf
Audiovox (UTStarcom) PPC 6600, 6700, etc Nam Programming :
Nam Set: ##SPC + Send
Nam Set: #*#SPC + Send
Nam Set: ##SPC#
DM mode: ##3424 + Send
DM mode: #*#3424 + Send
DM mode: ##3424#
Programming User Manual - programming_instructions.pdf
<<MOTOROLA>>
Motorola 7760, 7860, 2260, 8160, etc Nam Programming :
Nam Set: Fcn,0000000000000, Rcl
Nam Set: 74663#, Fcn, Fcn
Test Mode: Fcn, 00**83786633, Sto
Motorola v60c, v120c etc Nam Programming :
Nam Set: 74663#, Menu, Menu, Spc
Nam Set: Menu, 073887, * (type quickly)
Test Mode: Menu, 073887*, Spc
Debug Mode: ##33284
Force the phone into DIGITAL ONLY mode:
1) ##33284 (Debug)
2) RIGHT Softkey (Next) Twice
3) Down arrow 10 times to "PrefMod"
4) RIGHT Softkey (Change) until you see "DigOnly"
5) LEFT softkey (Exit)
6) MENU then LEFT Softkey return to idle screen
7) ##33284 (The last 4 will not display if you have done it correctly)
Motorola Razr V3C Nam Programming:
Nam Set: 74663 # clr clr
Nam Set: #073887* , then SPC
Motorola Q Nam Programming:
Nam Set: [Send] + 074663 + [Send] + [Send], Selecct NAM#
Motorola t182, c210, etc Nam Programming :
Nam Set: ##298645665, end
Short Nam: ##073887, sto
Debug Menu: ##1111, end
Service Menu: ##2222, end
Sound NS/EC on/off switch: ##1113, end
Motorola v710, v730, v740, ms150, etc Nam Programming :
Nam Set: 8378*# + press 3 times NATE (spc - 071082)
Service Menu: #758353266#646#
Motorola StarTac 2004 Nam Programming :
Nam Set: 5759789*#, press "Rec" button 3 times, (spc - 915037)
Motorola ms200, ms400, ms800, etc Nam Programming :
Nam Set: 5759789*#, press "Camera" button 3 times, (spc - 915037)
Nam Set: 246791538*#, press "Camera" button 3 times, (spc - 915037)
Motorola v6060 Nam Programming :
Nam Set:147*369#456*0#
MOTOROLA TEST MODE :
v60, c120, c331, etc:
1) Turn on the phone. Press MENU 0 7 3 8 8 7 *
2) The phone will require you to "Enter a Security Code", press 000000, OK
3) Scroll down to "Test mode" choose SELECT. Scroll down to "Enable"
choose SELECT. Your phone is now in test mode.
4) Signal strength is the 3_rd number down on the left hand side of the screen.
5) To toggle between regular mode and test mode: Press MODE then
quickly press the BUTTON DIRECTLY TO THE LEFT OF MENU.
6) To turn off the test mode the phone must be in regular mode, then follow
the above sequence and scroll down to where it says "DISABLE" instead of
"ENABLE" and choose select.
<<NOKIA>>
Nokia 3280, 3285, 3580, 3585, 5185, 6185, 8280, etc Nam Programming :
Nam Set: *3001#12345#
Software Version: *#837#
Software Version: *#9999#
Esn Number: *#92772689#
Restart Phone: *#75681#
Restart Phone: *#75682#
Nokia 8887 Nam Programming :
Version: *#0000#
Evrc: *#8378#
Esn/Data/Timer: *#92772689#
SID: *#743#
Nokia 8587 Nam Programming :
Nam Set: *#626#7764726#
A-Key: #8159357022#4579# (26 digits)
A-Key: #8159357022#4547# (20 digits)
Version: *#0000#
Version: *#837#
Vocoder: *#3872#
Change language: Menu 5, 3, 1
Change DM mode: *#7678#
Debug Screen: *#8378#
Debug: *#8380#
Field Test Menu: *#83788#
SPC Unlock, Factory Reset :
Full Factory Reset: *#7370#
Resets all settings including non-user changeable items (like SPC)
NOKIA TEST MODE:
51xx, 61xx, 71xx, 3285, 63xx, etc :
1) Turn on the phone. Press *3001#12345#
2) Scroll up to where it says "Field Test" and choose SELECT
3) Highlight "Enable" and choose OK. Turn the phone off then back on.
4) If the test mode screen does not show up press MENU and scroll
down to "Field Test" choose SELECT. Press 0 1 then choose OK.
5) Lower left or upper left number is the signal strength.
6) To turn off the test mode press MENU and scroll down to where it says
"Field Test" choose SELECT. Press 0 0 and then choose OK.
3360, 6360, etc :
down to "Field Test" choose SELECT. Press 2 1 0 1 then choose OK.
"Field Test" choose SELECT. Press 2 1 0 0 and then choose OK.
<<LG>>
Lg LX,VX-series, VX4400, VX6000, etc Nam Programming :
Nam Set: ##Spc(#)
Nam Set: Menu, 0
Advanced Settings: ##2342(#)
Vocoder: ##8626337,ok(#)
CAI Change: ##7738,ok(#)
Enable TTY: ##889,ok(#)
A-key: ##2539,ok(#)
Reset (Life time, Clear Memory, etc): ##786,ok(#)
lgc-300, etc Nam Programming :
Nam Set: Menu, 9, Spc
A-key: Press "Sto" 3sec, 2539**
lgc-330w, etc Nam Programming :
Nam Set: Menu, 4, 0, Spc
A-key: 2539**
lgc-510, v111, etc Nam Programming :
Nam Set: Menu, 3, 0, Spc
A-key: 2539**
lgc-500, 800w, etc Nam Programming :
Nam Set: Menu, 9 , 0, Spc
Debug Mode: Menu, 7, 0, Fsc
Debug Mode: Menu, 8, 0, Fsc
A-key: 2539**
<<ERICSSON / SONY-ERICSSON>>
SonyEricsson T608, etc Nam Programming :
Nam Set: 923885, joystick >, 111111
Nam Set shot: 987, joystick >, 111111
Nam Set long: 222652, joystick >, 111111
Vocoder: ##8626337, joystick >, 111111
Debug screen: ##33284, joystick >
Life Timer: ##786, joystick >
SW ver: 9#4#3#, joystick >
Edit Profile: ##3282, joystick >
Service menu: *#06*
Ericsson A1228c, T61, etc Nam Programming :
Short NAM: 987+Menu
Long NAM: 923885+Menu+Spc
CDMA Mode: 904093+Menu
Analog Mode: 904095+Menu
QNC: 904097+Menu
Debug Screen: 904090+Menu
DM Mode: 904050+Menu
<<EPSILON / COMPAL>>
Epsilon vc-5x, Compal 1100, etc Nam Programming :
Nam Set:: **321456987##
Short Nam: **147258963##
Service Menu 1: **1232580##
Service Menu 2: **078987##
Service Menu 3: **1234756##
Show SPC: **3214569871472365##
Version: **1470963##
Debug: **000000##
A-key: 2539**
Reset: **14789##
<<SK TELETECH>>
Sky All Models Nam Programming :
Nam Set: #7583538324#626#
Nam Set: *759#364*7388464#
Min simple mode: #758353266#646#
Irm simple mode #758353266#476#
Voice memo: #8767#277#
Test Mode: #7583538324#8378#
A-key: #758353266#2539#
Service Menu: Menu+4+0+Spc
Service Menu: Menu+5+0+Spc
<<WITHUS / MODOTTEL>>
Withus wce-100, 200, 300, etc Nam Programming :
Nam Set: ##948487+Save
Nam Set: ##948482+Save
ESN write: ##66835+Save (wce200 only)
SMS Settings: ##76766
NVM Rebuild: ##777464
<<GTRAN>>
Gtran gcp-2000 Nam Programming :
Nam Set: 01#737+Spc
Debug Menu: 01#324+Spc
Debug Mode: 01#727
Test Mode: 01#764+Spc
System Test Mode: 01#768+Spc
Gtran gcp-5000 Nam Programming :
Debug Mode: 01#727+Spc
Test Mode: 01#765
<<HYUNDAI>>
Hyundai hwp-110 Nam Programming :
Nam Set: #86904**89397#
DM Mode: ##2740*
(Open phone, inter code, close phone)
Hyundai hgc-120, 130, 200 Nam Programming :
Hyundai hgc-310, 600, 610 Nam Programming :
Nam Set: ##20022002, end, 1, Spc Code
Field Test: ##20022002, end, 1, Master Code
Hyundai Curitel h100, 150, hx510b, 520, etc Nam Programming :
A-key: 2539**
Debug Menu: ##27732726, end
Sar Test: ##27752345, end
Baud Rate: ##36**, end
Test Bell/Voice/Led/Dot: ##1122, end
RF Mode: ##2240, end
Ras Ram: ##2774, end
Cmux1: **0481, end
Cmux2: **0482, end
RX Mode Fax: **0492, end
RX Mode Data: **0491, end
RX Mode Reset: **0490, end
<<HUAWEI>>
Huawei ETS-668, 678, 688, etc Nam Programming :
Debug Mode: ##44+Menu
Debug Screen: ##33+Menu
CDG2 Test enable: ##234+Menu
CDG2 Test disable: ##432+Menu
China Lang Select: ##123+Menu
Blocking Debug Code: ###888+Menu
Home System Only On: ##461+Menu
Home System Only Off: ##460+Menu
Master Code for all Huawei models is - 309296
<<PANTECH / CURITEL>>
Pantech hx-525b, 550, 570, 575, etc Nam Programming:
Nam Set: ##13*92*#62* + Pwr
Debug Mode: ##*193*762534#* + Pwr (R-UIM mode disable)
Debug Mode: ##27732726 (R-UIM mode enable)
DM Mode Enable: ***18*#826*
Full Reset: ##03*934#9367*192#397#7412569746 + Pwr
MultiTest: ##22635*262* + Pwr
Cmux1: ***12*#811# + Pwr
Cmux1: ***37*#922* + Pwr
RX Mode Data: ***83*#247 + Pwr
RX Mode Reset: ***64*#133# + Pwr
DS Mode On: ***12045#*# + Pwr
RF NV Init: ##0*#*63861829372# + Pwr
RAS_RAM: ##3*13091#1279#* + Pwr
<<TREO>>
Palm One Treo 600, 650, 700, etc Nam Programming :
Nam Set: ##SPC#
DM mode: ##3424#
Debug: ##33284
Resetting Treo - resetting_treo650.doc
<<AXESSTEL>>
P800, T800, P1900, T1900, etc Nam Programming :
Nam Set: 47*68#47*869#
DM mode: ##9* + Send
Data cable select: menu + 7 + 1 + #
Data Manager: **##11
Data (Internet): **##13
Data USB: **##32
<<VK MOBILE>>
VK-100C, 110C, 200C, etc Nam Programming :
Nam Set: 153147539741593
Test Mode: 153147539123258 (88 - clear efs (set language to korean before))
<<GIGA TELECOM>>
Z510, Z710i(gcd-456) Nam Programming :
Nam Set: Menu+0+Spc
<<AnyDATA>>
AMC450 Nam Programming :
Nam Set: *74269#*748#96148063+SEL
<<ZTE>>
ZTE C150, C160, C170, C180, C220, etc Nam Programming:
Nam Set: *983*3641# (R-UIM mode)
Nam Set: #1463*389*
ZTE C201 Nam Programming:
Nam Set: *983*7358#
<<UBIQUAM>>
U100, U105, U200, U300, etc Nam Programming :
Nam Set: ##3435871
BREW Set Menu: ##8242739
System Test: ##33582
Handset Test: ##3435873
Handset Test: ##3435875
Factory Test Mode: ##3435874
<<SYNERTEK>>
Synertek S200 Nam Programming :
Nam Set: Menu+0+Spc
A-Key: 2539**+Save
Test vibro/rx/tx: ##5555+Save
Debug Screen: ##33+Save
Debug Screen: ##523+Save
RF Test: ####+Save
LCD type: ##325+Save
Synertek S500 Nam Programming :
SAR Test Strife test: *#0000#
Debug screen: *#8378#
Clear LCD: *#848378#
Debug menu: *#443336# (R-UIM mode)
CDG , Service option: *#234#
Function Test, LCD Contrast: *#878#
<<SONY>>
Sony CM-M1300, 3300, Z200 Nam Programming :
Nam Set: 111111+Ok(Jog Dial)+Select+Programming+Ok+Spc
The Following 26 Users Say Thank You to gsmpointhrp For This Useful Post:
Old 04-24-2008, 19:17   #2 (permalink)
Member: 659586
Thanks Meter: 86
thanks to nice share.....
Old 04-28-2008, 12:06   #3 (permalink)
Cheater -Don't Deal with him-
::gsmcoder::'s Avatar
Member: 172434
Sonork: 100.161280
Thanks Meter: 573
thanks............................................ ......
Old 05-03-2008, 20:39   #4 (permalink)
Member: 765074
greatful for this post will give it a try for my Aiji cdma ap210
Old 05-04-2008, 14:59   #5 (permalink)
Member: 738907
Any Code for Huawei V800 ???
Hi All,
any secret codes for Huawei V800?
i want to switch it to Qualcomm mode....
please help
Old 05-04-2008, 19:58   #6 (permalink)
destinyhammed's Avatar
Member: 634275
Sonork: 100.1619208
Thanks Meter: 27
very nice job camu tell me meanning of nam
Old 05-08-2008, 07:54   #7 (permalink)
Member: 78347
Thanks Meter: 2
great job thanks a lot
thanks
krishna
Old 05-13-2008, 12:18   #8 (permalink)
Member: 577014
Brother, thank u very much
Old 05-13-2008, 13:12   #9 (permalink)
Member: 498498
Thanks Meter: 15
thanks good work bro kept up
Old 05-14-2008, 16:17   #10 (permalink)
Member: 738907
Problem with SGH-X820 and E250...
Hi,
i'm trying to do one of the following:
"Samsung X, E, V, S-series (korean models), e250, v420, s350, etc Nam Programming :
on my X820/E250 and nothing work for me....
i.e. i hold the Menu (top left button) in my E250 for 2 sec and than pressed 0 and nothing happaned....
any idea what to do ?
please hhhheeeelllppp
Old 05-15-2008, 11:31   #11 (permalink)
sanku's Avatar
Member: 300606
Sonork: 1576723
Thanks Meter: 165
Thanks
alot.....................................
SANKU™
Old 05-27-2008, 05:10   #12 (permalink)
Member: 780769
Sonork: ardhi83
unlock code for nexian fp333 please.. urgent
Old 05-27-2008, 06:07   #13 (permalink)
ericnite101's Avatar
Member: 450871
Sonork: 100.1592197
Thanks Meter: 121
Cool
Big up man you've saved the boat.
Old 05-27-2008, 06:49   #14 (permalink)
Member: 303336
Sonork: 100.1612298
Thanks Meter: 1,100
good work keep it up.............
The Following 2 Users Say Thank You to m rizwan sh For This Useful Post:
Old 06-01-2008, 12:00   #15 (permalink)
Member: 416286
Sonork: 100.1622339
Thanks Meter: 749
If you pplz like my post than don't forget to hit thanks button
The Following User Says Thank You to gsmpointhrp For This Useful Post:
all cdma secret codes sainesh QUALCOMM Models (3G) 27 04-05-2010 23:52
need huawei C5080 all secert code or engineer code kyaw8719 Various CDMA/TDMA Cell Phones 0 03-01-2010 10:26
All cdma secret code logicmobile Nokia CDMA 1 07-01-2009 09:55
HOT,All Hard reset,Secert Codes,Cables Finder,Unlock code Here GsmunlockArena Universal GSM Software 48 06-19-2009 07:13
all cdma secret codes sainesh Nokia CDMA 9 08-07-2007 04:21
Page generated in 0.50711 seconds with 8 queries
