10-18-2006, 05:41 | #31 (permalink) |
Banned Join Date: Nov 2005
Member: 204243 Status: Offline Thanks Meter: 67 | solutions wbr NITINWADHWA xxxxxxxxxxxxxxxxx Last edited by ..::ArchitRaj::..; 05-31-2007 at 19:59. Reason: phone number removed |
11-04-2006, 19:36 | #34 (permalink) |
No Life Poster Join Date: May 2003
Member: 28004 Status: Offline Sonork: 100.1601142 Thanks Meter: 770 | i have a nokia 2255 cdma set which is dropped in water , after cleaning it the phone is working ok but some of the keys are not working and the display light does not glow , can u give me any ways for 2255 keypad ways and backlight ways ? please help me .. thanks |
The Following User Says Thank You to gsmsikar For This Useful Post: |
11-07-2006, 07:31 | #36 (permalink) |
Freak Poster Join Date: Jan 2005 Location: india Age: 44
Member: 110487 Status: Offline Thanks Meter: 52 | please help me when i was reset my 3125 reliance phone from (*#7370#) after the phone no signal. i think disconnected from the net work. how to re connected the phone to rim please help me thanks |
11-08-2006, 20:15 | #37 (permalink) | |
Registered User Join Date: Oct 2005 Location: newzeland Age: 43
Member: 191225 Status: Offline Thanks Meter: 2,097 | hai Quote:
more deatile contact 00967-733355862 by sainesh | |
11-09-2006, 19:52 | #38 (permalink) |
Member: 191225 Status: Offline Thanks Meter: 2,097 | all cdma codes Samsung: All type of phones (old modeles): NAM programming: 47*869#08#9 Test mode: *759#813580 or 5809540*45680 exit test mode - 02 A-Key: menu + 0, code 25## Samsung A500 1. Enter ## and the 6 digit OTKSL 2. SERVICE MENU will appear and 1.Basic will be highlighted 3. Press OK 4. Device will display NAM CDMA/ Phone Number 5. Enter 10 digit MIN 6. Press OK (3 times) 7. Display will return to Service Menu. Press END. 8. Programming is complete Samsung N240 and N400 1. Enter ## and type in the 6 digit OTKSL 2. The display will show SVC MENU and 1. Phone Number 3. Press OK 4. Enter the 10 digit MIN and press OK 5. The display will show NAM with Home SID on the second line (Note: SID is no longer used) 6. Press OK 7. The display will return to the SVC MENU 8. Press END to complete the programming Samsung Uproar 1. Press MENU key 2. Enter 9 2 0 3. Enter the OTKSL 4. At SVC Menu screen press OK 5. Enter MIN and press OK 4 times 6. Enter SID (4654) and press OK 7. Press END key 8. Programming is complete Samsung N300 1. Press ## followed by the OTKSL 2. SVC menu will be displayed 3. Press 1 for Phone # 4. Enter the 10 digit MIN and press OK 5. MIN that was entered will be displayed press OK 6. SVC Menu will display press 3 for NAM 7. Enter the 4 digit Home SID press OK 8. Press END and handset will power cycle Samsung i300 1. Tap on the Phone Icon with stylus 2. Press #907*9#0 ENTER LOCK should appear on screen 3. ENTER OTKSL 4. SVC MENU will appear press 1 5. Enter 10 digit MIN and then press SAVE 6. Press SAVE again 7. Press 3 and then press SAVE 6 times 8. Enter the HOME SID and press SAVE once 9. Press END key twice Samsung A400 and A460 1. Enter ## and OTKSL 2. Press 1 for Basic at MENU (1 of Phone # when using the MSL) 3. Enter 10 digit MIN and press OK 4. At 1.Basic Menu press the END key 5. Handset will power cycle Samsung 3500 8500 6100 N200 1. Press MENU 2. Press 6 0 (3500) 8 2 0 (8500/6100/N200) 3. Enter OTKSL 4. Press 1 at SVC MENU Screen 5. Enter MIN and press OK 6. Press OK 4 times 7. Enter SID (4654) and press OK 8. Press END key 9. Programming is complete Qualcomm: QCP-800 programming: menu + 3 + 0. SPC: "000000" or may be other SPC typed by user. QCP-820/1920/2035: type "111111" and press Jog Dial. Choose "Programming" and enter SPC: "000000" or may be other SPC typed by user. QCP 1960 and 2760 1. Press softkey under the work MENU 2. Press 8 0 3. Enter the OTKSL 4. Press softkey for OK 5. Enter MIN and press softkey for OK 6. No SID is require for this handset 7. Press softkey for EXIT 8. Programming is complete LG: LGC-300 programming: menu + 9 and enter SPC: "000000" or may be other SPC typed by user A-Key: press STO for some time while you can see special code enter zone. Type 2539** and enter A-key LGC-330W programming: menu + 4 + 0 and enter SPC: "000000" or may be other SPC typed by user. A-Key: type 2539** and enter A-key LGC-800W /500 programming: menu + 0 and enter SPC: "000000" or may be other SPC typed by user. A-Key: type 2539** and enter A-key LGC-510 programming: menu + 3 + 0 and enter SPC: "000000" or may be other SPC typed by user. A-Key: type 2539** and enter A-key LG1010 LG4NE1 TP2200 TP2100 Touchpoint SB/DB TP 1100 TP5200 1. Press ## 2. Enter the OTKSL 3. Scroll to SAVE and press OK 4. Scroll to MIN and press OK 5. Enter 10 digit MIN scroll to SAVE and press OK 6. Scroll to SID and press OK (Skip on 4NE1 go to RESET PHONE and press OK to complete) 7. Enter SID (4654) and scroll to SAVE and press OK 8. Programming is complete LG5350 1. Enter ## and enter the OTKSL and press the left soft key under the word “Save” 2. At the Service Program display select Mobile Phone # and press the OK in the center of the 4 way navigation key 3. Enter the 10 digit MIN and press OK 4. Scroll down to 4. Advanced and press OK 5. Scroll to NMSI and press OK 6. Enter the MSID and press OK 7. Scroll down to 9. Amps Phone # and press OK 8. Enter the MSID and press OK 9. Press the END key TP 2100 1. Press ## 2. Enter OTKSL 3. Scroll to SAVE and press Roller Ball in for OK (ESN will display) 4. Select NEXT (by pressing in the roller ball) 5. Scroll to EDIT and press in the roller ball 6. Enter MIN 7. Scroll to SAVE and press roller ball in 8. Select NEXT at the next 3 screens and then EXIT 9. Programming is complete TP3000 1. Press ## 2. Enter OTKSL 3. Scroll to SAVE and press OK 4. Open flip 5. Use Stylus to enter the 10 digit MIN 6. Press OK (No SID entry is required) 7. Programming is complete TP 5250 1. Press ## 2. Enter the OTKSL 3. Scroll to SAVE and press OK 4. The phone display will read SVC Program 5. Scroll to MOBILE PHONE # and press OK 6. Phone display will read Mobile Phone Number 7. Enter the 10 digit MIN and press OK 8. Scroll to Home SID and press OK 9. Enter the 4 digit SID (4654) and press OK 10. Reset Phone will be highlighted. Press OK 11. Phone will reset 12. Programming is complete LG V111(DM110) [menu]30. After ask lockcode, enter: 843691. Ericsson: Programming: Shot NAM 987 + menu Long NAM 923885 + menu and enter SPC: "000000" or may be other SPC typed by user. CDMA mode 904093 + menu Analog mode 904095 + menu DM mode 904959 + menu Hyundai: HGC-120E / -130E programming: #86904**89397# HGC-600E programming: ##20022002, END and enter SPC: "000000" or may be other SPC typed by user. Sony: CM-M1300/3300/Z200 programming: type "111111" and press Jog Dial. Choose "Programming" and enter SPC: "000000" or may be other SPC typed by user. Sony CM-M1300 1. Power phone on 2. Enter six "1s" ( 111111 ) 3. Press the jog dial in 4. Press the jog dial in again to select programming 5. Enter six "0s" for the service security code 6. Phone displays the ESN 7. Press the jog dial in for OK 8. Enter your ten digit cellular telephone number 9. Press the jog dial in for OK 10. Enter your cellular carrier’s system ID (SID) without the zeros (Example: if your carrier’s system ID is 00035, enter just 35) 11. Press the jog dial in for OK 12. Enter a name for NAM 1 or just press the jog dial in for OK 13. Phone displays Basic NAM 1 Programming is complete 14. Press the jog dial in 15. Press the jog dial in again for EXIT 16. Phone powers itself off 17. Press the power button to power the phone back on 18. Basic programming is complete Motorola: StarTAC 7760/7860 programming: Service menu: FCN+0+000000+000000+RCL Test mode: FCN 00**83786633 STO V60c programming: Service menu: 74663 # [Menu] [Menu] (programming code) Test mode: [Menu] 073887 * (security code = 000000) Motorola Tarpon (120x) 1. Press 74663 (spells PHONE) 1. Press # MENU MENU quickly 2. Enter OTKSL 3. The work MIN will be highlighted 4. Select the word CHANGE by selecting the top right button 5. Select DELETE. Press and hold the button until clear 6. Have the customer enter the 10 digit MIN number 7. Select OK with the top right button. The “User Activation” screen will appear 8. Scroll to highlight the CDMA Sys ID 9. Select CHANGE by selecting the top right button 10. Enter SID 11. Select OK by selecting the top right button 12. Select DONE with the top left button 13. Press the END key 14. Press # MENU MENU quickly 15. Enter OTKSL 16. The work MIN will be highlighted 17. Select the word CHANGE by selecting the top right button 18. Select DELETE. Press and hold the button until clear 19. Have the customer enter the 10 digit MIN number 20. Select OK with the top right button. The “User Activation” screen will appear 21. Scroll to highlight the CDMA Sys ID 22. Select CHANGE by selecting the top right button 23. Enter SID 24. Select OK by selecting the top right button 25. Select DONE with the top left button Press the END key Motorola Phones (ALL) 1. Enter 74663 # FCN FCN 2. Enter OTKSL 3. Enter MIN and press STO 4. Enter SID (4654) and press STO 5. Press STO again – programming is complete Note: on the Tarpon (120C) you will need to press the MENU key instead of FCN. Nokia: 5185/6185 programming: *3001#12345# Software version: *#837# or *#VER# or *#9999# Serial / ESN: *#92772689# or *#WARRANTY# Phone reset: *#75681# or *#75682# Nokia 6185-5170 1. Press *#639# 2. Enter OTKSL and press OK 3. Enter the MIN and select OK 4. Enter the SID and select OK 5. Programming is complete Nokia 3585 1. Enter ## followed by the OTKSL 2. Number (MDN) is highlighted. Press the upper left-hand soft key to select 3. Mobile Number will display. Enter the 10 digit MIN 4. Press OK 5. IMSI will appear. Press and hold the Clear key until the display is empty. 6. Enter 31000 plus the MSID (15 digits total) 7. Press the upper left hand soft key and select OK 8. It will take you back to the SVC Programming. Press the upper right hand soft key to select EXIT 9. Press END. 10. Phone will power cycle and programming is complete. SK Teletech: SK-IM 1000/1400/2000/2200/2400 programming: #7583538324#626# Getrun 2000: System NAM programming mode: 0 + 1 + # + 7 + 3 + 7 + SECURITY CODE (000000) Debug menu: 0 + 1 + # + 3 + 2 + 4 + SECURITY CODE (000000) Debug screen of field test mode: 0 + 1 + # + 7 + 2 + 7 Test mode: 0 + 1 + # + 7 + 6 + 4 + SECURITY CODE (000000) System test mode: 0 + 1 + # + 7 + 6 + 8 + SECURITY CODE (000000) NEOPOINT: Neopoint 1000 1. Press M to display Main Menu 2. Scroll to PREFERENCES 3. Press softkey under SELECT 4. Enter 040793 5. Scroll to PROGRAMMING 6. Press softkey under SELECT 7. Enter OTKSL 8. Press softkey under DONE 9. Scroll to PHONE NUMBER 10. Enter 10 digit MIN 11. Scroll to HOME SID 12. Enter SID (4654) 13. Press softkey under SAVE to exit 14. Programming is complete NEOPOINT 1600 1. Power the phone on 2. Press the "Menu" key 3. Scroll to "Preferences" - press "Select" 4. Key in the "Field Service Code" (the phone will not prompt you for the code) at the "preferences" screen to access the "Service" menu (Default code is "000000") 5. Scroll to "Programming" - press "Select" - the phone will ask for the "Subsidy Lock Code" 6. Enter the "Subsidy Lock Code(654321)" to access the "NAM" menu 7. Select the NAM to be programmed (NAM 1 or NAM 2) 8. Program the NAM - Phone number and CDMA Home SID 9. After programming has been completed press "Save" - the phone will reset Audiovox: Audiovox 9100 1. Press ## 2. Enter the OTKSL 3. Display will read Service/Menu 1 Basic…press OK 4. Next screen will read Service Mode/Home SID…press OK 5. Next screen will read Service Mode/Home SID…press OK 6. Device will display Service Menu 1. Basic # 7. Press END button to complete programming Handspring TREO: 1. Open the flip and press the PHONEBOOK button one time to display the dial pad 2. Enter ## and the OTKSL using the numbers on the Dial Pad 3. Press the handset button shown in the diagram above 4. At the Activations screen enter the MIN in the phone number field using the numbers on the device keyboard 5. Put a check in the Enable Number Portability box and type the MSID in the MSIN field 6. Press OK 7. The device will display the network search pop-up and return to the Phonebook display Hitachi P300: 1. Enter ## and the 6 digit OTKSL 2. Press the Options soft key and then scroll to Save Phone #. Press the OK soft key. 3. At the NAM display scroll to EDIT and press the OK soft key 4. Display will read NAM and MDN will be highlighted. Press the OK soft key. 5. At the MDN display enter the 10 digit MIN and press the SAVE soft key. 6. At the Save prompt press the OK soft key. The next display will show several options that should not edited. 7. Press the EXIT soft key and the device will power cycle. 8. Programming is complete. Kyosera: Kyocera 2345 1135 1. Press 111111 (#1 key 6 times) 2. Option will be highlighted 3. Press OK 4. Scroll down to Programming 5. The service programming dialog will appear Enter Security Code. 6. Enter the 6 digit OTSKL (code will show as asterisks on screen) 7. Service Options will appear 8. Scroll down to the BASIC NAM1 Info 9. Press OK 10. Select the Phone Number by pressing the OK key 11. Using the keypad enter the 10 digit MIN 12. Press OK 13. Press END to complete the programming Kyocera 6035 1. Press 1 six times (111111) and select OPTIONS 2. Select PROGRAMMING 3. Open flip 4. Tap the OTKSL on keypad on the screen. Tap OK 5. Tap on the PHONE NUMBER field. Enter MIN. 6. Leave A-KEY blank 7. Enter HOME SID (4654) 8. Tap SAVE & EXIT 9. Tap YES 10. Phone will be in OFF MODE Close flip. Kyocera 3035 1. Press 111111 (the #1 key six times) 2. Options will be highlighted 3. Press in the navigation key (Navigation key is the button located between the TALK & END key) 4. Scroll to PROGRAMMING using the Navigation key 5. Select PROGRAMMING by pressing in the Navigation key 6. Enter the six digit OTKSL and press in the navigation key 7. SERVICE OPTIONS will appear 8. Scroll down to the Basic NAM1 info 9. Press in the navigation key 10. Clear any numbers that may appear using the “clear” key (arrow key located directly below the navigation key) 11. Select the PHONE NUMBER by pressing in the navigation key 12. Enter the 10 digit MIN select OK by pressing in the navigation key 13. Press END. Programming is complete. Kyocera 2255 1. Press the 1 key six times (111111) “Option will be highlighted 2. Press OK 3. Scroll down to “Programming” and press “OK” 4. Enter OTKSL and press the navigation key 5. “Service Options” will appear scroll down to the “Basic NAM1 Info” 6. Press OK 7. Select Phone Number by pressing OK 8. Enter MIN and press OK again 9. Scroll to Home SID and press OK 10. Enter SID (4654) and press OK 11. Press END. Programming is complete. QCP 2035 1. Press 1 six times (111111) 2. Press u key to select OPTIONS 3. Highlight PROGRAMMING and press u key 4. Enter OTKSL 5. ESN will appear press left arrow key to select OK 6. Enter MIN and press ç key 7. Press ç key again to exit - Programming is complete Sanyo: Sanyo 4000 4500 4700 5000 6000 1. Press ## 2. Enter the OTKSL 3. Scroll to SAVE and press OK 4. ESN will be displayed – press OK 5. Enter 10 digit MIN and press OK 6. Enter SID (4654) and press OK 7. Press OK twice 8. Programming is complete Sanyo 5150 5300 and 6400 1. Enter ## followed by the OTKSL 2. Press MENU SAVE PHONE # 3. Press Ok 4. SVC Programming will be displayed. Scroll and highlight Mobile Number. Press OK 5. Press OK again 6. ESN will be displayed. Press OK 7. Mobile Number will be displayed enter the 10 digit MIN press OK 8. Press OK 4 times 9. Phone will power cycle 10. Programming is complete Sanyo 6000 1. Press ## 2. Enter OTKSL 3. Press MENU Key and scroll to SAVE PHONE # and press OK 4. ESN will be displayed press OK 5. Enter MIN and press OK 6. Enter SID and press OK 7. Press OK twice more 8. Programming is complete Sanyo 4900 1. Enter ## followed by the 6 digit OTKSL 2. Press the MENU/OK key and scroll and highlight SAVE PHONE # 3. Press MENU/OK 4. Scroll and highlight MOBILE NUMBER press OK 5. At the ESN display press OK 6. In the MOBILE NUMBER screen enter your MIN and press OK 4 times 7. At the service program menu scroll to exit and press the MENU/OK key. 8. Programming is complete Sanyo 6200 1. Enter ## 2. Enter OTKSL 3. Press the MENU key and scroll to highlight SAVE PHONE # 4. Press OK 5. Scroll and highlight MOBILE NUMBER 6. Press OK twice 7. Scroll and highlight EXIT 8. Press OK 9. Phone will power cycle 10. Programming is complete Toshiba: Toshiba 2032P 1. Slide the Radio Standby Switch on the left side of the device to the upper side (ON) to activate the phone function. This is the switch with the phone icon over it 2. After power up is completed use the stylus to tap on the ADMIN pull up menu at the bottom of the screen and select ACTIVATION WIZARD. If your device has not yet been activated the ACTIVATION WIZARD will automatically start when you turn on the radio in your device. 3. Tap NEXT 3 times. If the device has been previously activated it will require only 2 presses. 4. On the fourth screen enter the 6 digit OTKSL using keyboard 5. Enter the MIN in both entery fields then tap NEXT 6. Wait for the device to initialize and display “ready to connect” 7. To initiate IOTA tap the word ADMIN at the bottom of the display and then Data Provisioning 8. Programming is complete ******* Here is a list of various codes to try out. Some may require an MSL to be able to make full use of the functionality. ##2769737 [##BROWSER] - MiniBrowser Settings (2G) ##8626337 [##VOCODER] - Set Vocoder ##3282 [##DATA] - Setup Menu for Vision handsets ##8463 [##TIME] - Airtime Menu ##040793 - Debug Menu ##786 [##RUN] - Technical Information (be careful with this one, you can reset the handset) ##932 [##WEB] - IP Address information (2G) ##889 [##TTY] - TTY On or TTY Off ##4357 [##HELP] - Help |
The Following 6 Users Say Thank You to sainesh For This Useful Post: |
11-13-2006, 13:10 | #42 (permalink) | |
Junior Member Join Date: Sep 2006
Member: 342960 Status: Offline Thanks Meter: 0 | hi i had asked if i can transfer the same settings of Quote:
nokia bb5 service soulation avilable here | aleenasager | Nokia Hardware & Hardware Repair | 2 | 09-26-2007 16:29 |
all nokia bb5 service soulation avilabile here (click) | aleenasager | Nokia Hardware & Hardware Repair | 1 | 10-16-2006 00:56 |
all nokia bb5 service soulation avilabile here (click) | aleenasager | Nokia Hardware & Hardware Repair | 2 | 10-16-2006 00:54 |
All Nokia CDMA Service Software here ;) | dennt | Nokia CDMA | 7 | 08-25-2006 01:15 |
