Go Back   GSM-Forum > CDMA & TDMA Phones / Tablets Area > CDMA Apple, CDMA BlackBerry, Nokia & Motorola
CDMA Apple, CDMA BlackBerry, Nokia & Motorola CDMA Apple, CDMA BlackBerry, Nokia & Motorola
Old 09-26-2010, 05:38   #1 (permalink)
~AKSingh~'s Avatar
Member: 65063
Sonork: 100.1603561
Blackberry 8330 8703e 7103e 8130 Esn/Meid Repair
ESN/Meid Changing is ILEGAL cHECK your country's LAW
THIS PROCESS STICTLY CONFINED TO EDUCATIONAL PURPOSES ONLY
Blackberry 8330 8703e 7103e 8130 and many more Esn Repair process
Only by CdmaWorkshop Lisenced Version
Ref : CDMA Service Software / ESN Changer, SPC Unlocker...
What you need:
1- Blackberry Device
2- Blackberry Desktop Manager
3- CDMA Workshop 3.x.x *** This is only tested on 3.x.x. and higher ***
By older version only ESN can be repaired not pESNs
4- ESN/MEID That you want to right.
* NOTE
Make sure that the blackberry is on the lowest possible OS. If it is not you can get a "Read Error" in Workshop and you will not be able to Repair your device
* STEPS
Step 1: Open Blackberry Desktop Manage
Step 2: Verify that your Blackberry is on the lowest possible OS.
Step 3: Open CDMA Workshop.
Step 4: Connect to the Blackberry Com Port that pertains to your device. Example > If you notice you will have two ports for Blackberry. They will be called "RIM Virtual Ports" Mine are Com 2 & 3. You will always want to choose the highest one. So in my case I will choose "3"
Step 5: After you are connected click on "Read", then go to the "Security" tab and depending on your Blackberry send the "SPC" to your device.
if spc is correct " SPC is correct phone is unlocked " will be prompted
Here are the locations for the SPC code if your BB is not Verizon.
BlackBerry 8130:1060:1070
BlackBerry 8330:1060:1070
BlackBerry 8830:1060:1070
BlackBerry 8703e:100D:1012
Step 6: Go to MEID and click on "Read" then go to the drop down menu and select "Universal, Ram Method"
Then choose scan:
Blackberry Storm:
0264 : 0269 Scan and save as scan1 or something similar.
Then scan this location:
17B0 : 17FD Scan and save as scan2 or something similar.
Once the scan is done open both of them and take "scan2" and copy all the ad******* and paste it right under the last address under "scan1". VERY IMPORTANT *** DO NOT LEAVE A SPACE UNDER THE LAST ADDRESS *** Go ahead an put the cursor and the end of the last number and hit delete to delete any line that maybe under. To test just hit the down key. If it doesn't go down to the next line then you're good.
* Once you have combined the scans save it. Either as scan1 or something else. Just remember what you named it and where it's at.
Now if it is not a BB Storm 1 scan with this location:
1013 : 10D7
you don't need to combine since it's just one scan. Remember none of this will work unless you are running the lowest OS for that model.
Go ahead and save the scan after it's done.
Step 7: Now put the MEID Hex that you want in the box. Example A1000005478893 Meid Hexadecimal
go back to "Universal, Ram Method' and this time choose "Load". Then find either, the combined scan BB Storm 1, or the just one scan, any other BB. Keep in mind that this does not work for the Storm 2, 9530, or the 9630.
br,
Old 09-26-2010, 05:41   #2 (permalink)
~AKSingh~'s Avatar
Member: 65063
Sonork: 100.1603561
ESN address
8130 ESN ad*******:
1013:2F38
106C:CF60
1070:F7B8
1097: D47C
1098:25CD
10A5: D2F4
10A6:4AE0
10B4:20CE
10B5:44A1
MEID (pESN) ad*******:
1015:8430 - pESN
109C:7804 - pESN
109C:C9E5 - pESN
10AA:864C - MEID
10B8:CC70 - MEID
10B8:B18B - pESN
10B8:B48D - pESN
10B9:F879 - MEID
10B9:EF8B - pESN
1071:5398 - MEID
1071:4D10 - pESN
109C:77B4 - pESN
109C:C995 - pESN
10AA:85FC - MEID
10B8:C514 - MEID
10B8:C525 - MEID
10B8:AE39 - pESN
10B8:B137 - pESN
10B9:F825 - MEID
10B8:CC70 - MEID
10B8:B18B - pESN
10B8:B48D - pESN
10B9:F879 - MEID
10B9:EF8B - pESN
1071:5398 - MEID
1071:4D10 - pESN
109C:7170 - pESN
109C:C351 - pESN
10AA:707C - MEID
10AA:E864 - pESN
10B8:A98C - MEID
10B8:A99D - MEID
10B8:9BB8 - pESN
10B9:E29D - MEID
1071:5398 - MEID
1071:4D10 - pESN
1075:7668 - pESN
109C:C9E5 - pESN
10B8:CC70 - MEID
10B8:B18B - pESN
10B8: D88D - pESN
10B9:F879 - MEID
109C:C9E5 - pESN
10B8:CC70 - MEID
10B8:B18B - pESN
10B8:B48D - pESN
10B9:F879 - MEID
10B9:EF8B - pESN
1071:5398 - MEID
1071:4D10 - pESN
1071:48A4 - pESN
1072:6D4C - pESN
1072:75BC - pESN
1075:7198 - pESN
109C:7170 - pESN
109C:C351 - pESN
10AA:E864 - pESN
10B8:A0CA - pESN
10B9:E29D - pESN
10B8:9BB8 - pESN
1071:5398 - MEID
1071:4D10 - pESN
1075:74AC - pESN
1075:7668 - pESN
109C:C9E5 - pESN
10B8:CE70 - MEID
10B8:B18B - pESN
10B8:BC8D - pESN
10B9:F879 - MEID
br,
The Following 9 Users Say Thank You to ~AKSingh~ For This Useful Post:
Old 09-26-2010, 05:43   #3 (permalink)
~AKSingh~'s Avatar
Member: 65063
Sonork: 100.1603561
8330m
8330m meid ad*******
1015:8430 - pESN
1071:5398 - MEID
1071:4D10 - pESN
1071:4DE4 - pESN
1072:721C - pESN
1072:7A8C - pESN
1075:7668 - pESN
109C:7804 - pESN
109C:C9E5 - pESN
10AA:864C - MEID
10AA:FE40 - pESN
10B8:CE70 - MEID
10B8:B18A - pESN
10B8:B4A2 - pESN
10B9:F879 - MEID
br,
The Following 8 Users Say Thank You to ~AKSingh~ For This Useful Post:
Old 09-26-2010, 05:43   #4 (permalink)
~AKSingh~'s Avatar
Member: 65063
Sonork: 100.1603561
8703e
8703e ESn ad*******
ESN ad*******:
1005:86F4
1005:B450
1005:C864
1010:5240
1010:5314
1012:0320
1012:0B78
1014:5004
1015:76B0
101F:F084
1028:226D
1015:75D4
1012:0B78
br,
Old 09-26-2010, 05:44   #5 (permalink)
~AKSingh~'s Avatar
Member: 65063
Sonork: 100.1603561
Blackberry 9530 Esn repair
- Downgrade firmware to 4.7.0.65
- Input the new MIED
- Scan & save 0264:0269( text file 1 )
- Scan & save 17B0:17FD( text file 2 )
- Copy and paste text file 2 to text file 1
- Hit save and write.
Note: use universal ram methol to scan and write.
br,
Old 09-26-2010, 05:46   #6 (permalink)
~AKSingh~'s Avatar
Member: 65063
Sonork: 100.1603561
7103e Esn Repair
BB 7103e RAM scan 1000-1027 and found
ESN ad*******:
1005:7934
100C:6CE8
100C:6DBC
100D:296C
100E:1DC8
100E:2620
1010:68A8
1011:8F54
101C:0928
1023:F04D
br,
Old 09-26-2010, 05:49   #7 (permalink)
~AKSingh~'s Avatar
Member: 65063
Sonork: 100.1603561
8330 esn repair
8330 esn address from different Firmwares
ESN ad*******:
1015:8430
109C:7170
109C:C351
10AA:E864
10B8:9BB8
10B8:A0CA
10B9:E29D
1071:48A4
1074: D614
1075:7198
10B8:A0CA
10B9:E29D
1015:8100
1075:1E94
109C:1E6C
109C:704D
10AA:1D74
10AA:9560
10B8:4833
10B8:4D35
10B8:55FE
10B8:560F
10B9:8633
10B9:8F21
1015:8430
1071:48A4
1075:7198
109C:7170
109C:C351
10AA:7078
10AA:E864
10B8:9B72
10B9:E29D
1015:8430
1071:48A4
1075:6FE0
1075:719C
109C:7174
109C:C355
10AA:707C
10AA:E868
10B8:9BAE
10B9:E2A1
1015:8430
1071:4D10
1075:744C
1075:7608
109C:77B4
109C:C995
10AA:85F8
10AA:FDEC
10B8:B137
10B8:E639
10B9:F825
1015:8100
1075:1E94
109C:1E6C
109C:704D
10AA:1D74
10AA:9560
10B8:47F8
10B9:8F21
1015:8100
1070:F59C
1075:1E94
109C:1E6C
109C:704D
10AA:1D74
10AA:9560
10B8:482E
10B9:8F21
1015:8430
1071:48A4
1072:6D4C
1072:75BC
1075:7198
109C:7170
109C:C351
10AA:E864
10B8:A0CA
10B9:E29D
10B8:9BB8
1071:48A4
1015:8430
109C:7174
109C:C355
10AA:707C
10AA:E868
10B8:9BAE
10B8:A97E
10B8:A98F
10B9:E2A1
1015:8100
1075:1CD8
1075:1E94
109C:1E6C
109C:704D
10AA:1D74
10AA:9560
10B8:4335
10B8:4833
10B9:8F21
1015:8430
109C:7170
109C:C351
10AA:7078
10AA:E864
10B8:9B97
10B9:E29D
1071:48A4
1071:4978
br,
AKSingh
The Following 10 Users Say Thank You to ~AKSingh~ For This Useful Post:
Old 09-26-2010, 05:56   #8 (permalink)
~AKSingh~'s Avatar
Member: 65063
Sonork: 100.1603561
BB OS 4.5...175 and above have memory access restrictions
since phones like 8230, 8530 and 9630 came out with that OS version already there's no known way to enable mamory reading,
and since there's no older versions hence no downgrade
Beside these there are lot of issues in Blackberry Cdma like corrupted reg id
leading to no spc access
all can be resolved
Some particular version of firmware not allows to access proper ad******* need to be downgraded to only fixed versions etc
bla bla ......
br,
Old 09-26-2010, 08:03   #9 (permalink)
Moderator
yousha's Avatar
Member: 17689
Sonork: 100.72392
Its only for those who have CDMA-WORKSHOP 3.X or higher any info about BB Specially cdma is really important post only relevant things
NO THANKS POST
NO OTHER SPAM or Links to other forums
i will delete that otherwise i hope you people understand
Good info and needs to be sticky
The Following 9 Users Say Thank You to yousha For This Useful Post:
Old 09-26-2010, 08:41   #10 (permalink)
Member: 988879
Any info related to shareware software is useless to sticky.
And this whole method can be done via qxdm or unicdma tool.
Free of cost without buying any CDMA workshop.
This look advertisement of CDMA workshop selling only.
All know that akshing have no business now days accept CDMA workshop activation selling at 3x rate and saying bad words to other people at yahoo. Rolf
The Following 5 Users Say Thank You to Advance cdma For This Useful Post:
Old 09-30-2010, 07:12   #11 (permalink)
Crazy Poster
Member: 137412
Smile
sir from where we will get the esn ad******* for every phone thx ak singh doesnt have full knowledge abt cdma workshop because he just bought the cdmaworkshop start working sajinder from ludhiana have full knowledge abt the working of cdma softwares ak singh is also buying software from him he is a little kid against sajinder because thx.sajinder is using cdmaworkshop from three years and he also have dfs full version which the others doesnt have.i my knowledge he is the king of cdma softwares.
Old 09-30-2010, 15:35   #12 (permalink)
~AKSingh~'s Avatar
Member: 65063
Sonork: 100.1603561
thx Tarun I dint knew that
is there anything left please write it here
The Following User Says Thank You to ~AKSingh~ For This Useful Post:
Old 10-02-2010, 06:01   #13 (permalink)
sanjubhai's Avatar
Member: 386868
sir can we work with the cracked version of cdma workshop also .
sanjubhai.
Old 10-02-2010, 06:38   #14 (permalink)
Crazy Poster
Member: 239441
Thumbs down
sanjubhai.
Answer to your question is clearly stated.. JUSt READ VERY FIRST FEW lines of the first post (highlighted in RED color here)and then USE brain ..
What you need:
* NOTE
br,
NR
The Following User Says Thank You to barodagsm.com For This Useful Post:
Old 10-09-2010, 23:23   #15 (permalink)
luzer's Avatar
Member: 44659
... cracked version can't read blackberry phones
The Following User Says Thank You to luzer For This Useful Post:
Nokia "Contact Service" Repairer Dirk Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 5 10-04-2011 05:45
I need the nsc/nsw ESN editor URGENTLY!Please help me! Bert Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 0 03-19-2000 09:10
Nobody know the 6120 ESN promming? Bert Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 1 11-09-1999 03:35
Does any one know how to program the ESN number with nokia 6120? Bert Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 0 11-02-1999 09:45
ESN Change OGOMEZ Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 0 09-21-1999 23:56
Page generated in 0.48326 seconds with 12 queries
