08-01-2007, 19:16 | #1 (permalink) |
Insane Poster Join Date: Jun 2007 Location: east java
Member: 532088 Status: Offline Thanks Meter: 9 | help 3105 power switch tracks (pls see. image) somebody can help this --- the line connected to C306--, pls see attached image thx BR |
09-10-2007, 07:22 | #3 (permalink) | |
Member: 532088 Status: Offline Thanks Meter: 9 | Quote:
1st 3105: i make a hole with needle on the lost-point till i see very small point inside, then I drop a-small tin and heat it with ****er, you will see the tin glued, VIOLA, put wire to the switch. 2nd 3105: not possible to aplly 1st trick, then i make direct connection to uem PWRONX. it lies in 7th point right side.. good luck. | |
09-11-2007, 22:09 | #4 (permalink) |
Junior Member Join Date: Nov 2006
Member: 386021 Status: Offline Thanks Meter: 0 | YUP, i have red ur solution on FiF web, but i'm not dare to do like that, try to make connection to under uem. thx, i will try the first solve here, to look for lost point near power switch, ur br |
nokia 3530 power switch track broken....plz help.where to put jumper wire?????? | RAHUL12345 | Nokia Hardware & Hardware Repair | 6 | 05-28-2013 04:29 |
nokia 6100 power switch track or positive ways | barthosyn | Nokia Hardware & Hardware Repair | 18 | 12-12-2009 07:01 |
help 3105 power switch tracks | ufs_ternoda | Nokia CDMA | 0 | 08-01-2007 16:57 |
3220 power switch track | yandbass | Nokia Hardware & Hardware Repair | 8 | 09-29-2006 21:31 |
6230 power switch tracks ......... | faisi | Nokia Hardware & Hardware Repair | 3 | 03-17-2006 14:54 |
