How to Reset security code nokia 3586(CDMA) How to reset security code in nokia3586 Rh44 I dont have flashing cable for 3586 I having unlock code (i pasted below) But i dont know what is OTKSL Nokia 3585 1. Enter ## followed by the OTKSL 2. Number (MDN) is highlighted. Press the upper left-hand soft key to select 3. Mobile Number will display. Enter the 10 digit MIN 4. Press OK 5. IMSI will appear. Press and hold the Clear key until the display is empty. 6. Enter 31000 plus the MSID (15 digits total) 7. Press the upper left hand soft key and select OK 8. It will take you back to the SVC Programming. Press the upper right hand soft key to select EXIT 9. Press END. 10. Phone will power cycle and programming is complete. Anybody know solution |
its spc okk.......... |
ufs and POP port cable and do master reset( full fact defaults) enjoy. sm4rtboy |
if u do factory default. network will go as well as min sc all gone. use phoenix with usb cable |
use this master code ,, and be happy! br sm4rtboy |
1 Attachment(s) Quote:
wbr aksingh 09810222476 |
I dont have flashing cable for 3586 you should send the cable --LOL not help ...anyone br sm4rtboy |
he posted real solution .... and its work for me........ he don't posted mcode like you posted.........hehe @AVITHAKUR thx for pm..... |
Man first u Read carefully the difrence between Gsm & Cdma ! This master code needs IMEI no. to generate master code ! have u seen IMEI in cdma phones ?? |
rds aksingh |
help me too please, i have 3586 call problem. if i get incoming call than its only ringing 1 time (1 second) than display 1 missed call. n i can't make outgoing call. anybody can help? what's wrong with my 3586? thanks |
wait till 24 hour, no body can give solution hiks hiks hiks |
First Write PM which appropriate with your provider. (Example: PM Flexi, PM Esia, PM Starone, PM Fren) if use Phoenix, write PRI, TUN, Reset Full. |
wbr aksingh +919810222476 |
