Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Nokia > Nokia CDMA
Old 04-30-2007, 17:01   #1 (permalink)
Member: 494736
Thanks Meter: 3
Nokia 1255 Flash
People Please Help Me. I Need Flashfiles And Flasher For Nokia 1255 Rh-79
The Following User Says Thank You to sato_2005 For This Useful Post:
Old 05-01-2007, 07:05   #2 (permalink)
~AKSingh~'s Avatar
Member: 65063
Thanks Meter: 2,419
if u need 1255 flashfile for hang problem
u dont need to flash
u can even make ruim or non ruim just by simple trick
u are a new member search the forum , everything for 1255 is there
wbr
The Following 2 Users Say Thank You to ~AKSingh~ For This Useful Post:
Old 05-01-2007, 22:16   #3 (permalink)
Member: 494736
Thanks Meter: 3
My nokia 1255 power in with press * + 5 + power in emergency mode (download mode) in normal mode his not work and not power in. I need flasher and fullflash. On the phorum all links for a 1255 is bad.
The Following 2 Users Say Thank You to sato_2005 For This Useful Post:
Old 05-02-2007, 08:14   #4 (permalink)
deepak2005's Avatar
Member: 253019
Thanks Meter: 31
wbr
I am agery with mr. A K Singh jee
why you not agery with him
wbr
Deepak
The Following User Says Thank You to deepak2005 For This Useful Post:
Old 08-30-2007, 15:35   #5 (permalink)
Member: 552767
Thanks Meter: 13
any one can give me nokia 1255 RH-79 Flash file...
The Following User Says Thank You to kumar_212005 For This Useful Post:
Old 09-01-2007, 09:59   #6 (permalink)
Crazy Poster
Member: 572920
Thanks Meter: 5
its posted many times sir.
The Following User Says Thank You to Code Divide For This Useful Post:
Old 09-06-2007, 11:37   #7 (permalink)
Member: 429614
Thanks Meter: 29
Question use ccs tool for 1255
why r u not try 2 use ccs tool for flash 1255
The Following User Says Thank You to srijhawar For This Useful Post:
Old 09-07-2007, 07:01   #8 (permalink)
Member: 429614
Thanks Meter: 29
pick up bro 1255 flash file
here is d link...... http://rapidshare.com/files/53948049...NOKIA_1255.rar
The Following 7 Users Say Thank You to srijhawar For This Useful Post:
Old 12-09-2007, 02:04   #9 (permalink)
Member: 7103
Thanks Meter: 48
Originally Posted by srijhawar View Post
thanks very much bos
The Following User Says Thank You to rebi_cell For This Useful Post:
Old 06-05-2008, 08:40   #10 (permalink)
Member: 773062
Will the document to how to use it?
The Following User Says Thank You to hyhx For This Useful Post:
Old 06-05-2008, 09:48   #11 (permalink)
~AKSingh~'s Avatar
Member: 65063
Thanks Meter: 2,419
here instructions for 1255
wbr
File Type: txt 1255 unlocking.txt (890 Bytes, 577 views)
The Following 6 Users Say Thank You to ~AKSingh~ For This Useful Post:
Old 06-05-2008, 09:49   #12 (permalink)
~AKSingh~'s Avatar
Member: 65063
Thanks Meter: 2,419
further queries invited for all ccs models !
wbr
Old 01-28-2009, 17:17   #13 (permalink)
Member: 10107
Thanks Meter: 22
i need to convert to non ruim 1255
hi, i flashed 1255 handset showing battery symbol only .phone works ok with card, but dous not work in non ruim mode, how can i retore it to original non ruim mode, i tried to connect to bit pim but failed, it is connecting to qpst but cannot convert to non ruim, i tried reset wit ccs flash tool but then phone does not catch network, it is a reliance set.
regards
gopal
The Following 3 Users Say Thank You to gopalg73 For This Useful Post:
Old 12-12-2010, 11:02   #14 (permalink)
Member: 953903
no................................................ ...........................................
Old 12-31-2010, 10:21   #15 (permalink)
Member: 1030416
Sonork: rinku_2k9
Thanks Meter: 17
how to flesh 2505 nokia
how to flash nokia 1255 skagrll Nokia CDMA 5 03-28-2012 12:38
Nokia 1255 show only bettery . sonu arya Nokia CDMA 8 05-07-2010 18:47
Can anybody help nokia 1255 set dead.when i flash. debmobile Nokia CDMA 3 06-01-2009 17:11
URGENT : Flash file for CDMA Nokia 1255 aribairam2008 Universalbox 0 04-08-2008 21:39
Nokia 1255 flash file for universal box needed sunil9200 Universalbox 3 03-17-2008 15:01
Page generated in 0.22680 seconds with 10 queries
