08-06-2008, 08:54 | #1 (permalink) |
Insane Poster Join Date: Sep 2006
Member: 341975 Status: Offline Thanks Meter: 24 | Unlocking the User Lock Code on Nokia 2865i However, jaf does communicate with the phone and can read the PM (permanent memory) section. Here are some notes about the user lock code on this phone that i compiled. In this case, the user lock code is set to 6969 [154] 183=36393639 In this case, the user lock code is set to 12345 [154] 183=3132333435 Using jaf to erase pm field 183 of pm record 154 results in the user lock code being set to an unknown value. So don't erase this field or leave it blank. To get back into the phone with the now unknown password, i looked at what values changed in the pm as incorrect lock codes were entered. And then used jaf to erase the corresponding fields. Record 12 from field 11 erased! Record 20 from field 11 erased! Record 0 from field 98 erased! I also saw a field with a 1 value near this record that looked like a boolean on/off toggle and decided to erase it Record 13 from field 11 erased! The phone now booted up without asking for a user lock code anymore. For record, here's some more info about the phone that i was using: MCU SW version: V FL100V1000.nep 15-09-06 RM-193 (c)NMP PCI version: UEM version: 400 UPP version: 8273 RFIC version: DSP510_FLT_06w13_01_TK2 DSP version: DSP510_FLT_06w13_01_TK2 LCD version: SUEZ PPM version: V FL100_05w21_50_15.nbr 31-08-06 RM AA And i used the gsm nokia 3100 cable with this phone. It didn't quite fit properly into the phone. So i disassembled the phone, removed the motherboard and shielding over the fbus/mbus area and then held the phone adapter onto the motherboard using my hands. If you are going to work on a bunch of these phones, you'll probably want the proper adapter though. |
08-06-2008, 09:21 | #2 (permalink) |
Member: 341975 Status: Offline Thanks Meter: 24 | here's a little more info about the fields that were erased: 1st boot [11] 12=05 13=01 20=AA00 [98] 0=000100003132333435000000000000000031323334350000 0000000000000F373836353339383130310000000000000000 00000000000000000000000000000000000000373836333638 36343837000000000000000000000000000000000000000000 00000000000037383635333939323937000000000000000000 0000000000000000000000000000000000000101 2nd boot [11] 12=06 13=01 20=BA00 [98] 0=000100003132333435000000000000000031323334350000 0000000000000E373836353339383130310000000000000000 00000000000000000000000000000000000000373836333638 36343837000000000000000000000000000000000000000000 00000000000037383635333939323937000000000000000000 0000000000000000000000000000000000000101 note that F37383635 has become E37383635 |
T939 is USTpro can read the user lock code? please tream USTpro let me know | mymiela0419 | UST Pro II | 4 | 08-02-2009 09:00 |
user lock code on moto acer | panafax_gsm | VygisToolbox | 0 | 03-18-2006 05:45 |
forgot security/lock code on nokia 6680 | Snus_Kongen | Nokia Base Band 5 ( BB-5 ) | 3 | 11-08-2005 16:53 |
How to check the locks status on Nokia 6310i? | macosx | Phone Unlocking Codes & Maps | 0 | 03-29-2003 18:34 |
Is there anyway to reset the user lock on GD93? | NUGSM | Panasonic | 1 | 10-03-2001 13:34 |
