07-28-2008, 16:55 | #5 (permalink) |
Freak Poster Join Date: Feb 2006 Location: India
Member: 232566 Status: Offline Thanks Meter: 150 | Brief Explanation------> It is damn easy to flash Nokia CDMA handsets with JAF.you need nfp files as mentioned by akhilesh,open jaf exe select "Load NFP" and select the proper file i.e version depends upon ur needs.Don't select any other option except load NFP and click on flash. To obtain the nfp files you need to download desired firmware from the support area. 190 is for Ruim and 100 is for Non RUim. It is for Educational Purpose Only. Do not play with CDMA. Take Lessons from the CDMA Guru (Yahoo Messenger is mentioned in the above post) E N J O Y. Regards, |
The Following User Says Thank You to Moderate For This Useful Post: |
07-28-2008, 16:57 | #6 (permalink) |
Registered User Join Date: Oct 2005
Member: 189506 Status: Offline Sonork: 100.1576871 Thanks Meter: 126 | nfp files download from jaf support......... then open jaf ,tick on load nfp then flash it.......................... remember ,Don't do ui settings after flash |
07-28-2008, 18:27 | #7 (permalink) | |
Member: 232566 Status: Offline Thanks Meter: 150 | Quote:
http:///vbb/showthread.php?t=426591 Thnx to My Friend Rajan, Regards, | |
