04-23-2008, 17:47 | #1 (permalink) |
No Life Poster Join Date: Dec 2006 Location: P A K I S T A N
Member: 416286 Status: Offline Sonork: 100.1622339 Thanks Meter: 759 | All CDMA Secert Codes Samsung sph-n240, n400, a460, a500, etc Nam Programming : Nam Set: ##Spc Test Mode: 47*869#1235 Debug Menu: ##33284,ok Service Menu: Menu+8+0 (#889) Reset (Life time, Clear Memory, etc): ##786,ok A-key: ##2539,ok Label Selection: ##3882,ok Label(Home, Work, etc) : **523,ok NGG Setting (Gateway, etc.): ##2769737,ok Vocoder: ##8626337,ok CAI Change: ##7738,ok Enable TTY: ##889,ok Samsung a530, a610, a620, a660, a670, etc Nam Programming : Nam Set: Menu, 6, * Nam Set: ##3238, ok Nam Set: ##SPC (##000000), ok Service Menu: Menu, 9, * Test Mode: 47*68#13580 Test Mode: 47*869#1235 Samsung X, E, V, S-series (korean models), e250, v420, s350, etc Nam Programming : Nam Set: 6548#0**4#6 Nam Set: 47*869#08#9 Nam Set: 74153697193 Test Mode: 5809540*45680 (88 - EFS reset) Debug Menu: Menu(hold 2sec)+0, 6725 or 9720 or 1973 or 0415 Debug Menu: Menu+0(hold 2sec), 6725 or 9720 or 1973 or 0415 Debug Menu: Home(top of keypad)+0, 6725 or 9720 or 1973 or 0415 Samsung sch-411, 611, n105, a100, a300, a2000, etc Nam Programming : Nam Set: 47*869#08#9 Nam Set: Menu+60 Test Mode: *759#813580 Test Mode: 5809540*45680 A-key: Menu+0, 25## External Audio: Menu+0, #### Debug Menu: Menu+8, 0415 or Spc Debug Menu: Menu+9, 0415 or Spc Brief NAM Programing: Menu+40,626 (not all version) LCD Contrast: Menu+45 (not all version) SIO Mode: Menu+49 SIO Mode: Menu+69 Samsung N356 (India version) Nam Programming : Test Mode: Menu, 5, down arrow, * Test Mode: **00## (in some flashes) Samsung i700, etc Nam Programming : Nam Set: Go to start and select "PHONE" from the drop down menu, dial #83587 Samsung i300, etc Nam Programming : 1. Tap on the Phone Icon with stylus 2. Press #907*9#0 ENTER LOCK should appear on screen 3. Enter OTKSL 4. SVC MENU will appear press 1 5. Enter 10 digit MIN and then press SAVE 6. Press SAVE again 7. Press 3 and then press SAVE 6 times 8. Enter the HOME SID and press SAVE once 9. Press END key twice <<KYOCERA>> Kyocera 2345, 3035, 5135, 6035, Se47, KX, KE - series, etc Nam Programming : Nam Set: 111111+Jog Dial(Ok) CAI Change: ##7738,ok Enable TTY: ##889,ok Life Timer: ##786,ok A-key: ##2539,ok Tips: On some kyocera handsets the factory service module has not been disabled and the phone can be programmed without the Spc by inputting: Nam Set: ##333333 menu (service) Qualcomm qcp-800 Nam Pogramming : Nam Set: Menu+3+0+Spc Field Test: Menu+7+0+Fsc <<SANYO>> Sanyo 4900, 5150, 5300, 8100, etc Nam Programming : Nam Set: ##Spc+Ok+Key Down+Ok Advanced Setup: ##3282+Ok+Key Down+Ok+Msl A-key: ##2539+Ok+Key Down+Ok Version: ##**837+Ok+Key Down+Ok Debug Menu: ##FSC+Ok+Key Down+Ok Airtime menu: ##8463+Ok+Key Down+Ok Change CAI: ##7738+Ok+Key Down+Ok Vocoder: ##8626337+Ok+Key Down+Ok Reverse Logistic: ##786+Ok+Key Down+Ok Set IP Address: ##2769737+Ok+Key Down+Ok TTY On/Off: ##889+Ok+Key Down+Ok Ready Link: ##4636+Ok+Key Down+Ok Browser Init On/Off: ##4682+Ok+Key Down+Ok Picture Token: ##25327+Ok+Key Down+Ok Unknown Code: ##5282277+Ok+Key Down+Ok (SPC=000000, FSC=040793) Sanyo scp-A011, smp-A017, etc Nam Programming : Nam Set: F9(3 beep) + 0*72696#767 <<AUDIOVOX / UTSTARCOM>> Audiovox 4000, 9000, 9100, 9155, 9500, etc Nam Programming : Power the phone ON and wait until the little light on top goes out, then press: Nam Set: 289,Fcn, #,1 Service menu: Fcn,0,0, FSC Power the phone ON and press: Test Mode: Hold (2,*,Rcl) + Power Test Mode Commands: 99 - download - flash phone 124 - inam data write 125 - version 126 - get ESN 127 - get SPC 128 - get User lock 129 - is WFTV data write 137 - get FSC code 138 - NPcode (nam program code) 139 - dscode 141 - restart 218 - Read_Addr 000 - is cdma mode 001 - is fm mode 002 - is pcs mode 008 - is reg read addr 020 - is lna_range Audiovox (Hyundai) cdm-100, 130, 135, 8300, 8500, 8600, 8910, etc Nam Programming : Nam Set: ##20022002, end Read user lock: #5625*, end Port settings: ##7678, end DM baud rate: ##2283, end DM mode enable: **1004, end DS mode enable: **1005, end Misc. Test: ##27752345, end S/W Test1: ##27732726, end S/W Test2: ##2240, end Debug screen: ##2773, end Clear MRU: ##6782, end Rfnu_Contents: ##2250, end ?????: ##1133, end ?????: ##1144, end P_Rev: ##7738, end GPS Test: ##4771, end A-Key: 2538** SMS Eng: ##767364, end Battery_adc: ##2768, end Tests: ##1122, end Audiovox 8610, 8910, etc Nam programming : Name Set: ##847446, end, 111111 Audiovox pcx-3500xl Nam Programming : Nam Set: ##2726+Send+1998+1+Spc+1 Audiovox-107 Nam Programming : Nam Set: 45680*47*869#1 Audiovox CMP-3 Nam Programming : Nam Set: 45680*47*869#1 Dm Mode: Menu, 6, 6 Audiovox 9950 Nam Programming : Nam Set: ##3282 Audiovox Z800 (Audiovox 7900, Sharp) Nam Programming : Nam Set: m + # + envelope key + * + 1 Audiovox Thera (Toshiba 2032) Nam Programming : Thera Nam Programming User Manual - nam_thera.pdf Audiovox (UTStarcom) PPC 6600, 6700, etc Nam Programming : Nam Set: ##SPC + Send Nam Set: #*#SPC + Send Nam Set: ##SPC# DM mode: ##3424 + Send DM mode: #*#3424 + Send DM mode: ##3424# Programming User Manual - programming_instructions.pdf <<MOTOROLA>> Motorola 7760, 7860, 2260, 8160, etc Nam Programming : Nam Set: Fcn,0000000000000, Rcl Nam Set: 74663#, Fcn, Fcn Test Mode: Fcn, 00**83786633, Sto Motorola v60c, v120c etc Nam Programming : Nam Set: 74663#, Menu, Menu, Spc Nam Set: Menu, 073887, * (type quickly) Test Mode: Menu, 073887*, Spc Debug Mode: ##33284 Force the phone into DIGITAL ONLY mode: 1) ##33284 (Debug) 2) RIGHT Softkey (Next) Twice 3) Down arrow 10 times to "PrefMod" 4) RIGHT Softkey (Change) until you see "DigOnly" 5) LEFT softkey (Exit) 6) MENU then LEFT Softkey return to idle screen 7) ##33284 (The last 4 will not display if you have done it correctly) Motorola Razr V3C Nam Programming: Nam Set: 74663 # clr clr Nam Set: #073887* , then SPC Motorola Q Nam Programming: Nam Set: [Send] + 074663 + [Send] + [Send], Selecct NAM# Motorola t182, c210, etc Nam Programming : Nam Set: ##298645665, end Short Nam: ##073887, sto Debug Menu: ##1111, end Service Menu: ##2222, end Sound NS/EC on/off switch: ##1113, end Motorola v710, v730, v740, ms150, etc Nam Programming : Nam Set: 8378*# + press 3 times NATE (spc - 071082) Test Mode: Menu, 073887*, Spc Service Menu: #758353266#646# Motorola StarTac 2004 Nam Programming : Nam Set: 5759789*#, press "Rec" button 3 times, (spc - 915037) Motorola ms200, ms400, ms800, etc Nam Programming : Nam Set: 5759789*#, press "Camera" button 3 times, (spc - 915037) Nam Set: 246791538*#, press "Camera" button 3 times, (spc - 915037) Motorola v6060 Nam Programming : Nam Set:147*369#456*0# MOTOROLA TEST MODE : v60, c120, c331, etc: 1) Turn on the phone. Press MENU 0 7 3 8 8 7 * 2) The phone will require you to "Enter a Security Code", press 000000, OK 3) Scroll down to "Test mode" choose SELECT. Scroll down to "Enable" choose SELECT. Your phone is now in test mode. 4) Signal strength is the 3_rd number down on the left hand side of the screen. 5) To toggle between regular mode and test mode: Press MODE then quickly press the BUTTON DIRECTLY TO THE LEFT OF MENU. 6) To turn off the test mode the phone must be in regular mode, then follow the above sequence and scroll down to where it says "DISABLE" instead of "ENABLE" and choose select. <<NOKIA>> Nokia 3280, 3285, 3580, 3585, 5185, 6185, 8280, etc Nam Programming : Nam Set: *3001#12345# Software Version: *#837# Software Version: *#9999# Esn Number: *#92772689# Restart Phone: *#75681# Restart Phone: *#75682# Nokia 8887 Nam Programming : Nam Set: *3001#12345# Version: *#0000# Evrc: *#8378# Esn/Data/Timer: *#92772689# SID: *#743# Nokia 8587 Nam Programming : Nam Set: *#626#7764726# A-Key: #8159357022#4579# (26 digits) A-Key: #8159357022#4547# (20 digits) Version: *#0000# Version: *#837# Vocoder: *#3872# Change language: Menu 5, 3, 1 Change DM mode: *#7678# Debug Screen: *#8378# Debug: *#8380# Field Test Menu: *#83788# SPC Unlock, Factory Reset : Full Factory Reset: *#7370# Resets all settings including non-user changeable items (like SPC) NOKIA TEST MODE: 51xx, 61xx, 71xx, 3285, 63xx, etc : 1) Turn on the phone. Press *3001#12345# 2) Scroll up to where it says "Field Test" and choose SELECT 3) Highlight "Enable" and choose OK. Turn the phone off then back on. 4) If the test mode screen does not show up press MENU and scroll down to "Field Test" choose SELECT. Press 0 1 then choose OK. 5) Lower left or upper left number is the signal strength. 6) To turn off the test mode press MENU and scroll down to where it says "Field Test" choose SELECT. Press 0 0 and then choose OK. 3360, 6360, etc : 1) Turn on the phone. Press *3001#12345# 2) Scroll up to where it says "Field Test" and choose SELECT 3) Highlight "Enable" and choose OK. Turn the phone off then back on. 4) If the test mode screen does not show up press MENU and scroll down to "Field Test" choose SELECT. Press 2 1 0 1 then choose OK. 5) Lower left or upper left number is the signal strength. 6) To turn off the test mode press MENU and scroll down to where it says "Field Test" choose SELECT. Press 2 1 0 0 and then choose OK. <<LG>> Lg LX,VX-series, VX4400, VX6000, etc Nam Programming : Nam Set: ##Spc(#) Nam Set: Menu, 0 Advanced Settings: ##2342(#) Vocoder: ##8626337,ok(#) CAI Change: ##7738,ok(#) Enable TTY: ##889,ok(#) A-key: ##2539,ok(#) Reset (Life time, Clear Memory, etc): ##786,ok(#) lgc-300, etc Nam Programming : Nam Set: Menu, 9, Spc A-key: Press "Sto" 3sec, 2539** lgc-330w, etc Nam Programming : Nam Set: Menu, 4, 0, Spc A-key: 2539** lgc-510, v111, etc Nam Programming : Nam Set: Menu, 3, 0, Spc A-key: 2539** lgc-500, 800w, etc Nam Programming : Nam Set: Menu, 9 , 0, Spc Debug Mode: Menu, 7, 0, Fsc Debug Mode: Menu, 8, 0, Fsc A-key: 2539** <<ERICSSON / SONY-ERICSSON>> SonyEricsson T608, etc Nam Programming : Nam Set: 923885, joystick >, 111111 Nam Set shot: 987, joystick >, 111111 Nam Set long: 222652, joystick >, 111111 Vocoder: ##8626337, joystick >, 111111 Debug screen: ##33284, joystick > Life Timer: ##786, joystick > SW ver: 9#4#3#, joystick > Edit Profile: ##3282, joystick > Service menu: *#06* Ericsson A1228c, T61, etc Nam Programming : Short NAM: 987+Menu Long NAM: 923885+Menu+Spc CDMA Mode: 904093+Menu Analog Mode: 904095+Menu QNC: 904097+Menu Debug Screen: 904090+Menu DM Mode: 904050+Menu <<EPSILON / COMPAL>> Epsilon vc-5x, Compal 1100, etc Nam Programming : Nam Set:: **321456987## Short Nam: **147258963## Service Menu 1: **1232580## Service Menu 2: **078987## Service Menu 3: **1234756## Show SPC: **3214569871472365## Version: **1470963## Debug: **000000## A-key: 2539** Reset: **14789## <<SK TELETECH>> Sky All Models Nam Programming : Nam Set: #7583538324#626# Nam Set: *759#364*7388464# Min simple mode: #758353266#646# Irm simple mode #758353266#476# Voice memo: #8767#277# Test Mode: #7583538324#8378# A-key: #758353266#2539# Service Menu: Menu+4+0+Spc Service Menu: Menu+5+0+Spc <<WITHUS / MODOTTEL>> Withus wce-100, 200, 300, etc Nam Programming : Nam Set: ##948487+Save Nam Set: ##948482+Save ESN write: ##66835+Save (wce200 only) SMS Settings: ##76766 NVM Rebuild: ##777464 <<GTRAN>> Gtran gcp-2000 Nam Programming : Nam Set: 01#737+Spc Debug Menu: 01#324+Spc Debug Mode: 01#727 Test Mode: 01#764+Spc System Test Mode: 01#768+Spc Gtran gcp-5000 Nam Programming : Debug Mode: 01#727+Spc Test Mode: 01#765 <<HYUNDAI>> Hyundai hwp-110 Nam Programming : Nam Set: #86904**89397# DM Mode: ##2740* (Open phone, inter code, close phone) Hyundai hgc-120, 130, 200 Nam Programming : Nam Set: #86904**89397# Hyundai hgc-310, 600, 610 Nam Programming : Nam Set: ##20022002, end, 1, Spc Code Field Test: ##20022002, end, 1, Master Code Hyundai Curitel h100, 150, hx510b, 520, etc Nam Programming : Nam Set: ##20022002, end, 1, Spc Code Field Test: ##20022002, end, 1, Master Code A-key: 2539** Debug Menu: ##27732726, end Sar Test: ##27752345, end Baud Rate: ##36**, end DM mode enable: **1004, end DS mode enable: **1005, end Test Bell/Voice/Led/Dot: ##1122, end RF Mode: ##2240, end Ras Ram: ##2774, end Cmux1: **0481, end Cmux2: **0482, end RX Mode Fax: **0492, end RX Mode Data: **0491, end RX Mode Reset: **0490, end <<HUAWEI>> Huawei ETS-668, 678, 688, etc Nam Programming : Debug Mode: ##44+Menu Debug Screen: ##33+Menu CDG2 Test enable: ##234+Menu CDG2 Test disable: ##432+Menu China Lang Select: ##123+Menu Blocking Debug Code: ###888+Menu Home System Only On: ##461+Menu Home System Only Off: ##460+Menu Master Code for all Huawei models is - 309296 <<PANTECH / CURITEL>> Pantech hx-525b, 550, 570, 575, etc Nam Programming: Nam Set: ##13*92*#62* + Pwr Debug Mode: ##*193*762534#* + Pwr (R-UIM mode disable) Debug Mode: ##27732726 (R-UIM mode enable) DM Mode Enable: ***18*#826* Full Reset: ##03*934#9367*192#397#7412569746 + Pwr MultiTest: ##22635*262* + Pwr Cmux1: ***12*#811# + Pwr Cmux1: ***37*#922* + Pwr RX Mode Data: ***83*#247 + Pwr RX Mode Reset: ***64*#133# + Pwr DS Mode On: ***12045#*# + Pwr RF NV Init: ##0*#*63861829372# + Pwr RAS_RAM: ##3*13091#1279#* + Pwr <<TREO>> Palm One Treo 600, 650, 700, etc Nam Programming : Nam Set: ##SPC + Send Nam Set: #*#SPC + Send Nam Set: ##SPC# DM mode: ##3424 + Send DM mode: #*#3424 + Send DM mode: ##3424# Debug: ##33284 Programming User Manual - programming_instructions.pdf Resetting Treo - resetting_treo650.doc <<AXESSTEL>> P800, T800, P1900, T1900, etc Nam Programming : Nam Set: 47*68#47*869# DM mode: ##9* + Send Data cable select: menu + 7 + 1 + # Data Manager: **##11 Data (Internet): **##13 Data USB: **##32 <<VK MOBILE>> VK-100C, 110C, 200C, etc Nam Programming : Nam Set: 153147539741593 Test Mode: 153147539123258 (88 - clear efs (set language to korean before)) <<GIGA TELECOM>> Z510, Z710i(gcd-456) Nam Programming : Nam Set: Menu+0+Spc <<AnyDATA>> AMC450 Nam Programming : Nam Set: *74269#*748#96148063+SEL <<ZTE>> ZTE C150, C160, C170, C180, C220, etc Nam Programming: Nam Set: *983*3641# (R-UIM mode) Nam Set: #1463*389* ZTE C201 Nam Programming: Nam Set: *983*7358# <<UBIQUAM>> U100, U105, U200, U300, etc Nam Programming : Nam Set: ##3435871 BREW Set Menu: ##8242739 System Test: ##33582 Handset Test: ##3435873 Handset Test: ##3435875 Factory Test Mode: ##3435874 <<SYNERTEK>> Synertek S200 Nam Programming : Nam Set: Menu+0+Spc A-Key: 2539**+Save Test vibro/rx/tx: ##5555+Save Debug Screen: ##33+Save Debug Screen: ##523+Save RF Test: ####+Save LCD type: ##325+Save Synertek S500 Nam Programming : SAR Test Strife test: *#0000# Debug screen: *#8378# Clear LCD: *#848378# Debug menu: *#443336# (R-UIM mode) CDG , Service option: *#234# Function Test, LCD Contrast: *#878# <<SONY>> Sony CM-M1300, 3300, Z200 Nam Programming : Nam Set: 111111+Ok(Jog Dial)+Select+Programming+Ok+Spc |
The Following 26 Users Say Thank You to gsmpointhrp For This Useful Post: |
05-14-2008, 16:17 | #10 (permalink) |
Junior Member Join Date: Mar 2008
Member: 738907 Status: Offline Thanks Meter: 0 | Problem with SGH-X820 and E250... Hi, i'm trying to do one of the following: "Samsung X, E, V, S-series (korean models), e250, v420, s350, etc Nam Programming : Nam Set: 6548#0**4#6 Nam Set: 47*869#08#9 Nam Set: 74153697193 Test Mode: 5809540*45680 (88 - EFS reset) Debug Menu: Menu(hold 2sec)+0, 6725 or 9720 or 1973 or 0415 Debug Menu: Menu+0(hold 2sec), 6725 or 9720 or 1973 or 0415 Debug Menu: Home(top of keypad)+0, 6725 or 9720 or 1973 or 0415 " on my X820/E250 and nothing work for me.... i.e. i hold the Menu (top left button) in my E250 for 2 sec and than pressed 0 and nothing happaned.... any idea what to do ? please hhhheeeelllppp |
06-01-2008, 12:00 | #15 (permalink) |
Member: 416286 Status: Offline Sonork: 100.1622339 Thanks Meter: 759 | If you pplz like my post than don't forget to hit thanks button |
The Following User Says Thank You to gsmpointhrp For This Useful Post: |
all cdma secret codes | sainesh | QUALCOMM Models (3G) | 27 | 04-05-2010 23:52 |
need huawei C5080 all secert code or engineer code | kyaw8719 | Various CDMA/TDMA Cell Phones | 0 | 03-01-2010 11:26 |
All cdma secret code | logicmobile | Nokia CDMA | 1 | 07-01-2009 09:55 |
HOT,All Hard reset,Secert Codes,Cables Finder,Unlock code Here | GsmunlockArena | Universal GSM Software | 48 | 06-19-2009 07:13 |
all cdma secret codes | sainesh | Nokia CDMA | 9 | 08-07-2007 04:21 |
