04-28-2006, 16:03 | #1 (permalink) |
Registered User Join Date: Sep 2002
Member: 15866 Status: Offline Thanks Meter: 192 | nokia 6225 cdma prl problem i have full flash but after activatin no signal i flash with jaf and in *#837# prl showing none please guide me briefly |
04-28-2006, 20:36 | #2 (permalink) | |
Product Supporter Join Date: May 2004 Location: INDIA Age: 55
Member: 65063 Status: Offline Thanks Meter: 2,419 | Quote:
use dku2 usb detect it and upload tune and prl ,phone will work fine wbr aksingh | |
04-29-2006, 00:27 | #3 (permalink) | |
Junior Member Join Date: Apr 2006 Age: 44
Member: 257815 Status: Offline Thanks Meter: 2 | Quote:
I forget exactly which version it was, but I think it was like blah_blah_98 or something. If you need the tuning file you can load it off another 6225 and save it to your HDD. If you don't have it by Monday drop me a PM and I'll send it to you. Can't now because I'm off for the weekend (!!!!!!!) and out of the office. | |
04-29-2006, 19:38 | #5 (permalink) | |
prl is "prefered roaming list" if u have GTI or PBB then u can easily read prl from any nokia phone i.e from ur country opearator so its of no use to upload prl from my end. Soon i il post how to read write spc,prl,pri,eri and other phone settings by diego or phoenix. wbr aksingh | |
05-11-2006, 19:17 | #7 (permalink) | |
NOW GOTO MANAGE CONNECTION AND SET THE DESIRED PORT ,SAY COM 1 FBUS ,IF U R HAVING DKU5 CABLE,AND USB CONNECTION IF U R HAVING DKU2 USB REMEMBER:ALL BLACK AND WHITE HANDSETS , BELOW 6255,THEY ARE DETECTABLE ON DKU-5 SERIAL ONLY. NOW SCAN FOR HANDSET ,UR SOFTWARE MUST SHOW THE DETAILS OF CONNECTED HANDSETS GO TO PHONE SETTING FOR READING AND WRITING PRL,PHONE SETTING ETC FOR TUNNING GO TO RF PARAMETER AND READ ALL PARAMETER,THAT IS UR TUNE FILE TO RESTORE NETWORK...... WBR AKSINGH 09810222476 | |
05-13-2006, 10:31 | #8 (permalink) |
Member: 15866 Status: Offline Thanks Meter: 192 | i have serial dku cable and gti and i manage connection by fbus com 1 and scan successfully but here is nothing any option for read write prl please tell me the good way 2270 mobile model now |
05-17-2006, 07:56 | #12 (permalink) | |||
Insane Poster Join Date: Nov 2005
Member: 199488 Status: Offline Thanks Meter: 5 | Quote:
Did do u have use one time diego in win 98 with handset serial connected Quote:
Link are workinng http://forum.gsmhosting.com/vbb/show...2&postcount=89 B.R | |||
05-26-2006, 16:20 | #13 (permalink) |
Member: 259063 Status: Offline Thanks Meter: 2 | hello! friends pleases help me i need nokia cdma 6225 chinese flash files MCU Sw: V H175_03w24_24.nbr 05-12-2003 RH-27 (c)NMP PPM Sw: V H175_03w24_24.nbr 05-12-2003 RH-2 C Prd.Cd: 0511670 Bpr.Cd: 0509597 Pro.Sn: GZA013033 HW : 5000 PCI : 1099 UEM : 8 UPP : 4400 RFIC : DSP400_LAN_03w48_00_UP3f+i DSP : DSP400_LAN_03w48_00_UP3 LCD : LDS172 ESN : 060-14291764 (3CDA1334) SPC : 000000 XTKSL : 000000 my email:[email protected] or [email protected] thank you!!!! |
06-06-2006, 05:13 | #14 (permalink) | |
Also, I've not had the same luck with newer versions of Phoenix. Every time I've tried any but that one that ends in 98 it's not let me write the tuning file. Curious is all, thank you for your feedback | |
06-14-2006, 04:51 | #15 (permalink) |
Junior Member Join Date: May 2006 Location: Indonesia
Member: 276718 Status: Offline Thanks Meter: 2 | i confuses using diego or phoenix cdma ams.. my question" 1. can that software work without dongle like pbb or gti? 2. can that softawre read spc lock by provider? thanks before |
nokia 6275 cdma camera problem | ajay.vijay | Nokia Hardware & Hardware Repair | 0 | 01-16-2010 15:28 |
nokia 6275 cdma camera problem | ajay.vijay | Nokia Hardware & Hardware Repair | 0 | 01-16-2010 15:21 |
nokia 6275 cdma camera problem | ajay.vijay | Nokia Hardware & Hardware Repair | 0 | 01-16-2010 15:18 |
Refurbished Nokia 6225 CDMA Phone (unlocked) | IPMART | ipmart WebShop | 0 | 12-03-2009 06:20 |
Nokia 3125 CDMA Tower Problem | mann_s_love | Nokia CDMA | 3 | 05-24-2007 06:12 |
