Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Nokia > Nokia CDMA
Old 01-06-2008, 14:31   #1 (permalink)
SAN INFOTECH's Avatar
Member: 484665
Sonork: 100.1578012
Thanks Meter: 175
Nokia Cdma 2280 Head Free Problem
Any Body Have 2280 Head Free Icon Solution
The Ant
Old 01-06-2008, 14:49   #2 (permalink)
wie
Member: 667899
try to clean up the head set adaptor for the top part .if its not working then try to change ic emi that control the tomahawk.that should fix your problem.
Old 01-06-2008, 18:29   #3 (permalink)
Member: 480959
Thanks Meter: 49
use another head phone connector and also clean bottom connector u will get out of it
Old 01-08-2008, 08:06   #4 (permalink)
Member: 600307
Thanks Meter: 5
something like happens with me and i have tried everything but nothing happens.
some one suggest me to just restore factory setting.
this works for me
and the handsfree simbol doesn't appears again
so if u have done everything why not to restore the setting
hope this will work
Bunty
Old 01-20-2008, 16:05   #5 (permalink)
Member: 288188
Thanks Meter: 24
remove "R" around HF conector but u can't use HF anymore
nokia 2112,2280,3105 and other cdma flash file with Diego 3.0 cracked akhileshbaghel Nokia CDMA 243 09-15-2010 18:59
Nokia CDMA 2280 NETWORK PROBLEM...? amit123 Nokia Hardware & Hardware Repair 0 03-11-2009 16:30
Nokia CDMA 2280 NETWORK PROBLEM...? amit123 Nokia Hardware & Hardware Repair 0 03-11-2009 16:29
2280 nokia cdma nijascm Nokia CDMA 3 05-14-2006 13:26
Page generated in 0.18400 seconds with 9 queries
