Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Nokia > Nokia CDMA
Old 01-28-2008, 16:47   #1 (permalink)
Member: 691498
Thanks Meter: 3
NOKIA1325 show Only Battrey Point & Set is restart.
How Solw this problem pls help.
Old 01-28-2008, 18:23   #2 (permalink)
rk19801's Avatar
Member: 238252
Thanks Meter: 81
i have same problem in 1255..........
Old 01-29-2008, 04:14   #3 (permalink)
neetika99's Avatar
Member: 588837
Thanks Meter: 142
first check its connecting or not with bitpim?
Old 01-31-2008, 05:00   #4 (permalink)
Member: 243866
Thanks Meter: 10
not connecting with bitpim
Old 01-31-2008, 05:34   #5 (permalink)
alfin5557's Avatar
Member: 176999
Thanks Meter: 32
1325 show batrey only,flash with CCS12R033 cable use motorola T190.....................problem solved
Old 02-01-2008, 17:51   #6 (permalink)
Member: 429983
Sonork: 100.1604691
Thanks Meter: 59
sir please connect swithoff handset in download mode then flash it your problem will be 100% solved
Old 02-02-2008, 06:57   #7 (permalink)
~AKSingh~'s Avatar
Member: 65063
Thanks Meter: 2,360
for 100% free working solution for all ccs models like 1255,1325 ......
contact or pm
wbr
aksingh
The Following User Says Thank You to ~AKSingh~ For This Useful Post:
Old 02-02-2008, 10:16   #8 (permalink)
rekha1255's Avatar
Member: 333796
Sonork: 100.1587155
Thanks Meter: 80
FLASH BY CCS12R033 100% ok
Old 02-02-2008, 10:26   #9 (permalink)
rekha1255's Avatar
Member: 333796
Sonork: 100.1587155
Thanks Meter: 80
flash with CCS12R033 then chek 100% ok !!!!!
Old 10-26-2008, 07:57   #10 (permalink)
thushdt's Avatar
Member: 544160
Sonork: 100.1603100
Thanks Meter: 176
How the phone swith off in downloade mode
Old 11-01-2008, 14:39   #11 (permalink)
pavas's Avatar
Member: 792200
Thanks Meter: 63
open CCS12R033 and conect ur set in offline mode by pressing *+3+power on set will be connect then flash it problem solve 100 %
Old 11-06-2008, 09:27   #12 (permalink)
Member: 247765
Sonork: 100.1607102
Thanks Meter: 7
how to flash 1325 for a better solution...
coz' i have a same problem.....
i try with offline mode _ *+3 and/or *+5...
but still won't read with original flasher....
plese......
The Following User Says Thank You to palax For This Useful Post:
Easy way 3110 show only nokia logo & restart mr. uem Nokia Base Band 5 ( BB-5 ) 20 02-25-2012 16:23
NOKIA1325 & 2505 show Only Battrey Point & Set is restart. swechacnu Nokia CDMA 16 02-17-2010 05:09
W200i bord is short & set is on suntysunty Sony Ericsson Hardware Repair 7 04-29-2009 18:59
x160 when call set is restart shaheb_anl UST Pro II 5 06-02-2008 05:28
How to Connect K750i Test Point & Where Is The Test Point Location MT_LBN Sony Ericsson 0 02-03-2006 00:24
Page generated in 0.41413 seconds with 9 queries
