03-07-2006, 06:58 | #3 (permalink) | |
Product Supporter Join Date: May 2004 Location: INDIA Age: 55
Member: 65063 Status: Offline Thanks Meter: 2,419 | Quote:
regards aksingh | |
03-07-2006, 07:04 | #4 (permalink) | |
No Life Poster Join Date: Jul 2004 Location: Cuttack,India Age: 54
Member: 71721 Status: Offline Sonork: 100.106320 Thanks Meter: 139 | Quote:
03-07-2006, 12:08 | #5 (permalink) |
Freak Poster Join Date: Feb 2006 Location: India
Member: 232566 Status: Offline Thanks Meter: 150 | man with this u can only caliberate the parameters as said by avithakur and u can not flash with it.to flash u have to buy PBB and u know how much it costs it's Some $$$. |
03-07-2006, 17:50 | #6 (permalink) | ||
Insane Poster Join Date: Nov 2005
Member: 199488 Status: Offline Thanks Meter: 5 | Quote:
UFS*saras SW* can done ur flashing procedure without any complication B.R | ||
03-12-2006, 22:52 | #9 (permalink) |
Member: 199488 Status: Offline Thanks Meter: 5 | @inder thx friend u seems to be right we need there other FTP availabel to make it possible for all members to sharring @Nacam if u mean u have lust to done it by rapidshare. pls.... do email me Cracked phoenix A15 required systeme WIN 98 99.0 MB (103,907,328 Bytes) for downloading !!! its Free without any support 2-Crack_DLLs_GSM_Par..> 04-Mar-2006 22:03 864k CRACK DONGLE.exe 04-Mar-2006 22:04 399k DLL/ 04-Mar-2006 21:48 - Diego_02_14_SP1_009.exe 04-Mar-2006 22:23 5.1M Framework/ 04-Mar-2006 21:57 - INSTRUCCIONES.txt 04-Mar-2006 22:23 1k PASO 1 Diego_Service..> 05-Mar-2006 00:41 17.0M dongle/ 04-Mar-2006 22:00 - phoenix_service_sw_a..> 06-Mar-2006 19:19 66.0M Copia de DK2DRVS.isu 04-Mar-2006 15:12 13k Copia de DK2WIN32.DLL 04-Mar-2006 15:13 390k Copia de DK2WN95.386 04-Mar-2006 15:13 29k Copia de factoryset.dll 04-Mar-2006 15:14 268k Copia de factorysetf..> 04-Mar-2006 15:15 204k Copia de fastnam.dll 04-Mar-2006 15:16 524k Copia de fpi32.dll 04-Mar-2006 15:17 420k DK2DRVS.isu 04-Mar-2006 15:17 13k DK2WIN32.DLL 04-Mar-2006 15:18 390k DK2WN95.386 04-Mar-2006 15:19 29k factoryset.dll 04-Mar-2006 15:20 268k factorysetfn.dll 04-Mar-2006 15:21 204k fastnam.dll 04-Mar-2006 15:22 524k fastnamserver.dll 04-Mar-2006 15:23 148k fpi32.dll 04-Mar-2006 15:24 420k gsmgrfcontrolfn.dll 04-Mar-2006 15:25 336k gsmmrfcontrolfn.dll 04-Mar-2006 15:26 240k irunin.bmp 04-Mar-2006 15:26 8k irunin.dat 04-Mar-2006 15:26 95k irunin.ini 04-Mar-2006 15:26 18k irunin.lng 04-Mar-2006 15:26 16k mti32.dll 04-Mar-2006 15:27 212k mti32ext.dll 04-Mar-2006 15:27 180k nam.dll 04-Mar-2006 15:28 292k namserver.dll 04-Mar-2006 15:28 164k phoenix.exe 04-Mar-2006 15:29 192k tdmasrfcontrolfn.dll 04-Mar-2006 15:30 260k B.R |
03-27-2006, 01:42 | #13 (permalink) |
Member: 199488 Status: Offline Thanks Meter: 5 | do you have some problemes to upload prl or TUN file and you are not im known how to fix it ? using diego and phoenix you have the possibility to done it there its all what u need for installing cracked version here is the download link for cracked A15 its without any support A15 ENJOY Last edited by Don OMAR; 03-27-2006 at 01:52. |
03-30-2006, 17:09 | #14 (permalink) |
Junior Member Join Date: Mar 2006
Member: 248327 Status: Offline Thanks Meter: 0 | WOOHOO!! It all working 100% ---> Hello my friends! I have the solution to installing Diego/Phoenix on a Windows 2000 machine. It should also work very similar on XP... First make sure to clean up any old failed installations then follow this procedure to install. MAKE SURE YOU ARE LOGGED IN AS "ADMINISTRATOR" USER DURING THIS INSTALLATION. 1: From the files provided by other members, extract/find the following files DK2DRVS.isu (13kb) DK2WIN32.DLL (390kb) DK2WN95.386 (29kb) mti32.dll (212kb) mti32ext.dll (180kb) These should be in the cracks provided for phoenix, make sure to get the correct byte size!!! Extract these files into \WINNT\system32 !!!VERY IMPORTANT!!!! After you put these files in, right click on each one and select Properties.. Select the "security" tab, uncheck the "Allow inheritable permissions from parent blah blah..." All the settings for the file should be cleared, then add "Everybody" to have only read and execute permissions on this file. Once you have done this, the installer cannot modify the DK2* files anymore!!!...Now proceed... 2: Install Diego 2.14 by executing the file: Diego_Service_SW_C2_14_004.exe (17,434kb) 3: Restart PC 4: Install Diego service pack by executing the file: Diego_02_14_SP1_009.exe (5,267kb) 5: Restart PC 6: Install Phoenix a15 by executing the file: phoenixa15.exe (67,603kb) NOTE: A dialog appears asking if you want to upgrade the DK2 drivers. I have tested both keeping the old version and upgrading, both seem to work. I choose not to upgrade (because I'm sentimental...) for safety. Also, some errors appear saying that DK2*.dll cannot be accessed, just click "ignore" buttons. Also, DO NOT replace the files in the \Framework folder as the instructions in the crack says.- this will break phoenix!! Just keep the \Framework as it is installed. 7: Restart PC Now after you login, the setup will continue and register all the dll's. Click ignore if any errors show up and ok if the DesKey not found box shows up. The files you placed into the \winnt\system32 folder should not have changed (because it's not allowed by the system [IMG]http://www.************.com/forum/images/smilies/biggrin.gif[/IMG] ) So the setup should proceed without fatal errors... After I install Phoenix, my Diego can no longer connect with the phone. BUT, this does not matter because all the same functionality is found in Phoenix. Phoenix should now start without any errors and be able to detect your phone. Note that you MUST configure a connection first under the "manage Connections" menu. I hope these instructions will be of help. Thank you to all those people who shared files and links to make all this testing possible. [IMG]http://www.************.com/forum/images/smilies/biggrin.gif[/IMG] Many thanks to all people for the diego and phoenix links/files!!!!! |
04-05-2006, 18:18 | #15 (permalink) |
No Life Poster Join Date: Jul 2004 Location: GEORGIA,Tbilisi
Member: 75765 Status: Offline Thanks Meter: 722 | Ok, I managed to run phoenix by following those steps, but see the errors I got, P.S. I tried everything to connect my 7610 with DKU-2 cable with software without success ! |
phoenix 2008_44_5_36652 for download | gsm-lord | Nokia Base Band 5 ( BB-5 ) | 2 | 12-10-2008 13:15 |
**phoenix A15**pls link here | Ja\/\/aD | Nokia CDMA | 0 | 01-20-2007 21:26 |
**Wanted** link Phoenix A15...? | Ja\/\/aD | Nokia Digital Core Technology 4 ( DCT-4 ) | 5 | 12-17-2006 18:51 |
phoenix a15 2004.24.7.55.exe | TechPhone | Nokia CDMA | 0 | 01-24-2006 06:04 |
phoenix a15 crack | TechPhone | Various CDMA/TDMA Cell Phones | 5 | 10-18-2005 03:54 |
