03-07-2007, 04:41 | #1 (permalink) |
No Life Poster Join Date: Jul 2005 Location: Auckland
Member: 160928 Status: Offline Thanks Meter: 338 | 6255 mic not working thanks |
The Following User Says Thank You to MUTUAL For This Useful Post: |
03-08-2007, 16:07 | #2 (permalink) | |
Product Supporter Join Date: May 2004 Location: INDIA Age: 55
Member: 65063 Status: Offline Thanks Meter: 2,419 | Quote:
wbr aksingh | |
The Following 9 Users Say Thank You to ~AKSingh~ For This Useful Post: |
03-22-2007, 03:27 | #4 (permalink) |
Junior Member Join Date: Mar 2007
Member: 473016 Status: Offline Thanks Meter: 0 | I have a unit with the same/simlar fault. The external large speaker will not work and the mic will not work. But if I use nokia external earpiece and mic it works fine. Obviously the two circuits are related. Thanks TEX |
03-22-2007, 04:36 | #5 (permalink) |
No Life Poster Join Date: Oct 2003 Age: 43
Member: 40602 Status: Offline Thanks Meter: 118 | For mic emif you could use hf-mic emif, but after that mic in handsfree will not working but it is better than main mic is damaged. I havent found a way to the jumper tricks since mic have mic bias that can only managed by an ic. This mic emif can be found in 6255,6235,2865,6265 so far this is i know. br, s1emens |
04-04-2007, 23:41 | #6 (permalink) | |
Member: 160928 Status: Offline Thanks Meter: 338 | Quote:
01-22-2008, 22:10 | #9 (permalink) | |
No Life Poster Join Date: May 2007 Location: "Alfa-Gsm"
Member: 507536 Status: Offline Thanks Meter: 75 | 6255i Microphone... Quote:
Hello mates i have two sets with same Mic problem, any soluition for this, i do not have any Mic Ic so if there is other solution will be apreciated.- Regards ..::Alfa-Gsm::.. | |
01-23-2008, 09:57 | #11 (permalink) | |
Insane Poster Join Date: Dec 2002 Location: delhi Age: 47
Member: 19333 Status: Offline Thanks Meter: 6 | Quote:
v3 mic not working display light ok keypad light not working | shani72 | Motorola Hardware Repair | 2 | 10-22-2009 08:15 |
1200 mic not work jampar ok bat not work pizzzzzh........................? | punitdodiya | Nokia Hardware & Hardware Repair | 5 | 09-08-2009 22:52 |
6255 mic not working | MUTUAL | Nokia Hardware & Hardware Repair | 0 | 03-07-2007 04:35 |
moto c 200 mic not working . want mic ways with picture | shahi | Motorola Hardware Repair | 0 | 03-01-2007 10:15 |
6630 mic not working need mic ways | ashok_kumar459 | Nokia Hardware & Hardware Repair | 3 | 02-13-2006 18:14 |
