tips to flash n1255 if ‘u have problem with n1255 only display battery indicator. and only have rj cable 1255. you can flash it use CCS12R019 with mt-box com emulator. - connected mt2com (mt-box com emulator) set: VBAT:3.6V VPP:0.0 - set port at control panel > Griffin Team Virtual Com enter Properties > Port Setting > Advance > check “Use FIFO” > set Receice Buffer fr 14 to 4, and Transmit Buffer fr 16 to 4 > OK - run CCS12R019 - insert rj 1255 cable to mt-box and the set - klick *+5+on > until set detected at active phone mode: COM2_Boot Loader Download Mode - browse f/w (active bundle) – use f/w as your own language: *.cbb otomatically detected file: Application, Language Pack dan File System - klick “Update” .. prosses.. done.. - release cable and check your set i’ve tested it.! |
Hi I hove N1255 UNC TAT TKS REL .CBB ;NO HAVE ......RH79BR014.004.YMN.CBB have you??? I buy 200$ my Email:[email protected] QQ:448058611 MSN:[email protected] TOM TKS!!! |
sorry bro.. i only have TKI_RH79BR0041_1255_v2.cbb (indonesia). |
1255 not responding i hv problem with 1255,when it was flashing , Application, Language Pack dan File System this step done after that when its reconnect again,.bar step its long time not change...n not responding ...phone is dead... i hv done ..again n again but it result same before the phone is ok what my problem |
tomlat ,Hello! You do not have TKI_RH79BR0041_1255_v2.cbb This document?I now need to document this flash? Can help the busy? Thank you very much |
