04-22-2008, 15:05 | #1 (permalink) |
Freak Poster Join Date: Jul 2005 Age: 73
Member: 157657 Status: Offline Thanks Meter: 70 | tips to flash n1255 and only have rj cable 1255. you can flash it use CCS12R019 with mt-box com emulator. - connected mt2com (mt-box com emulator) set: VBAT:3.6V VPP:0.0 - set port at control panel > Griffin Team Virtual Com enter Properties > Port Setting > Advance > check “Use FIFO” > set Receice Buffer fr 14 to 4, and Transmit Buffer fr 16 to 4 > OK - run CCS12R019 - insert rj 1255 cable to mt-box and the set - klick *+5+on > until set detected at active phone mode: COM2_Boot Loader Download Mode - browse f/w (active bundle) – use f/w as your own language: *.cbb otomatically detected file: Application, Language Pack dan File System - klick “Update” .. prosses.. done.. - release cable and check your set i’ve tested it.! |
04-22-2008, 16:57 | #2 (permalink) |
Junior Member Join Date: Apr 2008
Member: 745361 Status: Offline Thanks Meter: 1 | Hi I hove N1255 UNC TAT TKS REL .CBB ;NO HAVE ......RH79BR014.004.YMN.CBB have you??? I buy 200$ my Email:[email protected] QQ:448058611 MSN:[email protected] TOM TKS!!! |
04-28-2008, 15:56 | #4 (permalink) |
Junior Member Join Date: Mar 2006
Member: 242951 Status: Offline Thanks Meter: 0 | 1255 not responding i hv problem with 1255,when it was flashing , Application, Language Pack dan File System this step done after that when its reconnect again,.bar step its long time not change...n not responding ...phone is dead... i hv done ..again n again but it result same before the phone is ok what my problem |
how to flash a52? | fuadgsm | E-Gold Based Phones | 1 | 03-29-2010 18:48 |
how to flash e250i | adda2004 | Samsung Flashers, Software, Firmware. | 0 | 03-29-2010 12:26 |
Which box to flash N1255 CDMA? | shritelmob | Nokia Hardware & Hardware Repair | 3 | 08-17-2007 12:59 |
Tips To Make N73 To Music Edition | .::koolfriend4u::. | Nokia Base Band 5 ( BB-5 ) | 1 | 12-14-2006 01:27 |
Tips ! how to flash K500/K700 empty with Cruiser | danielkhaw | Cruiser Suite | 1 | 08-01-2005 07:37 |
