09-23-2008, 23:38 | #1 (permalink) |
Junior Member Join Date: Sep 2008
Member: 869391 Status: Offline Thanks Meter: 0 | voice call AT Command I am trying to make a voice call over a CDMA phone installed as a CDMA modem on my PC. Each time i send a dial command "ATD 123456789", its shows on the screen of the phone that its making a data call instead of a voice all. What i need to do is to be able to dial a voice call through a CDMA modem, but each i send the dial command, it makes a data call. I have tried two different phones. I am using Nokia 2115i and Nokia 6275. and they are both CDMA phones. I am sending AT commands through Hyper Terminal. Please, urgent assistance is required. Thanks. |
10-24-2008, 10:09 | #2 (permalink) |
Junior Member Join Date: Apr 2007
Member: 483145 Status: Offline Thanks Meter: 0 | Voice call Hi javajoe , What you are doing is right for data call. If you want to do Voice call Then put an" ; " at the end of number. ex: ATD9945037004; for voice call ATD9945037004 for DATA call. with regards, Harsha |
10-27-2008, 20:40 | #3 (permalink) |
Member: 869391 Status: Offline Thanks Meter: 0 | thanks for the response. i have been able to solve the situation. The problem i had then was that the phones i was using as modems do not support voice calls. So i had to get a modem that supports both voice and data calls. Thanks once again. Java Joe |
How to make a VOICE call using AT commands on siemens or se phones? | spaxa | GSM Programming & Reverse Engineering | 2 | 05-19-2007 21:28 |
AT commands for initiate 3G call & send AT commands to GPRS modem from computer need | codec_romania | GSM Programming & Reverse Engineering | 0 | 08-26-2006 07:53 |
how to listen a voice call in two phones with same number at a time | vikranth99 | Sim Cloning and Scaning | 2 | 01-15-2006 16:00 |
How can i get A50 Detailed Call Status using AT commands? | rdtesti | x1x to x45/x50 | 0 | 01-05-2005 15:34 |
AT Answering a voice call | talex | GSM Programming & Reverse Engineering | 1 | 10-29-2004 01:57 |
