05-06-2009, 10:55 | #1 (permalink) |
No Life Poster Join Date: Feb 2007
Member: 453916 Status: Offline Sonork: 100.1620840 Thanks Meter: 246 | A727 freeze after try to unlock here the result Loading flash file... Flash file loaded OK! Searching for UMTS phone... Phone detected! : COM6 Programming flash... ERR_WRITE_TIMEOUT Change [Flashing security] and try again! Elapsed Time (01:52) plss the help me out to solve my problems |
05-07-2009, 08:13 | #2 (permalink) |
Member: 453916 Status: Offline Sonork: 100.1620840 Thanks Meter: 246 | using USTPro2 to unlock my A707 and A727 for now about 1 month can't flash phone or unlock for the phone power up in freeze i can't flash this two phone plss i willy need a help out here why USTPro2 not solve this problems??? |
05-10-2009, 23:49 | #5 (permalink) |
Member: 453916 Status: Offline Sonork: 100.1620840 Thanks Meter: 246 | Flash with A707UCG4_Cingular.qst Loading flash file... Flash file loaded OK! Searching for UMTS phone... Phone detected! : COM6 Programming flash... Operation successful. Elapsed Time (05:04) Phone now is "Phone Freeze" Press "Direct Unlock" Reading data from box... Searching for UMTS phone on box port... Phone detected on box port! Error : MSL Bypass failed! Write PATCHED FLASH - or RPL - to phone and try again! Operation successful. Elapsed Time (00:02) plss help for the error above |
The Following User Says Thank You to chris2007 For This Useful Post: |
05-11-2009, 00:07 | #6 (permalink) |
Member: 453916 Status: Offline Sonork: 100.1620840 Thanks Meter: 246 | Flash with A727_43_cingular.qst Loading flash file... Flash file loaded OK! Searching for UMTS phone... Phone detected! : COM6 Programming flash... Operation successful. Elapsed Time (06:09) Press "Direct Unlock" Reading data from box... Searching for UMTS phone on box port... Phone detected on box port! Error : MSL Bypass failed! Write PATCHED FLASH - or RPL - to phone and try again! Operation successful. Elapsed Time (00:02 Insert sim card phone need network code what is the error above??? |
05-28-2009, 20:58 | #9 (permalink) |
Product Manager Join Date: Aug 2007 Location: Inside Java
Member: 574123 Status: Offline Sonork: 100.1581804 Thanks Meter: 1,839 | @chris2007 If u haven't solved your problem yet, then This is your Solution. After Flashing the phone with Regular Firmware from Support, Press Fast Direct Unlock. Only Use Direct Unlock if u flashed with Patched Firmware from Support. So your Mistake is Pressing Direct Unlock, u should press Fast Direct Unlock... Good Luck |
U880 dead after try to unlock it | adam92se | LG | 14 | 02-11-2009 13:14 |
MYC2-3 CHARGE HIMSELF after Try To Unlock | denard | SAGEM JTAG UNLOCKER | 7 | 04-26-2008 23:35 |
TV900 frist sim formated done but freeze after try to format sconed sim | Sudan-Mobiles | Infinity-Box | 3 | 02-21-2008 11:27 |
k750i dead after try to unlock | djouaka | Sony Ericsson | 5 | 03-11-2007 20:01 |
UB TEAM... How to repair the blink bb2020 after try to unlock | MadPhone | Universalbox | 12 | 03-09-2007 00:31 |
