12-21-2006, 15:14 | #1 (permalink) |
No Life Poster Join Date: Jan 2005 Age: 54
Member: 105625 Status: Offline Thanks Meter: 44 | Box/SmartCard not found - can you please fix this!? Theres always detections problems, and it must 100% sure be software related. Can you please improve the detection rutines in your software? I don't want to buy a seperate computer just for UST - it must be possible to fix the software so that UST can run on the same computer as other unlocking devices. Box/ports is installed fine (COM5 and 7) using UST drivers, and card is installed fine and working (i can read serial using the tool). But UST software still just says "BOX_ERROR_0x00 : Box/SmartCard not found!" while "loading module", or somtimes immidiately. Other times it just says unknown error. I'm so tired of buying expensive devices, where developer don't care about making the software compatible when other devices are connected as well. SEtool is the only of about 20 tools i own, that ALWAYS works perfect - always detects it's own card without any problems. Last edited by James_S; 12-21-2006 at 15:26. |
12-21-2006, 15:33 | #2 (permalink) |
No Life Poster Join Date: Apr 2005 Location: colchester Age: 56
Member: 134206 Status: Offline Thanks Meter: 17 | This my be a long shot but try taking ust apart and checking the sim is conected inside????? Had the same problem when i knocked the box -in the end found sim loose in box |
12-21-2006, 15:44 | #3 (permalink) |
No Life Poster Join Date: Mar 2005 Location: rome
Member: 125415 Status: Offline Thanks Meter: 309 | have you installer ns pro ??? if yes, download drivers for xp version 3.00 uninstall every ust pro related ( ust pro II device ad ust pro II com port ) you can find them in usb device and in com and lpt port Then disconnect box, install drivers, and when asked connect ust pro 2 box. Then for path write X:/program files/ust pro II/drivers And continue Ust pro now works ! |
12-22-2006, 00:40 | #4 (permalink) | |
Member: 105625 Status: Offline Thanks Meter: 44 | Quote:
Dengel: Already tried deleting everything, and reinstalling with mentioned drivers. My point is- why would i need to reinstall ust every time i install an other device? If it is so damn hard to get the ports in the UST box work, i want to use an other port, like my nsdongle device or something. Why can't the software just start and let me choose a different port? | |
12-22-2006, 01:28 | #6 (permalink) |
Freak Poster Join Date: Apr 2005 Location: Sant'Antioco - Italy Age: 38
Member: 135608 Status: Offline Thanks Meter: 91 | try to open your box and check sim holder. try also to take the card from the box and put in in the setool card reader. check your drivers must be version 3.00 p.s. the driver wich are with the serial reader program are v1.00. for v3.00 you must go to the support. you must register first. |
12-22-2006, 06:23 | #7 (permalink) |
No Life Poster Join Date: Dec 2003 Location: Baltchik,Bulgaria Age: 50
Member: 47236 Status: Offline Thanks Meter: 58 | James_S Same to me bro! 3 mounts i am fighting with my box 1 day work 10 days triing to run soft! this are all empty words- clean connectors bla bla This is Vahid problem and he need to solve it People cant have PC for every box that they own! I am triing to contact with Syroia 3 mounts already and he is always busy and can write on icq! And Vahid how is posible SN_reader to see card SN but soft cant see the card? Can you fix this in next update? How is posible to use 15 boxes on same PC but only UST PRO2 cant run? br |
12-25-2006, 22:16 | #8 (permalink) | |
I have 80% of the most famous GSM-tools, and theres a few that have really poor box/card detection rutines. That includes UST-pro, Multibox and Furious. All other never have any problems connecting to their box/card. It's very annoying that these teams don't care about writing proper software. | |
BOX IS NOT FOUND.DEMO MODE please help me | leslyjd | CPF-BOX Ⅱ | 2 | 12-09-2009 15:51 |
can you please delete this user | shuichi | Board, Server and Login Problems/Support | 6 | 06-20-2009 03:14 |
BOX_ERROR_0x00 : Box/SmartCard not found! | waqarmunir4 | UST Pro II | 13 | 02-18-2007 16:40 |
any way for solved BOX_ERROR_0X00 : BOX/SmartCard not found | gsm4libya | UST Pro II | 9 | 08-01-2006 21:08 |
Help mebox_error_ox00 : box/smartcard not found | gtsmg1982 | UST Pro II | 0 | 06-02-2006 11:21 |
