11-14-2007, 23:52 | #7 (permalink) |
Freak Poster Join Date: Oct 2003 Location: Serbia
Member: 42332 Status: Offline Thanks Meter: 2 | I had the same problem, after flashing d900i losing signal every few seconds. didn't help unlock/rebuild, only way to fix it is to write good eprom from another phone, now signal drop a little, but never lost. Problem is to back original imei, when I finaly manage to back it - I have the same problem with signal !?! any tip? or trick |
11-15-2007, 18:36 | #8 (permalink) |
Insane Poster Join Date: Sep 2007
Member: 588010 Status: Offline Thanks Meter: 1 | Been there, done that. 1) Download the eeprom from the UST-pro2 support site. 2) Erase and re-write the eeprom using the one you downloaded. 3) Download the D900i_OF_XAGE1 flash files from UST-Pro2 support site 4) UNCHECK the erase box and the EEPROM box and check the FFS and Flash files box, loading the XA flash files. CHECK the FFS format box. 5) Write the flash and FFS files to the phone. 6) enter the correct IMEI code into the program. Start with checking the Newest algorithm. 7) PUT THE BATTERY IN THE PHONE, but no SIM chip. 8) Start the IMEI writing program and connect the phone when prompted. 9) When done, take the battery out, put in the SIM chip, the battery, fire it up and start setting your settings. That worked for me. Phone works great now. |
11-16-2007, 12:53 | #11 (permalink) | |
Member: 588010 Status: Offline Thanks Meter: 1 | Quote:
It depends: When you click on the FFS file it will give you the list of languages it supports. you can try the other flash files at UST-PRO2.org/support or the mirror site. I went for that one because it's the file for the UK and I'm in the USA. All I can tell you is what worked for me. | |
D900i no network | stich_in | SWIFT Platform | 1 | 06-20-2011 15:35 |
d900i no network warning | terry123 | Ultimate-Sam | 23 | 03-03-2009 15:09 |
D900i No Network!!!PLZ help | HD gsm | Samsung Flashers, Software, Firmware. | 3 | 12-26-2008 14:43 |
d900i no network plz help siroya | ..:::Gsm india:::.. | UST Pro II | 2 | 02-17-2008 18:21 |
D900i no network after flash | LordMen007 | UST Pro II | 3 | 09-05-2007 01:12 |
