Unlock Server
Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > UST Pro II
Old 10-01-2007, 17:14   #1 (permalink)
JC_BY's Avatar
Member: 59319
Sonork: 100.1606948
D900i read-write EEPROM doesn't work!
Power ON phone...
Phone detected!
Loading Preloader...
Preloader OK!
Setting 921600 bps...
Baudrate set OK!
Loading second loader...
2nd boot OK!
Getting Flash ID...
Manufactor : SAMSUNG
Chip Type : KBJ10KB00M
Programming EEPROM...
Minor error detected during operation.
Operation successful.
Elapsed Time (00:17)
Old 10-01-2007, 20:11   #2 (permalink)
Member: 7444
Sonork: 100.99999
FILE ACCESS ERROR !!!
May be eeprom file is "Read-Only" , btw, just close UST and open again, and it will work ok.
Old 10-01-2007, 21:06   #3 (permalink)
JC_BY's Avatar
Member: 59319
Sonork: 100.1606948
OK! On notebook I could read eeprom. But rebuilding IMEI still doesn't work
Reading data from box...
Power ON phone...
Phone detected!
Preloader OK!
Baudrate set OK!
2nd boot OK!
Getting Flash ID...
Bypassing MSL Security...
MSL access granted OK!
Calculating security...
Security data calculated OK!
Rebuilding IMEI...
Elapsed Time (00:45)
But IMEI wasn't changed.
Old 10-01-2007, 21:19   #4 (permalink)
JC_BY's Avatar
Member: 59319
Sonork: 100.1606948
This is the log from writing eeprom on notebook
Power ON phone...
Phone detected!
Preloader OK!
Baudrate set OK!
2nd boot OK!
Getting Flash ID...
EEPROM programming OK!
Elapsed Time (01:21)
Old 10-01-2007, 22:04   #5 (permalink)
SiRoYa's Avatar
Member: 16107
choose old algo if u have tried with new algo
Old 10-02-2007, 07:16   #6 (permalink)
mmcr's Avatar
Member: 281082
ok guys, this is how i change D900i, for some reason "rebuild" doesn't always work. dl an eeprom file from support, flash it to the phone without the battery, now rebuild imei with battery in, phone off hey. works 100% tested on more than 30 pieces already!
Old 10-02-2007, 12:09   #7 (permalink)
Member: 588010
Thank you!
This actually worked! However, using the "old algorithm" box it required me to detach the phone, power it up, and re-attach it before the timer ran out. But it seemed to work. The phone still won't start but the IMEI reprogram indicated that it changed the IMEI and completed successfully.
Now I'm flashing the phone with the downloaded D900i_25 files, clicking both the FLASH and FFS files, and the FORMAT FFS box. I have the battery removed.
We'll see if that works...
Old 10-02-2007, 15:14   #8 (permalink)
Member: 588010
Well,
the method of re-writing the IMEI code worked, but the flashing didn't. I tried it without and with the battery.
Phone still comes on to the first screen that says SGH-D900i, goes to second screen, then shuts off.
Now I'll try both with the old and the new algorithms....
Old 10-12-2007, 07:28   #9 (permalink)
mmcr's Avatar
Member: 281082
so my method works...
Old 10-12-2007, 15:44   #10 (permalink)
Member: 588010
Don't sound so surprised!!!!
Old 10-12-2007, 17:10   #11 (permalink)
mmcr's Avatar
Member: 281082
lol, just checking buddy! if you ever get stuck with any phone on UST, just msg me on MSN or YAHOO! i'm on all the time
¿Restore IMEI on D900i after writing eeprom? artur223 UST Pro II 10 08-01-2007 11:14
Scheme for reading/writing eeprom from Samsung 100% working Bogi Samsung Flashers, Software, Firmware. 57 10-12-2003 18:50
How to read/write EEPROM of Sl45??? banKa x1x to x45/x50 0 02-20-2002 11:09
Read\Write eeprom 5xx/6xx/9xx GSM Brothers Various 11 09-03-2001 18:10
Read/write EEPROM C35i? laxxe x1x to x45/x50 0 06-12-2001 14:10
vBulletin Optimisation provided by vB Optimise v2.5.2 (Lite) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. ()
Page generated in 0.34458 seconds with 11 queries
