10-13-2009, 14:05 | #1 (permalink) |
Freak Poster Join Date: Mar 2004 Age: 43
Member: 57806 Status: Offline Thanks Meter: 4 | Damn it! Gimme Explanation for S5230 Unlock! It's definately not working with E210 Combo Cable (I've changed it 3 times) I've tried with original usb cable... didn't help! I also changed the driver (first one was broadcom driver from UST support, second one was original driver from phone) I changed the COM Port (1-16) BUT without success! Always getting error: "Phone not Found!" or it hangs up (Nand) and nothing happens! Is there somebody, who had the same problem and afterwards unlocked it successfully? Is there anybody, who can give me a Step-by-Step Explanation? But only someone, who knows this problem! Thanks in advance |
10-13-2009, 16:04 | #4 (permalink) |
No Life Poster Join Date: Nov 2008 Location: UK NETWORK SOURCE
Member: 908175 Status: Offline Thanks Meter: 314 | wich version you are using if you are yousing 9.9.60 it is not gona work because this setup have got some bug use 9.9.54 and post the report here tested by me 10000000000% work |
The Following User Says Thank You to qasi786 For This Useful Post: |
10-13-2009, 17:23 | #9 (permalink) |
Member: 908175 Status: Offline Thanks Meter: 314 | here go to support here is supporter you can down load any setup http://www.ustpro2.org/USTPro2_Support.exe |
10-14-2009, 09:15 | #14 (permalink) |
Freak Poster Join Date: Sep 2006 Location: topcom.comunicaciones Age: 47
Member: 353737 Status: Offline Sonork: 100.1580139 Thanks Meter: 43 | please check this link: http://forum.gsmhosting.com/vbb/showthread.php?t=839480 |
The Following User Says Thank You to topcomgsm For This Useful Post: |
when we can hope for s5230 unlock sir ? | .:M@ster:. | Z3X-Team Products | 2 | 06-18-2009 10:28 |
It is time for SE unlocking servis | TITO | Universalbox | 1 | 06-02-2008 21:42 |
DAMN IT! WTF is the problem with this "FT_Write - General IO Error"? | kasalapi | Twisterflasher | 15 | 07-17-2005 16:43 |
for arabic unlocker pdf explan how unlock c3100 | fonec | VygisToolbox | 0 | 10-13-2004 17:10 |
