E2120 hangs and restarts complete solution with flash files and trick if you are facing problem in solution of E2120 smasung pls donot open the set nor remove components just adopt the following well experienced procedures open ustpro software select e2120 uncheck "bypass in TAT mode(new)" enter imei no reading from the back lable press "rebuild imei" flash phone with these two files http://www.megaupload.com/?d=GZPUHH70 rebuild imei AGAIN with "bypass in TAT mode(new)" disconnect the phone press power ON button on the mobile phone untill mobile completely powered ON thanks to you all by gsmzaman |
Real solution mother board change bro...................... |
Thanks for This solution Sir,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,, |
any one tested.............??? |
e2120 hangsand restart complete solution Quote:
i sort out this fault and finally post here. before post i rectify one more mobile... even then do reply after succeess. thanks to you all by gsmzaman |
thank.u.......................... |
thanks for the tricks sir.. i'm hoping this was the final solution of these kind of unit.. |
