Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > UST Pro II
Old 08-08-2008, 07:54   #1 (permalink)
Member: 805902
Thumbs up Eroor On Ust
HI GUYS WHEN I START UST SW I GET THIS ERROR EVERY TIME ON UST WINDOW ...........Displaying Security info...
Security : Cyberflex Access e-gate 32K
Box S.N. : 821902-FFFAC8
{{Check driver installation!
Multiflashing is disabled!}}
Loading list of phones...
688 Models supported.
Ready...
{{}}Check driver installation!
Multiflashing is disabled!}}}}THIS TYPE OF ERROR
IF ANY BODY KNNOW THAT HOW I SOLVE THIS PROBLEM SO PLZ REPLY
Old 08-08-2008, 09:11   #2 (permalink)
SiRoYa's Avatar
Member: 16107
This msg is normal and u cannot say this is error... multiflashing is only enable if u are using old box with 2 comports !!!
Old 08-08-2008, 10:11   #3 (permalink)
Member: 805902
thanx for reply siroya.......
but when i direct unlock samsung a707 then phone is found on box ports
but when i flash the phone its giving error that [{ phone not found}]???
thats y i think this is dueto that its giving [{Multiflashing is disabled }]
coz i am new user of ust but now
u clear that this is not error n i vil understand but wat is this problem which i
face on A707 flashing for unlock plz reply?
Old 08-08-2008, 10:19   #4 (permalink)
frnd_4_gsm's Avatar
Member: 279604
Sonork: 100.1582858
for flashing a707 u need to press 9 and power on the handset will show red scren after u insert cable and install drivers
Old 08-08-2008, 10:27   #5 (permalink)
frnd_4_gsm's Avatar
Member: 279604
Sonork: 100.1582858
for unlocking ....power on phone without sim then press *#0002*28346# ,back,back,back,9,6,1 to change it to samsung usb modem then install the driver. cable name v804 rj-45 + usb
Old 08-08-2008, 10:31   #6 (permalink)
Member: 805902
thanx frnd 4 gsm vil try n post result thanks once again...
Old 08-08-2008, 10:58   #7 (permalink)
SiRoYa's Avatar
Member: 16107
yes for flashing u must use usb cable !!!
Old 08-08-2008, 11:51   #8 (permalink)
Member: 805902
but sir when i attach usb cable on box its gives error below
that [usb divice not rcognize} and not asking for driver
what i vil be do now???
Old 08-08-2008, 11:55   #9 (permalink)
frnd_4_gsm's Avatar
Member: 279604
Sonork: 100.1582858
try to connect usb cable on computer main motherboard port
Old 08-08-2008, 12:04   #10 (permalink)
SiRoYa's Avatar
Member: 16107
yes put usb cable in other usb hub or direct to pc
Old 08-08-2008, 14:54   #11 (permalink)
Member: 805902
ill use lap top direct mainboard port me not use a hub but problem is still
Old 08-08-2008, 16:41   #12 (permalink)
SiRoYa's Avatar
Member: 16107
did u put ur fone in download mode 9 + power on .. if yes and still same
go to hardware properties and change samsung modem port to lower then 12
Old 08-09-2008, 07:46   #13 (permalink)
Member: 805902
yes mr siroya i put the fone in download mode any ways ill
change hardware properties n post result thanx for quick reply n great support
Old 08-09-2008, 14:32   #14 (permalink)
Member: 805902
Ill Check Ports Its On Port 4 But When I Put
Usb Cable For Flashing Its Not Asking For
Driver ?????NOW WAT I VIL BE DO NEXT PLZ REPLY
Old 09-04-2008, 08:05   #15 (permalink)
Member: 663739
ust
Box S.N. : 421900-0019A2
689 Models supported.
Ready...
what is this BOX...who can fix this??proble
help on how flash t809 on ust pro hamra_ksa UST Pro II 1 06-25-2009 08:09
help active on ust-pro to ust-pro2 reaz.com UST Pro II 1 02-08-2007 20:45
BIG problem on UST v7.20 adam5589 UST Pro II 0 11-13-2004 04:05
S105 flash file not supported on UST Phantom UST Pro II 0 12-23-2003 05:25
Page generated in 1.69083 seconds with 11 queries
