07-04-2008, 19:32 | #1 (permalink) |
No Life Poster Join Date: Jan 2002 Location: tunis,Tunisia Age: 54
Member: 8228 Status: Offline Sonork: 12399830 Thanks Meter: 136 | F250 killed by ust box ; no network , imei :000000000000 now imei is 0000000000 and phone no network i try to repair using all available full flash from support and eeprom; but no solution imei has changed using eeprom file but can't change it to original imei |
07-04-2008, 22:32 | #5 (permalink) |
Freak Poster Join Date: Oct 2006 Location: bacoor cavite Age: 42
Member: 375209 Status: Offline Thanks Meter: 14 | my tricks here if phone imei 000000000000.....write eprom f250 after write eprom dont power on the unit ,,,,,typ the origenal imei on rebuiled imei on ust software,click rebuiled imei...now ur f250 imei back to origenal imei also signal work fine if process not success try and try the tricks TRICKS IS OPTIONAL IF F250 ON UST SOFTWARE NO OPTION ON REBUILED IMEI....TRICKS NOT WORKS...... |
07-05-2008, 07:51 | #6 (permalink) | |
Member: 8228 Status: Offline Sonork: 12399830 Thanks Meter: 136 | Quote:
E200 successfully flashed but killed by UST | gsmtime | UST Pro II | 4 | 03-08-2008 16:51 |
z560 killed by ust | gsmuy | UST Pro II | 7 | 08-25-2006 14:44 |
Nec 342i killed by red Box | spider-man | NEC | 4 | 11-29-2005 20:45 |
p910i killed by furious box again | nokia_dan | FuriouS II | 4 | 09-07-2005 19:24 |
