Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > UST Pro II
Old 10-13-2009, 08:11   #1 (permalink)
Code:L.A 22's Avatar
Member: 990900
Fido SAMSUNG F266 unlock Done via read code By: UST pro
F266 From Canada Canada.
1st: Read Code
2nd: i use this code
*2767*3855# after restart phone
enter this *7465625*638*00000000*00000000#
3rd: after i off the phone then i insert SIM phone need the sp code and i enter her the result
The Following 2 Users Say Thank You to Code:L.A 22 For This Useful Post:
Old 10-20-2009, 06:51   #2 (permalink)
zeerik's Avatar
Member: 282066
Sonork: 100.1590696
witch cable you have used?
Old 10-20-2009, 07:55   #3 (permalink)
zeerik's Avatar
Member: 282066
Sonork: 100.1590696
100% tested with j750
The Following User Says Thank You to zeerik For This Useful Post:
Old 11-23-2009, 13:30   #4 (permalink)
Member: 741648
come on guys 23 views and nothing
I tried all this:
*7465625*77*00000000*00000000# you will get a SP code personalized which will set the SP lock to 8 zeros (note there are eight 0s there)
next
#7465625*77*00000000# = Disables SP lock
*7465625*638*00000000*00000000# you will get a Network code personalized which will set the network lock to 8 zeros (note there are eight 0s there)
#7465625*638*Code# = Disables Network lock
There and now the SP lock and network lock is gone. You may have to have the network lock locked before you can lock the SP lock. I locked it and then unlocked it after removing the SP lock.
After you try it post here so others can see if it works.
But it just didn't work
It says no lock code in sim
Old 04-16-2010, 08:08   #5 (permalink)
Member: 446169
Sonork: 100.1601454
Bt After Unlock Show Limitid serviec
Old 04-18-2010, 08:05   #6 (permalink)
Temporary banned !!
Member: 149305
Sonork: 100.1612778
yes the smae problem i've got too, but only telenore carier working well. now tell any body can i change its band too???
The Following 3 Users Say Thank You to azhar63 For This Useful Post:
T629 DONE via Read Code....... nhoy'sbarage UST Pro II 0 03-14-2010 05:12
Blackberry 8220 done via read codes [ENJOY] shawgsm 3GKey / BB-Box 0 01-12-2010 07:21
E1120 read code by ust pro delux_gsm QUALCOMM Models (3G) 1 11-24-2009 12:40
Gt-S5600v samsung unlocked tru read codes by ust-pro nelsky UST Pro II 0 09-28-2009 08:44
samsung x576 unlock done by read codes aleon HWK 3 03-27-2009 19:17
Page generated in 0.26418 seconds with 12 queries
