Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > UST Pro II
Old 11-19-2009, 03:15   #1 (permalink)
Member: 1113892
Sonork: none
Thanks Meter: 62
F480i Flash Successfully Done ! User code Removed
Download Flash-Files and Dowloader from UST Support Site :
Use UST as Interface:
Tick: UART
Attache E210 Combo Cable to phone. ( just RJ45 , no need to connect USB )
Select Comport
Select Bound Rate
( Phone must be off )
Click Start from Software
Press Power on phone.
When it connect , Put flash files in all fields, ( see picture below.)
Tick : BootLoader+AllBin+FS
Tick : Auto Reboot
Click Download .. And wait process to be finished.
How to use Download Mode
    1. Turn off the target phone!!!
    2. Select COM Port(USB or UART) , Baud Rate.
    3. Push the Start Button.
    4. Turn on the target phone!!!
  * Connecting to target phone
     Try to open COM42    >Success!!
   - Turn on the target phone immediately!!!!
      Listen for the BOOT signal            > > > OK
      Send the Download start signal        > > > OK
      Listen for the Download start ACK signal    > > > OK
  * NAND Flash Driver Download
     preloader downloading            > > > OK
     NAND Flash driver downloading        > > > OK
     Flash Type Checking            > > > OK
      NAND Bad block check            > > > 1 Bad block found
        P.Block[155] ---> S.Block[1002]
OK
     UART Download Mode    > > > Available
  * NAND : Preboot Download
    Preboot Download start!!
      Download  Completed ( Elapsed Time :   0.4s)
  * NAND : Boot1a Download
    Boot1 Download start!!
  * NAND : Boot1b Download
    Boot1b Download start!!
      Download  Completed ( Elapsed Time :   1.0s)
  * NAND : Boot2 Download
    Boot2 Download start!!
      Download  Completed ( Elapsed Time :   9.1s)
  * NAND : APPS Download
    APPS Download start!!
      Download  Completed ( Elapsed Time : 1203.2s)
  * NAND : COMMS Download
    COMMS Download start!!
      Download  Completed ( Elapsed Time : 149.8s)
  * NAND : Sys_ind Download
    Sysparm Ind Download start!!
      Download  Completed ( Elapsed Time :   1.7s)
  * NAND : Patch Download
    Patch Download start!!
      Download  Completed ( Elapsed Time :   0.8s)
  * NAND : Rsrc Download
    Rsrc Download start!!
      Download  Completed ( Elapsed Time : 788.3s)
  * NAND : TFS Download
    TFS Download start!!
     TFS Format...     OK
     ** Mounting TFS system...
     ** Start Downloading TFS file **
     Sending NAND CheckSum:c7bd81a3
 OK!
     TFS time set OK!
     Cr.dir "/DB"...
     Cr.dir "/DB2"...
     Cr.dir "/DB2/unlimitdb"...
     Cr.dir "/Debug"...
     Cr.dir "/Exe"...
     Cr.dir "/Exe/Java"...
     Cr.dir "/Exe/Java/Games"...
     Cr.dir "/Exe/Java/Games/Asphalt 4"...
     Cr.dir "/Exe/Java/Games/Crazy penguin"...
     Cr.dir "/Exe/Java/Games/DJ Mix tour"...
     Cr.dir "/Exe/Java/Games/Monopoly"...
     Cr.dir "/Exe/Java/Games/Pyramid bloxx"...
     Cr.dir "/Exe/Java/Links"...
     Cr.dir "/Exe/Java/Locked Games"...
     Cr.dir "/Exe/Java/Locked Games/Checkers Deluxe"...
     Cr.dir "/Exe/Java/Locked Games/Content Explorer"...
     Cr.dir "/Exe/Java/Locked Games/Google Maps"...
     Cr.dir "/Exe/Mocha"...
     Cr.dir "/Exe/Mocha/App"...
     Cr.dir "/Exe/Mocha/Lib"...
     Cr.dir "/Media"...
     Cr.dir "/Media/Images"...
     Cr.dir "/Media/Images/My photos"...
     Cr.dir "/Media/Other files"...
     Cr.dir "/Media/Sounds"...
     Cr.dir "/Media/Sounds/Music"...
     Cr.dir "/Media/Sounds/Ringtones"...
     Cr.dir "/Media/Videos"...
     Cr.dir "/Media/Videos/My video clips"...
     Cr.dir "/Mount"...
     Cr.dir "/Registry"...
     Cr.dir "/Security"...
     Cr.dir "/Security/Certs"...
     Cr.dir "/Security/CM"...
     Cr.dir "/Security/DefaultPrivateCert"...
     Cr.dir "/Security/DefaultRootCACerts"...
     Cr.dir "/Security/DEVCerts"...
     Cr.dir "/Security/DEVCerts/Domain1Certs"...
     Cr.dir "/Security/DEVCerts/Domain2Certs"...
     Cr.dir "/Security/DEVCerts/Domain3Certs"...
     Cr.dir "/Security/DEVCerts/RootCACerts"...
     Cr.dir "/Security/Domain1Certs"...
     Cr.dir "/Security/Domain2Certs"...
     Cr.dir "/Security/Domain3Certs"...
     Cr.dir "/Security/Keyinfo"...
     Cr.dir "/Security/Keyinfo/Client"...
     Cr.dir "/Security/Keyinfo/Client/RSA512"...
     Cr.dir "/Security/Keyinfo/RCA"...
     Cr.dir "/Security/Keyinfo/RCA/RSA512"...
     Cr.dir "/Security/PROFILE"...
     Cr.dir "/Settings"...
     Cr.dir "/Settings/Default"...
     Cr.dir "/Settings/Default/NV"...
     Cr.dir "/SystemFS"...
     Cr.dir "/SystemFS/Country"...
     Cr.dir "/SystemFS/DB"...
     Cr.dir "/SystemFS/Driver"...
     Cr.dir "/SystemFS/Driver/Pitch"...
     Cr.dir "/SystemFS/FFSCountry"...
     Cr.dir "/SystemFS/Media"...
     Cr.dir "/SystemFS/Media/Images"...
     Cr.dir "/SystemFS/Media/Images/My photos"...
     Cr.dir "/SystemFS/Media/Other files"...
     Cr.dir "/SystemFS/Media/Sounds"...
     Cr.dir "/SystemFS/Media/Sounds/Ringtones"...
     Cr.dir "/SystemFS/Media/Sounds/Voice clips"...
     Cr.dir "/SystemFS/Media/Videos"...
     Cr.dir "/SystemFS/Media/Videos/My video clips"...
     Cr.dir "/SystemFS/MediaSet"...
     Cr.dir "/SystemFS/MediaSet/Frame"...
     Cr.dir "/SystemFS/MediaSet/Frame/Camera"...
     Cr.dir "/SystemFS/MediaSet/Frame/Camera/Frame"...
     Cr.dir "/SystemFS/MediaSet/Frame/Camera/Frame/Image"...
     Cr.dir "/SystemFS/MediaSet/Frame/Camera/Frame/Thumb"...
     Cr.dir "/SystemFS/MediaSet/Frame/Camera/Mosaic"...
     Cr.dir "/SystemFS/MediaSet/Frame/Camera/Mosaic/Image"...
     Cr.dir "/SystemFS/MediaSet/Frame/Camera/Mosaic/Thumb"...
     Cr.dir "/SystemFS/MediaSet/Frame/Camera/QuickView"...
     Cr.dir "/SystemFS/MediaSet/Frame/Camera/Simulator"...
     Cr.dir "/SystemFS/MediaSet/Frame/ImgEditor"...
     Cr.dir "/SystemFS/MediaSet/Frame/ImgEditor/ThumbNail"...
     Cr.dir "/SystemFS/MediaSet/MovieMaker"...
     Cr.dir "/SystemFS/MediaSet/UCS"...
     Cr.dir "/SystemFS/MediaSet/UCS/Default"...
     Cr.dir "/SystemFS/MediaSet/Widget"...
     Cr.dir "/SystemFS/Settings"...
     Cr.dir "/SystemFS/Settings/OperatorSettings"...
     Cr.dir "/SystemFS/Settings/OperatorSettings/Baltic"...
     Cr.dir "/SystemFS/Settings/OperatorSettings/Baltic/BiteLT"...
     Cr.dir "/SystemFS/Settings/OperatorSettings/Baltic/BiteLT/Registry"...
     Cr.dir "/SystemFS/Settings/OperatorSettings/Baltic/BiteLV"...
     Cr.dir "/SystemFS/Settings/OperatorSettings/Baltic/BiteLV/Registry"...
     Cr.dir "/SystemFS/Settings/OperatorSettings/Baltic/ElisaEE"...
     Cr.dir "/SystemFS/Settings/OperatorSettings/Baltic/ElisaEE/Registry"...
     Cr.dir "/SystemFS/Settings/OperatorSettings/Baltic/EmtEE"...
     Cr.dir "/SystemFS/Settings/OperatorSettings/Baltic/EmtEE/Registry"...
     Cr.dir "/SystemFS/Settings/OperatorSettings/Baltic/LmtLV"...
     Cr.dir "/SystemFS/Settings/OperatorSettings/Baltic/LmtLV/Registry"...
     Cr.dir "/SystemFS/Settings/OperatorSettings/Baltic/OmniLT"...
     Cr.dir "/SystemFS/Settings/OperatorSettings/Baltic/OmniLT/Registry"...
     Cr.dir "/SystemFS/Settings/OperatorSettings/Baltic/Tele2EE"...
     Cr.dir "/SystemFS/Settings/OperatorSettings/Baltic/Tele2EE/Registry"...
     Cr.dir "/SystemFS/Settings/OperatorSettings/Baltic/Tele2LT"...
     Cr.dir "/SystemFS/Settings/OperatorSettings/Baltic/Tele2LT/Registry"...
     Cr.dir "/SystemFS/Settings/OperatorSettings/Baltic/Tele2LV"...
     Cr.dir "/SystemFS/Settings/OperatorSettings/Baltic/Tele2LV/Registry"...
     Cr.dir "/SystemFS/Settings/OperatorSettings/Default"...
     Cr.dir "/SystemFS/Settings/OperatorSettings/Default/None"...
     Cr.dir "/SystemFS/Settings/OperatorSettings/Default/None/Registry"...
     Cr.dir "/SystemFS/Settings/OperatorSettings/Kazakhstan"...
     Cr.dir "/SystemFS/Settings/OperatorSettings/Kazakhstan/Kcell"...
     Cr.dir "/SystemFS/Settings/OperatorSettings/Kazakhstan/Kcell/Registry"...
     Cr.dir "/SystemFS/Settings/OperatorSettings/Kazakhstan/Kmobile"...
     Cr.dir "/SystemFS/Settings/OperatorSettings/Kazakhstan/Kmobile/Registry"...
     Cr.dir "/SystemFS/Settings/OperatorSettings/Romania"...
     Cr.dir "/SystemFS/Settings/OperatorSettings/Russia"...
     Cr.dir "/SystemFS/Settings/OperatorSettings/Russia/Beeline"...
     Cr.dir "/SystemFS/Settings/OperatorSettings/Russia/Beeline/Registry"...
     Cr.dir "/SystemFS/Settings/OperatorSettings/Russia/Megafon"...
     Cr.dir "/SystemFS/Settings/OperatorSettings/Russia/Megafon/Registry"...
     Cr.dir "/SystemFS/Settings/OperatorSettings/Russia/MTS"...
     Cr.dir "/SystemFS/Settings/OperatorSettings/Russia/MTS/Registry"...
     Cr.dir "/SystemFS/Settings/OperatorSettings/Ukraine"...
     Cr.dir "/SystemFS/Settings/OperatorSettings/Ukraine/Beeline"...
     Cr.dir "/SystemFS/Settings/OperatorSettings/Ukraine/Beeline/Registry"...
     Cr.dir "/SystemFS/Settings/OperatorSettings/Ukraine/Kyivstar"...
     Cr.dir "/SystemFS/Settings/OperatorSettings/Ukraine/Kyivstar/Registry"...
     Cr.dir "/SystemFS/Settings/OperatorSettings/Ukraine/Life"...
     Cr.dir "/SystemFS/Settings/OperatorSettings/Ukraine/Life/Registry"...
     Cr.dir "/SystemFS/Settings/OperatorSettings/Ukraine/MTS"...
     Cr.dir "/SystemFS/Settings/OperatorSettings/Ukraine/MTS/Registry"...
     Cr.dir "/SystemFS/Settings/OperatorSettings/Ukraine/Utel"...
     Cr.dir "/SystemFS/Settings/OperatorSettings/Ukraine/Utel/Registry"...
     Cr.dir "/SystemFS/Settings/OperatorSettings/Uzbekistan"...
     Cr.dir "/SystemFS/Settings/OperatorSettings/Uzbekistan/MTS"...
     Cr.dir "/SystemFS/Settings/OperatorSettings/Uzbekistan/MTS/Registry"...
     Cr.dir "/SystemFS/Settings/OperatorSettings/Uzbekistan/UNITEL"...
     Cr.dir "/SystemFS/Settings/OperatorSettings/Uzbekistan/UNITEL/Registry"...
     Cr.dir "/SystemFS/Settings/PreConfiguration"...
     Cr.dir "/SystemFS/Settings/PreConfiguration/Baltic"...
     Cr.dir "/SystemFS/Settings/PreConfiguration/Baltic/NV"...
     Cr.dir "/SystemFS/Settings/PreConfiguration/Baltic/Registry"...
     Cr.dir "/SystemFS/Settings/PreConfiguration/Baltic/User"...
     Cr.dir "/SystemFS/Settings/PreConfiguration/Baltic/User/Br"...
     Cr.dir "/SystemFS/Settings/PreConfiguration/Default"...
     Cr.dir "/SystemFS/Settings/PreConfiguration/Default/NV"...
     Cr.dir "/SystemFS/Settings/PreConfiguration/Default/Registry"...
     Cr.dir "/SystemFS/Settings/PreConfiguration/Default/User"...
     Cr.dir "/SystemFS/Settings/PreConfiguration/Default/User/Br"...
     Cr.dir "/SystemFS/Settings/PreConfiguration/Kazakhstan"...
     Cr.dir "/SystemFS/Settings/PreConfiguration/Kazakhstan/NV"...
     Cr.dir "/SystemFS/Settings/PreConfiguration/Kazakhstan/Registry"...
     Cr.dir "/SystemFS/Settings/PreConfiguration/Kazakhstan/User"...
     Cr.dir "/SystemFS/Settings/PreConfiguration/Kazakhstan/User/Br"...
     Cr.dir "/SystemFS/Settings/PreConfiguration/Russia"...
     Cr.dir "/SystemFS/Settings/PreConfiguration/Russia/NV"...
     Cr.dir "/SystemFS/Settings/PreConfiguration/Russia/Registry"...
     Cr.dir "/SystemFS/Settings/PreConfiguration/Russia/User"...
     Cr.dir "/SystemFS/Settings/PreConfiguration/Russia/User/Br"...
     Cr.dir "/SystemFS/Settings/PreConfiguration/Ukraine"...
     Cr.dir "/SystemFS/Settings/PreConfiguration/Ukraine/NV"...
     Cr.dir "/SystemFS/Settings/PreConfiguration/Ukraine/Registry"...
     Cr.dir "/SystemFS/Settings/PreConfiguration/Ukraine/User"...
     Cr.dir "/SystemFS/Settings/PreConfiguration/Ukraine/User/Br"...
     Cr.dir "/SystemFS/Settings/PreConfiguration/Uzbekistan"...
     Cr.dir "/SystemFS/Settings/PreConfiguration/Uzbekistan/Registry"...
     Cr.dir "/SystemFS/Settings/PreConfiguration/Uzbekistan/User"...
     Cr.dir "/SystemFS/Settings/PreConfiguration/Uzbekistan/User/Br"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/Algeria"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/Algeria/Djezzy"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/Algeria/Djezzy/Registry"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/Algeria/Mobilis"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/Algeria/Mobilis/Registry"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/Algeria/Nedjma"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/Algeria/Nedjma/Registry"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/Australia"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/Australia/Crazy"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/Australia/Crazy/Registry"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/Australia/H3G"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/Australia/H3G/Registry"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/Australia/Optus"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/Australia/Optus/Registry"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/Australia/Telstra"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/Australia/Telstra/Registry"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/Australia/Virgin"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/Australia/Virgin/Registry"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/Australia/Vodafone"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/Australia/Vodafone/Registry"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/Austria"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/Austria/A1"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/Austria/A1/Registry"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/Austria/Bob"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/Austria/Bob/Registry"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/Austria/H3G"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/Austria/H3G/Registry"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/Austria/Orange"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/Austria/Orange/Registry"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/Austria/T-Mobile"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/Austria/T-Mobile/Registry"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/Austria/Tele.ring"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/Austria/Tele.ring/Registry"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/Austria/Yesss!"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/Austria/Yesss!/Registry"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/Belgium"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/Belgium/Base"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/Belgium/Base/Registry"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/Belgium/Mobistar"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/Belgium/Mobistar/Registry"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/Belgium/Proximus"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/Belgium/Proximus/Registry"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/Bulgaria"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/Bulgaria/M-Tel"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/Bulgaria/M-Tel/Registry"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/Cyprus"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/Cyprus/CYTA"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/Cyprus/CYTA/Registry"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/Cyprus/MTN"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/Cyprus/MTN/Registry"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/Czech"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/Czech/Eurotel"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/Czech/Eurotel/Registry"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/Czech/O2"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/Czech/O2/Registry"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/Czech/T-Mobile"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/Czech/T-Mobile/Registry"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/Czech/Vodafone"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/Czech/Vodafone/Registry"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/Default"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/Default/None"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/Default/None/Registry"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/Denmark"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/Denmark/3"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/Denmark/3/Registry"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/Denmark/Sonofon"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/Denmark/Sonofon/Registry"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/Denmark/TDC"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/Denmark/TDC/Registry"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/Denmark/Telenor"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/Denmark/Telenor/Registry"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/Denmark/Telia"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/Denmark/Telia/Registry"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/Denmark/Telmore"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/Denmark/Telmore/Registry"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/Estonia"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/Estonia/Elisa"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/Estonia/Elisa/Registry"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/Estonia/EMT"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/Estonia/EMT/Registry"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/Estonia/Tele2"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/Estonia/Tele2/Registry"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/Finland"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/Finland/DNA"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/Finland/DNA/Registry"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/Finland/Elisa"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/Finland/Elisa/Registry"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/Finland/Saunalahti"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/Finland/Saunalahti/Registry"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/Finland/Sonera"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/Finland/Sonera/Registry"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/France"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/France/AUC"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/France/AUC/Registry"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/France/Bouygtel"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/France/Bouygtel/Registry"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/France/Carrefour"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/France/Carrefour/Registry"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/France/NRJ"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/France/NRJ/Registry"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/France/NRJ(ORANGE)"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/France/NRJ(ORANGE)/Registry"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/France/Orange"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/France/Orange/Registry"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/France/SFR"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/France/SFR/Registry"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/France/TELE2"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/France/TELE2/Registry"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/France/VirginMobile"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/France/VirginMobile/Registry"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/Germany"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/Germany/E-Plus"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/Germany/E-Plus/Registry"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/Germany/O2"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/Germany/O2/Registry"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/Germany/T-Mobile"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/Germany/T-Mobile/Registry"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/Germany/Vodafone"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/Germany/Vodafone/Registry"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/GermanyDebitel"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/GermanyDebitel/E-Plus"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/GermanyDebitel/E-Plus/Registry"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/GermanyDebitel/O2"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/GermanyDebitel/O2/Registry"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/GermanyDebitel/T-Mobile"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/GermanyDebitel/T-Mobile/Registry"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/GermanyDebitel/Vodafone"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/GermanyDebitel/Vodafone/Registry"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/Greece"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/Greece/Cosmote"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/Greece/Cosmote/Registry"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/Greece/TIM"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/Greece/TIM/Registry"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/Greece/Vodafone"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/Greece/Vodafone/Registry"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/Greece/Vodafone_Prepaid"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/Greece/Vodafone_Prepaid/Registry"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/Greece/Wind"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/Greece/Wind/Registry"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/Hungary"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/Hungary/Pannon"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/Hungary/Pannon/Registry"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/Hungary/T-Mobile"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/Hungary/T-Mobile/Registry"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/Hungary/Vodafone"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/Hungary/Vodafone/Registry"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/Iceland"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/Iceland/Nova"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/Iceland/Nova/Registry"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/Iceland/Siminn"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/Iceland/Siminn/Registry"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/Iceland/Vodafone_Iceland"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/Iceland/Vodafone_Iceland/Registry"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/Ireland"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/Ireland/H3G"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/Ireland/H3G/Registry"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/Ireland/Meteor"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/Ireland/Meteor/Registry"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/Ireland/O2"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/Ireland/O2/Registry"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/Ireland/Vodafone_PAYG"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/Ireland/Vodafone_PAYG/Registry"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/Ireland/Vodafone_Postpay"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/Ireland/Vodafone_Postpay/Registry"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/Italy"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/Italy/H3G"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/Italy/H3G/Registry"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/Italy/TIM"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/Italy/TIM/Registry"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/Italy/Vodafone"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/Italy/Vodafone/Registry"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/Italy/Wind"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/Italy/Wind/Registry"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/Italy/Wind_Biz"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/Italy/Wind_Biz/Registry"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/Kazakhstan"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/Kazakhstan/Beeline"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/Kazakhstan/Beeline/Registry"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/Kazakhstan/Kcell"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/Kazakhstan/Kcell/Registry"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/Kazakhstan/NEO"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/Kazakhstan/NEO/Registry"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/Korea"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/Korea/Gumi"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/Korea/Gumi/Registry"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/Korea/Suwon"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/Korea/Suwon/Registry"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/Latvia"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/Latvia/Bite"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/Latvia/Bite/Registry"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/Latvia/LMT"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/Latvia/LMT/Registry"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/Latvia/Tele2"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/Latvia/Tele2/Registry"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/Lithuania"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/Lithuania/Bite"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/Lithuania/Bite/Registry"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/Lithuania/Omnitel"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/Lithuania/Omnitel/Registry"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/Lithuania/Tele2"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/Lithuania/Tele2/Registry"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/Luxembourg"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/Luxembourg/LuxGSM"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/Luxembourg/LuxGSM/Registry"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/Luxembourg/Tango"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/Luxembourg/Tango/Registry"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/Luxembourg/Vox Mobile"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/Luxembourg/Vox Mobile/Registry"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/Malta"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/Malta/Vodafone"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/Malta/Vodafone/Registry"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/Morocco"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/Morocco/MAT"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/Morocco/MAT/Registry"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/Morocco/MED"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/Morocco/MED/Registry"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/Netherlands"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/Netherlands/KPN"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/Netherlands/KPN/Registry"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/Netherlands/Orange"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/Netherlands/Orange/Registry"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/Netherlands/T-Mobile"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/Netherlands/T-Mobile/Registry"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/Netherlands/Telefort"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/Netherlands/Telefort/Registry"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/Netherlands/Vodafone"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/Netherlands/Vodafone/Registry"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/Norway"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/Norway/Netcom"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/Norway/Netcom/Registry"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/Norway/Network N"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/Norway/Network N/Registry"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/Norway/TDC"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/Norway/TDC/Registry"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/Norway/Tele2"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/Norway/Tele2/Registry"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/Norway/Telenor"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/Norway/Telenor/Registry"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/Poland"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/Poland/Era"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/Poland/Era/Registry"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/Poland/Era_TakTak_Prepay"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/Poland/Era_TakTak_Prepay/Registry"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/Poland/Heyah"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/Poland/Heyah/Registry"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/Poland/Orange"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/Poland/Orange/Registry"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/Poland/Play"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/Poland/Play/Registry"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/Poland/Plus"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/Poland/Plus/Registry"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/Portugal"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/Portugal/Optimus"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/Portugal/Optimus/Registry"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/Portugal/TMN"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/Portugal/TMN/Registry"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/Portugal/Vodafone"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/Portugal/Vodafone/Registry"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/Romania"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/Romania/Connex"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/Romania/Connex/Registry"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/Romania/Cosmorom"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/Romania/Cosmorom/Registry"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/Romania/Orange"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/Romania/Orange/Registry"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/Romania/Vodafone"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/Romania/Vodafone/Registry"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/Romania/Vodafone_Prepay"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/Romania/Vodafone_Prepay/Registry"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/Russia"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/Russia/Beeline"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/Russia/Beeline/Registry"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/Russia/Megafon"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/Russia/Megafon/Registry"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/Russia/MTS"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/Russia/MTS/Registry"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/Slovak"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/Slovak/O2"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/Slovak/O2/Registry"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/Slovak/Orange"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/Slovak/Orange/Registry"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/Slovak/T-Mobile"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/Slovak/T-Mobile/Registry"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/Slovenia"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/Slovenia/Mobitel"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/Slovenia/Mobitel/Registry"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/Slovenia/SI-MOBIL"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/Slovenia/SI-MOBIL/Registry"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/Slovenia/Vodafone"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/Slovenia/Vodafone/Registry"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/SouthAfrica"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/SouthAfrica/CellC"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/SouthAfrica/CellC/Registry"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/SouthAfrica/MTN"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/SouthAfrica/MTN/Registry"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/SouthAfrica/Virgin"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/SouthAfrica/Virgin/Registry"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/SouthAfrica/Vodacom"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/SouthAfrica/Vodacom/Registry"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/Spain"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/Spain/Amena"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/Spain/Amena/Registry"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/Spain/Euskaltel"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/Spain/Euskaltel/Registry"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/Spain/movistar"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/Spain/movistar/Registry"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/Spain/Orange"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/Spain/Orange/Registry"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/Spain/Vodafone"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/Spain/Vodafone/Registry"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/Spain/Yoigo"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/Spain/Yoigo/Registry"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/Sweden"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/Sweden/3"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/Sweden/3/Registry"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/Sweden/Tele2"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/Sweden/Tele2/Registry"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/Sweden/Telenor"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/Sweden/Telenor/Registry"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/Sweden/Telia"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/Sweden/Telia/Registry"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/Switzerland"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/Switzerland/Orange"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/Switzerland/Orange/Registry"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/Switzerland/Sunrise"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/Switzerland/Sunrise/Registry"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/Switzerland/Swisscom"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/Switzerland/Swisscom/Registry"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/Tunisia"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/Tunisia/Tunisiana"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/Tunisia/Tunisiana/Registry"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/Tunisia/Tunisie_telecom"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/Tunisia/Tunisie_telecom/Registry"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/UK"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/UK/Asda"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/UK/Asda/Registry"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/UK/BT_Mobile"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/UK/BT_Mobile/Registry"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/UK/H3G"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/UK/H3G/Registry"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/UK/O2"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/UK/O2/Registry"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/UK/O2_Postpaid"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/UK/O2_Postpaid/Registry"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/UK/O2_Prepaid"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/UK/O2_Prepaid/Registry"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/UK/O2_Prepay"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/UK/O2_Prepay/Registry"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/UK/Orange"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/UK/Orange/Registry"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/UK/T-Mobile"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/UK/T-Mobile/Registry"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/UK/Tesco"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/UK/Tesco/Registry"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/UK/Virgin_Mobile"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/UK/Virgin_Mobile/Registry"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/UK/Vodafone_Contract"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/UK/Vodafone_Contract/Registry"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/UK/Vodafone_PAYG"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/UK/Vodafone_PAYG/Registry"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/Ukraine"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/Ukraine/Beeline"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/Ukraine/Beeline/Registry"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/Ukraine/Kyivstar"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/Ukraine/Kyivstar/Registry"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/Ukraine/Kyivstar_A&B"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/Ukraine/Kyivstar_A&B/Registry"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/Ukraine/Kyivstar_Djuice"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/Ukraine/Kyivstar_Djuice/Registry"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/Ukraine/Life"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/Ukraine/Life/Registry"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/Ukraine/MTS"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/Ukraine/MTS/Registry"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/Ukraine/Mts_*****"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/Ukraine/Mts_*****/Registry"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/Ukraine/Utel"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/Ukraine/Utel/Registry"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/Uzbekistan"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/Uzbekistan/Buztel"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/Uzbekistan/Buztel/Registry"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/Uzbekistan/MTS"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/Uzbekistan/MTS/Registry"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/Uzbekistan/Unitel"...
     Cr.dir "/SystemFS/Settings/SimAutoSettings/Uzbekistan/Unitel/Registry"...
     Cr.dir "/SystemFS/SlavFFSCountry"...
     Cr.dir "/SystemFS/Test"...
     Cr.dir "/SystemFS/Test/Sound"...
     Cr.dir "/SystemFS/User"...
     Cr.dir "/SystemFS/User/Ax"...
     Cr.dir "/SystemFS/User/BluetoothPrint"...
     Cr.dir "/SystemFS/User/Br"...
     Cr.dir "/SystemFS/User/Cognima"...
     Cr.dir "/SystemFS/User/Cognima/shozu"...
     Cr.dir "/SystemFS/User/Ct"...
     Cr.dir "/SystemFS/User/Exe"...
     Cr.dir "/SystemFS/User/Exe/Java"...
     Cr.dir "/SystemFS/User/Exe/Mocha"...
     Cr.dir "/SystemFS/User/Exe/Mocha/App"...
     Cr.dir "/SystemFS/User/Exe/Mocha/Lib"...
     Cr.dir "/SystemFS/User/Fonts"...
     Cr.dir "/SystemFS/User/IMS"...
     Cr.dir "/SystemFS/User/MmApp"...
     Cr.dir "/SystemFS/User/MmApp/MovieMaker"...
     Cr.dir "/SystemFS/User/Mp"...
     Cr.dir "/SystemFS/User/Msg"...
     Cr.dir "/SystemFS/User/Msg/Tmpl"...
     Cr.dir "/SystemFS/User/MTP"...
     Cr.dir "/SystemFS/User/Mx"...
     Cr.dir "/SystemFS/User/OPW"...
     Cr.dir "/SystemFS/User/OPW/msg"...
     Cr.dir "/SystemFS/User/OPW/sys"...
     Cr.dir "/SystemFS/User/OPW/tmp"...
     Cr.dir "/SystemFS/User/OPW/voda"...
     Cr.dir "/SystemFS/User/Psh"...
     Cr.dir "/SystemFS/User/Psh/Default"...
     Cr.dir "/SystemFS/User/Qs"...
     Cr.dir "/SystemFS/User/Theme"...
     Cr.dir "/SystemFS/User/Theme/Default"...
     Cr.dir "/SystemFS/User/Theme/Install"...
     Cr.dir "/SystemFS/User/Widget"...
     Cr.dir "/User"...
     Cr.dir "/User/Ax"...
     Cr.dir "/User/BluetoothPrint"...
     Cr.dir "/User/Br"...
     Cr.dir "/User/Cognima"...
     Cr.dir "/User/Cognima/shozu"...
     Cr.dir "/User/Ct"...
     Cr.dir "/User/Exe"...
     Cr.dir "/User/Exe/Java"...
     Cr.dir "/User/Exe/Mocha"...
     Cr.dir "/User/Exe/Mocha/App"...
     Cr.dir "/User/Exe/Mocha/Lib"...
     Cr.dir "/User/Fonts"...
     Cr.dir "/User/IMS"...
     Cr.dir "/User/MmApp"...
     Cr.dir "/User/MmApp/MovieMaker"...
     Cr.dir "/User/Mp"...
     Cr.dir "/User/Msg"...
     Cr.dir "/User/Msg/Tmpl"...
     Cr.dir "/User/MTP"...
     Cr.dir "/User/Mx"...
     Cr.dir "/User/OPW"...
     Cr.dir "/User/OPW/msg"...
     Cr.dir "/User/OPW/sys"...
     Cr.dir "/User/OPW/tmp"...
     Cr.dir "/User/OPW/voda"...
     Cr.dir "/User/Psh"...
     Cr.dir "/User/Psh/Default"...
     Cr.dir "/User/Qs"...
     Cr.dir "/User/Theme"...
     Cr.dir "/User/Theme/Default"...
     Cr.dir "/User/Theme/Install"...
     Cr.dir "/User/Widget"...
     Writing a TFS Version...
      Wrt.file "/DB2/unlimitdb/phonedb_vol2.00" (16384 bytes)... OK!
     Wrt.file "/DB2/aslite.cfg" (37 bytes)... OK!
     Wrt.file "/DB2/phonedb_data.00" (688128 bytes)... OK!
     Wrt.file "/DB2/phonedb_indx.i0" (81920 bytes)... OK!
     Wrt.file "/DB2/phonedb_loganchor" (296 bytes)... OK!
     Wrt.file "/DB2/phonedb_logfile5" (67659 bytes)... OK!
     Wrt.file "/DB2/phonedb_mobile_lite.db" (8 bytes)... OK!
     Wrt.file "/DB2/phonedb_temp.t0" (16384 bytes)... OK!
     Wrt.file "/DB2/svcversion.ini" (4 bytes)... OK!
     Wrt.file "/Exe/Java/Games/Asphalt 4/Asphalt4_GUMI_QVGA_v6.5.5_Touch_WCG_withLibrary.jad" (674 bytes)... OK!
     Wrt.file "/Exe/Java/Games/Asphalt 4/Asphalt4_GUMI_QVGA_v6.5.5_Touch_WCG_withLibrary.jar" (492333 bytes)... OK!
     Wrt.file "/Exe/Java/Games/Asphalt 4/icon.png" (1555 bytes)... OK!
     Wrt.file "/Exe/Java/Games/Crazy penguin/CzaryPenguinCatapult_QVGA_v6.5.2_CIS_Touch.jad" (590 bytes)... OK!
     Wrt.file "/Exe/Java/Games/Crazy penguin/CzaryPenguinCatapult_QVGA_v6.5.2_CIS_Touch.jar" (337713 bytes)... OK!
     Wrt.file "/Exe/Java/Games/DJ Mix tour/DJMixTour_SUWON_QVGA_v6.5.1_CIS_Touch.jad" (599 bytes)... OK!
     Wrt.file "/Exe/Java/Games/DJ Mix tour/DJMixTour_SUWON_QVGA_v6.5.1_CIS_Touch.jar" (487133 bytes)... OK!
     Wrt.file "/Exe/Java/Games/DJ Mix tour/icon.png" (594 bytes)... OK!
     Wrt.file "/Exe/Java/Games/Monopoly/icon.png" (2683 bytes)... OK!
     Wrt.file "/Exe/Java/Games/Monopoly/Monopoly_QVGA_v6.5.2_CIS_Touch.jad" (561 bytes)... OK!
     Wrt.file "/Exe/Java/Games/Monopoly/Monopoly_QVGA_v6.5.2_CIS_Touch.jar" (591515 bytes)... OK!
     Wrt.file "/Exe/Java/Games/Pyramid bloxx/PyramidBloxx_QVGA_v6.5.2_CIS_Touch.jad" (605 bytes)... OK!
     Wrt.file "/Exe/Java/Games/Pyramid bloxx/PyramidBloxx_QVGA_v6.5.2_CIS_Touch.jar" (308353 bytes)... OK!
     Wrt.file "/Exe/Java/Locked Games/Checkers Deluxe/checkers_deluxe_sm_f480.jad" (348 bytes)... OK!
     Wrt.file "/Exe/Java/Locked Games/Checkers Deluxe/checkers_deluxe_sm_f480.jar" (90719 bytes)... OK!
     Wrt.file "/Exe/Java/Locked Games/Checkers Deluxe/icon.png" (211 bytes)... OK!
     Wrt.file "/Exe/Java/Locked Games/Content Explorer/ContentExplorer_QVGA_0.16.6.jad" (692 bytes)... OK!
     Wrt.file "/Exe/Java/Locked Games/Content Explorer/ContentExplorer_QVGA_0.16.6.jar" (297066 bytes)... OK!
     Wrt.file "/Exe/Java/Locked Games/Google Maps/GoogleMaps.jad" (966 bytes)... OK!
     Wrt.file "/Exe/Java/Locked Games/Google Maps/GoogleMaps.jar" (591394 bytes)... OK!
     Wrt.file "/Exe/Java/Locked Games/Google Maps/icon43x38.png" (3457 bytes)... OK!
     Wrt.file "/Exe/Java/jwc_properties.ini" (2712 bytes)... OK!
     Wrt.file "/Exe/Java/KJxDispatch.ini" (85 bytes)... OK!
     Wrt.file "/Media/Sounds/Music/Beyond Samsung.mp3" (4688910 bytes)... OK!
     Wrt.file "/Media/Sounds/Music/Flash Flash.mp3" (4891236 bytes)... OK!
     Wrt.file "/Media/Sounds/Music/Nothing Left To Say.mp3" (4931798 bytes)... OK!
     Wrt.file "/Registry/DevWlanProfile.ini" (2581 bytes)... OK!
     Wrt.file "/Registry/DualClock.ini" (1273 bytes)... OK!
     Wrt.file "/Registry/EditInputModeConfig.ini" (36 bytes)... OK!
     Wrt.file "/Registry/EmailSetup.ini" (2237 bytes)... OK!
     Wrt.file "/Registry/ImsPclSetup.ini" (28 bytes)... OK!
     Wrt.file "/Registry/ImsPoC.ini" (19 bytes)... OK!
     Wrt.file "/Registry/ImsPoCSettings.ini" (0 bytes)... OK!
     Wrt.file "/Registry/ImsProfiles.ini" (23 bytes)... OK!
     Wrt.file "/Registry/ImsReg.ini" (650 bytes)... OK!
     Wrt.file "/Registry/ImsSetup.ini" (617 bytes)... OK!
     Wrt.file "/Registry/ImsXDMSetup.ini" (0 bytes)... OK!
     Wrt.file "/Registry/MmsSetup.ini" (998 bytes)... OK!
     Wrt.file "/Registry/MmsTmpl.ini" (55 bytes)... OK!
     Wrt.file "/Registry/MpSetting.ini" (288 bytes)... OK!
     Wrt.file "/Registry/MsgSetting.ini" (42 bytes)... OK!
     Wrt.file "/Registry/P2PVshConfig.ini" (122 bytes)... OK!
     Wrt.file "/Registry/PostcardSetup.ini" (884 bytes)... OK!
     Wrt.file "/Registry/ProtoAccount.ini" (860 bytes)... OK!
     Wrt.file "/Registry/PshSetAccessPoint.ini" (165 bytes)... OK!
     Wrt.file "/Registry/RemoteSyncConfig.ini" (285 bytes)... OK!
     Wrt.file "/Registry/TapiConfig.ini" (91 bytes)... OK!
     Wrt.file "/Registry/TapiSmsConfig.ini" (260 bytes)... OK!
     Wrt.file "/Registry/WClock.ini" (1123 bytes)... OK!
     Wrt.file "/Security/Certs/ca-cert.der" (745 bytes)... OK!
     Wrt.file "/Security/Certs/my_cert.der" (782 bytes)... OK!
     Wrt.file "/Security/Certs/my_key.der" (319 bytes)... OK!
     Wrt.file "/Security/Certs/pca-cert.der" (746 bytes)... OK!
     Wrt.file "/Security/Certs/verisign.der" (774 bytes)... OK!
     Wrt.file "/Security/Certs/verisign_class3.der" (576 bytes)... OK!
     Wrt.file "/Security/Certs/verisign_rsa.der" (568 bytes)... OK!
     Wrt.file "/Security/Domain2Certs/samsungkey.der" (953 bytes)... OK!
     Wrt.file "/Security/Domain3Certs/GeoTrust_CA_for_UTI.der" (910 bytes)... OK!
     Wrt.file "/Security/Domain3Certs/VeriSignClass3_PPCA.crt" (576 bytes)... OK!
     Wrt.file "/Security/Domain3Certs/VeriSignClass3_PPCA_G2.crt" (774 bytes)... OK!
     Wrt.file "/Security/Domain3Certs/VeriSignClass3_PPCA_G3.crt" (1054 bytes)... OK!
     Wrt.file "/Security/Keyinfo/Client/RSA512/wap_root.bin" (163 bytes)... OK!
     Wrt.file "/Security/Keyinfo/RCA/RSA512/cawap_root.bin" (163 bytes)... OK!
     Wrt.file "/Security/Keyinfo/RCA/RSA512/cawap_root.pri" (346 bytes)... OK!
     Wrt.file "/Security/PROFILE/WIM.profile" (2909 bytes)... OK!
     Wrt.file "/Security/wmls.conf" (7680 bytes)... OK!
     Wrt.file "/Security/wtls.conf" (496 bytes)... OK!
     Wrt.file "/SystemFS/Country/Open_Slav" (12 bytes)... OK!
     Wrt.file "/SystemFS/Driver/STW_ISP_AIT848_128KB_v1.2A_20090601.bin" (126976 bytes)... OK!
     Wrt.file "/SystemFS/FFSCountry/F480I_Open_Europe_Slav_FS" (12 bytes)... OK!
     Wrt.file "/SystemFS/Media/Images/Candle Lights.bmp" (691256 bytes)... OK!
     Wrt.file "/SystemFS/Media/Images/Colored Canyon.bmp" (691256 bytes)... OK!
     Wrt.file "/SystemFS/Media/Images/Green Theme.bmp" (691256 bytes)... OK!
     Wrt.file "/SystemFS/Media/Images/Hills and Streams.bmp" (691256 bytes)... OK!
     Wrt.file "/SystemFS/Media/Images/Red Prestone.bmp" (691256 bytes)... OK!
     Wrt.file "/SystemFS/Media/Images/Saffron.bmp" (691256 bytes)... OK!
     Wrt.file "/SystemFS/Media/Images/Sunset.bmp" (691256 bytes)... OK!
     Wrt.file "/SystemFS/Media/Images/Water Drop.bmp" (691256 bytes)... OK!
     Wrt.file "/SystemFS/Media/Sounds/Ringtones/1960's.mp3" (495739 bytes)... OK!
     Wrt.file "/SystemFS/Media/Sounds/Ringtones/Animato Tone.mp3" (94242 bytes)... OK!
     Wrt.file "/SystemFS/Media/Sounds/Ringtones/Basic Piped Ring.mp3" (52544 bytes)... OK!
     Wrt.file "/SystemFS/Media/Sounds/Ringtones/Bugs' Song.mp3" (534080 bytes)... OK!
     Wrt.file "/SystemFS/Media/Sounds/Ringtones/City Light.mp3" (524288 bytes)... OK!
     Wrt.file "/SystemFS/Media/Sounds/Ringtones/Classic Bell.mp3" (69509 bytes)... OK!
     Wrt.file "/SystemFS/Media/Sounds/Ringtones/Cloudy Tone.mp3" (74643 bytes)... OK!
     Wrt.file "/SystemFS/Media/Sounds/Ringtones/Color Lounge.mp3" (517914 bytes)... OK!
     Wrt.file "/SystemFS/Media/Sounds/Ringtones/Elegant Arrival.mp3" (46862 bytes)... OK!
     Wrt.file "/SystemFS/Media/Sounds/Ringtones/Glass Bell Tone.mp3" (87728 bytes)... OK!
     Wrt.file "/SystemFS/Media/Sounds/Ringtones/Highway 101.mp3" (566286 bytes)... OK!
     Wrt.file "/SystemFS/Media/Sounds/Ringtones/Late Nite.mp3" (285282 bytes)... OK!
     Wrt.file "/SystemFS/Media/Sounds/Ringtones/Le Club.mp3" (270976 bytes)... OK!
     Wrt.file "/SystemFS/Media/Sounds/Ringtones/Look Back.mp3" (268474 bytes)... OK!
     Wrt.file "/SystemFS/Media/Sounds/Ringtones/Maze Of City.mp3" (542173 bytes)... OK!
     Wrt.file "/SystemFS/Media/Sounds/Ringtones/Samsung Tune.mp3" (431178 bytes)... OK!
     Wrt.file "/SystemFS/Media/Sounds/Ringtones/Slowly.mp3" (384891 bytes)... OK!
     Wrt.file "/SystemFS/Media/Sounds/Ringtones/Sunny Day.mp3" (262208 bytes)... OK!
     Wrt.file "/SystemFS/Media/Sounds/Ringtones/The Floor.mp3" (252702 bytes)... OK!
     Wrt.file "/SystemFS/Media/Sounds/Ringtones/Waterdrop Tone.mp3" (117103 bytes)... OK!
     Wrt.file "/SystemFS/MediaSet/Frame/Camera/Frame/Image/pf_01.gif" (13768 bytes)... OK!
     Wrt.file "/SystemFS/MediaSet/Frame/Camera/Frame/Image/pf_02.gif" (5309 bytes)... OK!
     Wrt.file "/SystemFS/MediaSet/Frame/Camera/Frame/Image/pf_03.gif" (20905 bytes)... OK!
     Wrt.file "/SystemFS/MediaSet/Frame/Camera/Frame/Image/pf_04.gif" (12114 bytes)... OK!
     Wrt.file "/SystemFS/MediaSet/Frame/Camera/Frame/Image/pf_05.gif" (9749 bytes)... OK!
     Wrt.file "/SystemFS/MediaSet/Frame/Camera/Frame/Image/pf_06.gif" (4111 bytes)... OK!
     Wrt.file "/SystemFS/MediaSet/Frame/Camera/Frame/Image/pf_07.gif" (25979 bytes)... OK!
     Wrt.file "/SystemFS/MediaSet/Frame/Camera/Frame/Image/pf_08.gif" (18077 bytes)... OK!
     Wrt.file "/SystemFS/MediaSet/Frame/Camera/Frame/Image/pf_09.gif" (17334 bytes)... OK!
     Wrt.file "/SystemFS/MediaSet/Frame/Camera/Frame/Image/pf_10.gif" (8593 bytes)... OK!
     Wrt.file "/SystemFS/MediaSet/Frame/Camera/Frame/Image/pf_11.gif" (26660 bytes)... OK!
     Wrt.file "/SystemFS/MediaSet/Frame/Camera/Frame/Image/pf_12.gif" (6080 bytes)... OK!
     Wrt.file "/SystemFS/MediaSet/Frame/Camera/Frame/Image/pf_13.gif" (26613 bytes)... OK!
     Wrt.file "/SystemFS/MediaSet/Frame/Camera/Frame/Image/pf_14.gif" (22947 bytes)... OK!
     Wrt.file "/SystemFS/MediaSet/Frame/Camera/Frame/Image/pf_15.gif" (16507 bytes)... OK!
     Wrt.file "/SystemFS/MediaSet/Frame/Camera/Frame/Image/pf_16.gif" (8307 bytes)... OK!
     Wrt.file "/SystemFS/MediaSet/Frame/Camera/Frame/Image/pf_17.gif" (14926 bytes)... OK!
     Wrt.file "/SystemFS/MediaSet/Frame/Camera/Frame/Image/pf_18.gif" (19877 bytes)... OK!
     Wrt.file "/SystemFS/MediaSet/Frame/Camera/Frame/Image/pf_19.gif" (21613 bytes)... OK!
     Wrt.file "/SystemFS/MediaSet/Frame/Camera/Frame/Image/pf_20.gif" (7890 bytes)... OK!
     Wrt.file "/SystemFS/MediaSet/Frame/Camera/Frame/Thumb/pf_01.gif" (1939 bytes)... OK!
     Wrt.file "/SystemFS/MediaSet/Frame/Camera/Frame/Thumb/pf_02.gif" (1619 bytes)... OK!
     Wrt.file "/SystemFS/MediaSet/Frame/Camera/Frame/Thumb/pf_03.gif" (2455 bytes)... OK!
     Wrt.file "/SystemFS/MediaSet/Frame/Camera/Frame/Thumb/pf_04.gif" (3198 bytes)... OK!
     Wrt.file "/SystemFS/MediaSet/Frame/Camera/Frame/Thumb/pf_05.gif" (1617 bytes)... OK!
     Wrt.file "/SystemFS/MediaSet/Frame/Camera/Frame/Thumb/pf_06.gif" (1839 bytes)... OK!
     Wrt.file "/SystemFS/MediaSet/Frame/Camera/Frame/Thumb/pf_07.gif" (2090 bytes)... OK!
     Wrt.file "/SystemFS/MediaSet/Frame/Camera/Frame/Thumb/pf_08.gif" (2362 bytes)... OK!
     Wrt.file "/SystemFS/MediaSet/Frame/Camera/Frame/Thumb/pf_09.gif" (2256 bytes)... OK!
     Wrt.file "/SystemFS/MediaSet/Frame/Camera/Frame/Thumb/pf_10.gif" (1584 bytes)... OK!
     Wrt.file "/SystemFS/MediaSet/Frame/Camera/Frame/Thumb/pf_11.gif" (1973 bytes)... OK!
     Wrt.file "/SystemFS/MediaSet/Frame/Camera/Frame/Thumb/pf_12.gif" (2792 bytes)... OK!
     Wrt.file "/SystemFS/MediaSet/Frame/Camera/Frame/Thumb/pf_13.gif" (2844 bytes)... OK!
     Wrt.file "/SystemFS/MediaSet/Frame/Camera/Frame/Thumb/pf_14.gif" (2695 bytes)... OK!
     Wrt.file "/SystemFS/MediaSet/Frame/Camera/Frame/Thumb/pf_15.gif" (2646 bytes)... OK!
     Wrt.file "/SystemFS/MediaSet/Frame/Camera/Frame/Thumb/pf_16.gif" (1657 bytes)... OK!
     Wrt.file "/SystemFS/MediaSet/Frame/Camera/Frame/Thumb/pf_17.gif" (2289 bytes)... OK!
     Wrt.file "/SystemFS/MediaSet/Frame/Camera/Frame/Thumb/pf_18.gif" (2715 bytes)... OK!
     Wrt.file "/SystemFS/MediaSet/Frame/Camera/Frame/Thumb/pf_19.gif" (2693 bytes)... OK!
     Wrt.file "/SystemFS/MediaSet/Frame/Camera/Frame/Thumb/pf_20.gif" (1822 bytes)... OK!
     Wrt.file "/SystemFS/MediaSet/Frame/Camera/Mosaic/Image/pmf_01_4.gif" (2660 bytes)... OK!
     Wrt.file "/SystemFS/MediaSet/Frame/Camera/Mosaic/Image/pmf_02_9.gif" (3509 bytes)... OK!
     Wrt.file "/SystemFS/MediaSet/Frame/Camera/Mosaic/Image/pmf_03_3.gif" (2780 bytes)... OK!
     Wrt.file "/SystemFS/MediaSet/Frame/Camera/Mosaic/Image/pmf_04_2.gif" (2083 bytes)... OK!
     Wrt.file "/SystemFS/MediaSet/Frame/Camera/Mosaic/Image/pmf_05_3.gif" (2572 bytes)... OK!
     Wrt.file "/SystemFS/MediaSet/Frame/Camera/Mosaic/Image/pmf_06_3.gif" (1991 bytes)... OK!
     Wrt.file "/SystemFS/MediaSet/Frame/Camera/Mosaic/Image/pmf_07_2.gif" (1935 bytes)... OK!
     Wrt.file "/SystemFS/MediaSet/Frame/Camera/Mosaic/Image/pmf_08_3.gif" (2350 bytes)... OK!
     Wrt.file "/SystemFS/MediaSet/Frame/Camera/Mosaic/Image/pmf_09_3.gif" (2729 bytes)... OK!
     Wrt.file "/SystemFS/MediaSet/Frame/Camera/Mosaic/Image/pmf_10_3.gif" (2701 bytes)... OK!
     Wrt.file "/SystemFS/MediaSet/Frame/Camera/Mosaic/Image/pmf_11_3.gif" (2476 bytes)... OK!
     Wrt.file "/SystemFS/MediaSet/Frame/Camera/Mosaic/Image/pmf_12_3.gif" (3050 bytes)... OK!
     Wrt.file "/SystemFS/MediaSet/Frame/Camera/Mosaic/Image/pmf_13_3.gif" (3352 bytes)... OK!
     Wrt.file "/SystemFS/MediaSet/Frame/Camera/Mosaic/Image/pmf_14_2.gif" (1974 bytes)... OK!
     Wrt.file "/SystemFS/MediaSet/Frame/Camera/Mosaic/Image/pmf_15_5.gif" (3090 bytes)... OK!
     Wrt.file "/SystemFS/MediaSet/Frame/Camera/Mosaic/Image/pmf_16_2.gif" (2407 bytes)... OK!
     Wrt.file "/SystemFS/MediaSet/Frame/Camera/Mosaic/Image/pmf_17_6.gif" (3360 bytes)... OK!
     Wrt.file "/SystemFS/MediaSet/Frame/Camera/Mosaic/Image/pmf_18_3.gif" (2922 bytes)... OK!
     Wrt.file "/SystemFS/MediaSet/Frame/Camera/Mosaic/Thumb/pmf_01_4.gif" (1380 bytes)... OK!
     Wrt.file "/SystemFS/MediaSet/Frame/Camera/Mosaic/Thumb/pmf_02_9.gif" (1678 bytes)... OK!
     Wrt.file "/SystemFS/MediaSet/Frame/Camera/Mosaic/Thumb/pmf_03_3.gif" (1884 bytes)... OK!
     Wrt.file "/SystemFS/MediaSet/Frame/Camera/Mosaic/Thumb/pmf_04_2.gif" (1494 bytes)... OK!
     Wrt.file "/SystemFS/MediaSet/Frame/Camera/Mosaic/Thumb/pmf_05_3.gif" (1391 bytes)... OK!
     Wrt.file "/SystemFS/MediaSet/Frame/Camera/Mosaic/Thumb/pmf_06_3.gif" (1545 bytes)... OK!
     Wrt.file "/SystemFS/MediaSet/Frame/Camera/Mosaic/Thumb/pmf_07_2.gif" (1534 bytes)... OK!
     Wrt.file "/SystemFS/MediaSet/Frame/Camera/Mosaic/Thumb/pmf_08_3.gif" (1741 bytes)... OK!
     Wrt.file "/SystemFS/MediaSet/Frame/Camera/Mosaic/Thumb/pmf_09_3.gif" (1553 bytes)... OK!
     Wrt.file "/SystemFS/MediaSet/Frame/Camera/Mosaic/Thumb/pmf_10_3.gif" (1875 bytes)... OK!
     Wrt.file "/SystemFS/MediaSet/Frame/Camera/Mosaic/Thumb/pmf_11_3.gif" (1535 bytes)... OK!
     Wrt.file "/SystemFS/MediaSet/Frame/Camera/Mosaic/Thumb/pmf_12_3.gif" (1936 bytes)... OK!
     Wrt.file "/SystemFS/MediaSet/Frame/Camera/Mosaic/Thumb/pmf_13_3.gif" (2048 bytes)... OK!
     Wrt.file "/SystemFS/MediaSet/Frame/Camera/Mosaic/Thumb/pmf_14_2.gif" (1552 bytes)... OK!
     Wrt.file "/SystemFS/MediaSet/Frame/Camera/Mosaic/Thumb/pmf_15_5.gif" (1924 bytes)... OK!
     Wrt.file "/SystemFS/MediaSet/Frame/Camera/Mosaic/Thumb/pmf_16_2.gif" (1471 bytes)... OK!
     Wrt.file "/SystemFS/MediaSet/Frame/Camera/Mosaic/Thumb/pmf_17_6.gif" (1667 bytes)... OK!
     Wrt.file "/SystemFS/MediaSet/Frame/Camera/Mosaic/Thumb/pmf_18_3.gif" (1856 bytes)... OK!
     Wrt.file "/SystemFS/MediaSet/Frame/Camera/QuickView/PolaroidBg_H.gif" (1255 bytes)... OK!
     Wrt.file "/SystemFS/MediaSet/Frame/Camera/QuickView/PolaroidBg_V.gif" (1255 bytes)... OK!
     Wrt.file "/SystemFS/MediaSet/Frame/Camera/Simulator/CaptureBitmapLandscape.jpg" (55382 bytes)... OK!
     Wrt.file "/SystemFS/MediaSet/Frame/Camera/Simulator/CaptureBitmapPanorama.jpg" (35263 bytes)... OK!
     Wrt.file "/SystemFS/MediaSet/Frame/Camera/Simulator/CaptureBitmapPortrait.jpg" (75209 bytes)... OK!
     Wrt.file "/SystemFS/MediaSet/Frame/Camera/Simulator/PolaroidBg.gif" (1255 bytes)... OK!
     Wrt.file "/SystemFS/MediaSet/Frame/ImgEditor/ThumbNail/06_image_editor_frame01_thumbnail.png" (9172 bytes)... OK!
     Wrt.file "/SystemFS/MediaSet/Frame/ImgEditor/ThumbNail/06_image_editor_frame02_thumbnail.png" (8839 bytes)... OK!
     Wrt.file "/SystemFS/MediaSet/Frame/ImgEditor/ThumbNail/06_image_editor_frame03_thumbnail.png" (7618 bytes)... OK!
     Wrt.file "/SystemFS/MediaSet/Frame/ImgEditor/ThumbNail/06_image_editor_frame04_thumbnail.png" (9194 bytes)... OK!
     Wrt.file "/SystemFS/MediaSet/Frame/ImgEditor/ThumbNail/06_image_editor_frame05_thumbnail.png" (8397 bytes)... OK!
     Wrt.file "/SystemFS/MediaSet/Frame/ImgEditor/ThumbNail/06_image_editor_frame06_thumbnail.png" (5328 bytes)... OK!
     Wrt.file "/SystemFS/MediaSet/Frame/ImgEditor/ThumbNail/06_image_editor_frame07_thumbnail.png" (7191 bytes)... OK!
     Wrt.file "/SystemFS/MediaSet/Frame/ImgEditor/ThumbNail/06_image_editor_frame08_thumbnail.png" (9505 bytes)... OK!
     Wrt.file "/SystemFS/MediaSet/Frame/ImgEditor/ThumbNail/06_image_editor_frame09_thumbnail.png" (7794 bytes)... OK!
     Wrt.file "/SystemFS/MediaSet/Frame/ImgEditor/ThumbNail/06_image_editor_frame10_thumbnail.png" (7338 bytes)... OK!
     Wrt.file "/SystemFS/MediaSet/Frame/ImgEditor/ThumbNail/06_image_editor_frame11_thumbnail.png" (7647 bytes)... OK!
     Wrt.file "/SystemFS/MediaSet/Frame/ImgEditor/ThumbNail/06_image_editor_frame12_thumbnail.png" (6207 bytes)... OK!
     Wrt.file "/SystemFS/MediaSet/Frame/ImgEditor/ThumbNail/06_image_editor_frame13_thumbnail.png" (7082 bytes)... OK!
     Wrt.file "/SystemFS/MediaSet/Frame/ImgEditor/ThumbNail/06_image_editor_frame14_thumbnail.png" (5768 bytes)... OK!
     Wrt.file "/SystemFS/MediaSet/Frame/ImgEditor/ThumbNail/06_image_editor_frame15_thumbnail.png" (5432 bytes)... OK!
     Wrt.file "/SystemFS/MediaSet/Frame/ImgEditor/ThumbNail/06_image_editor_frame16_thumbnail.png" (6258 bytes)... OK!
     Wrt.file "/SystemFS/MediaSet/Frame/ImgEditor/ThumbNail/06_image_editor_frame17_thumbnail.png" (5637 bytes)... OK!
     Wrt.file "/SystemFS/MediaSet/Frame/ImgEditor/ThumbNail/06_image_editor_frame18_thumbnail.png" (3899 bytes)... OK!
     Wrt.file "/SystemFS/MediaSet/Frame/ImgEditor/ThumbNail/06_image_editor_frame19_thumbnail.png" (6663 bytes)... OK!
     Wrt.file "/SystemFS/MediaSet/Frame/ImgEditor/ThumbNail/06_image_editor_frame20_thumbnail.png" (9955 bytes)... OK!
     Wrt.file "/SystemFS/MediaSet/Frame/ImgEditor/06_image_editor_frame01.png" (59941 bytes)... OK!
     Wrt.file "/SystemFS/MediaSet/Frame/ImgEditor/06_image_editor_frame02.png" (42934 bytes)... OK!
     Wrt.file "/SystemFS/MediaSet/Frame/ImgEditor/06_image_editor_frame03.png" (37480 bytes)... OK!
     Wrt.file "/SystemFS/MediaSet/Frame/ImgEditor/06_image_editor_frame04.png" (42597 bytes)... OK!
     Wrt.file "/SystemFS/MediaSet/Frame/ImgEditor/06_image_editor_frame05.png" (47719 bytes)... OK!
     Wrt.file "/SystemFS/MediaSet/Frame/ImgEditor/06_image_editor_frame06.png" (20738 bytes)... OK!
     Wrt.file "/SystemFS/MediaSet/Frame/ImgEditor/06_image_editor_frame07.png" (40591 bytes)... OK!
     Wrt.file "/SystemFS/MediaSet/Frame/ImgEditor/06_image_editor_frame08.png" (57470 bytes)... OK!
     Wrt.file "/SystemFS/MediaSet/Frame/ImgEditor/06_image_editor_frame09.png" (55307 bytes)... OK!
     Wrt.file "/SystemFS/MediaSet/Frame/ImgEditor/06_image_editor_frame10.png" (41388 bytes)... OK!
     Wrt.file "/SystemFS/MediaSet/Frame/ImgEditor/06_image_editor_frame11.png" (48238 bytes)... OK!
     Wrt.file "/SystemFS/MediaSet/Frame/ImgEditor/06_image_editor_frame12.png" (28224 bytes)... OK!
     Wrt.file "/SystemFS/MediaSet/Frame/ImgEditor/06_image_editor_frame13.png" (37644 bytes)... OK!
     Wrt.file "/SystemFS/MediaSet/Frame/ImgEditor/06_image_editor_frame14.png" (26994 bytes)... OK!
     Wrt.file "/SystemFS/MediaSet/Frame/ImgEditor/06_image_editor_frame15.png" (28906 bytes)... OK!
     Wrt.file "/SystemFS/MediaSet/Frame/ImgEditor/06_image_editor_frame16.png" (52882 bytes)... OK!
     Wrt.file "/SystemFS/MediaSet/Frame/ImgEditor/06_image_editor_frame17.png" (36977 bytes)... OK!
     Wrt.file "/SystemFS/MediaSet/Frame/ImgEditor/06_image_editor_frame18.png" (14105 bytes)... OK!
     Wrt.file "/SystemFS/MediaSet/Frame/ImgEditor/06_image_editor_frame19.png" (25839 bytes)... OK!
     Wrt.file "/SystemFS/MediaSet/Frame/ImgEditor/06_image_editor_frame20.png" (52277 bytes)... OK!
     Wrt.file "/SystemFS/MediaSet/MovieMaker/blackframe.jpg" (1023 bytes)... OK!
     Wrt.file "/SystemFS/MediaSet/MovieMaker/blackframe_qvga.jpg" (230454 bytes)... OK!
     Wrt.file "/SystemFS/MediaSet/MovieMaker/videoeditor_transition_bars.png" (1059 bytes)... OK!
     Wrt.file "/SystemFS/MediaSet/MovieMaker/videoeditor_transition_bars_qvga.png" (1865 bytes)... OK!
     Wrt.file "/SystemFS/MediaSet/MovieMaker/videoeditor_transition_checkboard.png" (474 bytes)... OK!
     Wrt.file "/SystemFS/MediaSet/MovieMaker/videoeditor_transition_checkboard_qvga.png" (1047 bytes)... OK!
     Wrt.file "/SystemFS/MediaSet/MovieMaker/videoeditor_transition_circle.png" (10033 bytes)... OK!
     Wrt.file "/SystemFS/MediaSet/MovieMaker/videoeditor_transition_circle_qvga.png" (26118 bytes)... OK!
     Wrt.file "/SystemFS/MediaSet/MovieMaker/videoeditor_transition_disolve.png" (58288 bytes)... OK!
     Wrt.file "/SystemFS/MediaSet/MovieMaker/videoeditor_transition_disolve_qvga.png" (119029 bytes)... OK!
     Wrt.file "/SystemFS/MediaSet/MovieMaker/videoeditor_transition_downleft.png" (518 bytes)... OK!
     Wrt.file "/SystemFS/MediaSet/MovieMaker/videoeditor_transition_downleft_qvga.png" (780 bytes)... OK!
     Wrt.file "/SystemFS/MediaSet/MovieMaker/videoeditor_transition_downright.png" (466 bytes)... OK!
     Wrt.file "/SystemFS/MediaSet/MovieMaker/videoeditor_transition_downright_qvga.png" (724 bytes).
The Following 14 Users Say Thank You to Sydney_Unlocker For This Useful Post:
Old 11-19-2009, 03:37   #2 (permalink)
Member: 1113892
Sonork: none
Thanks Meter: 62
i added to code tag . but don't know wt happen..
if moderate can edit the post . and enter code taag ?????????????
Old 11-19-2009, 05:48   #3 (permalink)
Member: 1113892
Sonork: none
Thanks Meter: 62
Another F480i Flashing Done.
Flashing take about 1 hour time
 * How to use Download Mode
      NAND Bad block check            > > > Not found
OK
      Download  Completed ( Elapsed Time :   0.9s)
      Download  Completed ( Elapsed Time :   9.0s)
      Download  Completed ( Elapsed Time : 1191.1s)
      Download  Completed ( Elapsed Time : 149.5s)
      Download  Completed ( Elapsed Time :   1.6s)
      Download  Completed ( Elapsed Time : 780.4s)
     TFS Format...     OK
 OK!
     TFS time set OK!
     Complete nand!
     Unmounting TFS!OK!
      Download  Completed ( Elapsed Time : 1008.3s)
  * TOTAL Elapsed Time : 3142.4s
PS.. Flashing Log is toooo long .. but can't put in CODE TAG , so i deleted some of logs.
The Following 3 Users Say Thank You to Sydney_Unlocker For This Useful Post:
Old 11-19-2009, 17:55   #4 (permalink)
Member: 652617
Thanks Meter: 10
where support,can I download downloader?
Old 11-19-2009, 18:18   #5 (permalink)
Member: 1086393
Thanks Meter: 771
share the link of exe??? Is this is integrated with ust? is it authorised??/
Old 11-19-2009, 23:47   #6 (permalink)
Member: 1113892
Sonork: none
Thanks Meter: 62
go to ust support area
Original Flash files
F480i folder
in the folder , there are Flash Files , Driver and Dowloader..
Thanks
The Following 2 Users Say Thank You to Sydney_Unlocker For This Useful Post:
Old 12-23-2009, 23:44   #7 (permalink)
Member: 739774
Thanks Meter: 89
F480i folder
Thanks
there is no F480i file on UST support area!!
Only F480 & F480L !!
Old 12-24-2009, 01:01   #8 (permalink)
Member: 1113892
Sonork: none
Thanks Meter: 62
Go to "
ORIGINAL FLASH FILE folder
you will find it there
Old 12-24-2009, 06:19   #9 (permalink)
kalpeshoza's Avatar
Member: 462292
Thanks Meter: 397
yes old method i done some pic with this way but now just press the one click and remove user code pls dont ask me how ? *3* .
Old 01-17-2010, 20:56   #10 (permalink)
Member: 1140833
Thanks Meter: 3
Thanks for this infos man canigale
Old 01-22-2010, 10:21   #11 (permalink)
GsmExpertz.Clt's Avatar
Member: 74036
Sonork: 100.1601291
Thanks Meter: 42
Try to open COM6 >Success!!
OK
Download Completed ( Elapsed Time : 1185.8s)
Download Completed ( Elapsed Time : 147.6s)
Download Completed ( Elapsed Time : 829.5s)
TFS Format... OK
Sending NAND CheckSum:cb9bd98
OK!
TFS time set OK!
Cr.dir "/DB"...
Cr.dir "/DB2"...
Cr.dir "/Debug"...
Cr.dir "/Exe"...
Cr.dir "/Exe/Java/Games/Party Island - Bubble Popper"...
Cr.dir "/Exe/Java/Games/PyramidBloxx"...
Cr.dir "/Exe/Java/Games/Wise Star"...
Cr.dir "/Media"...
Cr.dir "/Media/Sounds/Voice clips"...
Cr.dir "/Mount"...
Cr.dir "/SystemFS/Settings/PreConfiguration/Algeria"...
Cr.dir "/SystemFS/Settings/PreConfiguration/Algeria/Registry"...
Cr.dir "/SystemFS/Settings/PreConfiguration/Algeria/User"...
Cr.dir "/SystemFS/Settings/PreConfiguration/Algeria/User/Br"...
Cr.dir "/SystemFS/Settings/PreConfiguration/Austria"...
Cr.dir "/SystemFS/Settings/PreConfiguration/Austria/NV"...
Cr.dir "/SystemFS/Settings/PreConfiguration/Austria/Registry"...
Cr.dir "/SystemFS/Settings/PreConfiguration/Austria/User"...
Cr.dir "/SystemFS/Settings/PreConfiguration/Austria/User/Br"...
Cr.dir "/SystemFS/Settings/PreConfiguration/Belgium"...
Cr.dir "/SystemFS/Settings/PreConfiguration/Belgium/Registry"...
Cr.dir "/SystemFS/Settings/PreConfiguration/Belgium/User"...
Cr.dir "/SystemFS/Settings/PreConfiguration/Belgium/User/Br"...
Cr.dir "/SystemFS/Settings/PreConfiguration/Czecho"...
Cr.dir "/SystemFS/Settings/PreConfiguration/Czecho/NV"...
Cr.dir "/SystemFS/Settings/PreConfiguration/Czecho/Registry"...
Cr.dir "/SystemFS/Settings/PreConfiguration/Czecho/User"...
Cr.dir "/SystemFS/Settings/PreConfiguration/Czecho/User/Br"...
Cr.dir "/SystemFS/Settings/PreConfiguration/France"...
Cr.dir "/SystemFS/Settings/PreConfiguration/France/NV"...
Cr.dir "/SystemFS/Settings/PreConfiguration/France/Registry"...
Cr.dir "/SystemFS/Settings/PreConfiguration/France/User"...
Cr.dir "/SystemFS/Settings/PreConfiguration/France/User/Br"...
Cr.dir "/SystemFS/Settings/PreConfiguration/Germany"...
Cr.dir "/SystemFS/Settings/PreConfiguration/Germany/NV"...
Cr.dir "/SystemFS/Settings/PreConfiguration/Germany/Registry"...
Cr.dir "/SystemFS/Settings/PreConfiguration/Germany/User"...
Cr.dir "/SystemFS/Settings/PreConfiguration/Germany/User/Br"...
Cr.dir "/SystemFS/Settings/PreConfiguration/Germany_Debitel"...
Cr.dir "/SystemFS/Settings/PreConfiguration/Germany_Debitel/Registry"...
Cr.dir "/SystemFS/Settings/PreConfiguration/Germany_Debitel/User"...
Cr.dir "/SystemFS/Settings/PreConfiguration/Germany_Debitel/User/Br"...
Cr.dir "/SystemFS/Settings/PreConfiguration/Greece"...
Cr.dir "/SystemFS/Settings/PreConfiguration/Greece/NV"...
Cr.dir "/SystemFS/Settings/PreConfiguration/Greece/Registry"...
Cr.dir "/SystemFS/Settings/PreConfiguration/Greece/User"...
Cr.dir "/SystemFS/Settings/PreConfiguration/Greece/User/Br"...
Cr.dir "/SystemFS/Settings/PreConfiguration/Hungary"...
Cr.dir "/SystemFS/Settings/PreConfiguration/Hungary/NV"...
Cr.dir "/SystemFS/Settings/PreConfiguration/Hungary/Registry"...
Cr.dir "/SystemFS/Settings/PreConfiguration/Hungary/User"...
Cr.dir "/SystemFS/Settings/PreConfiguration/Hungary/User/Br"...
Cr.dir "/SystemFS/Settings/PreConfiguration/Ireland"...
Cr.dir "/SystemFS/Settings/PreConfiguration/Ireland/NV"...
Cr.dir "/SystemFS/Settings/PreConfiguration/Ireland/Registry"...
Cr.dir "/SystemFS/Settings/PreConfiguration/Ireland/User"...
Cr.dir "/SystemFS/Settings/PreConfiguration/Ireland/User/Br"...
Cr.dir "/SystemFS/Settings/PreConfiguration/Italy"...
Cr.dir "/SystemFS/Settings/PreConfiguration/Italy/NV"...
Cr.dir "/SystemFS/Settings/PreConfiguration/Italy/Registry"...
Cr.dir "/SystemFS/Settings/PreConfiguration/Italy/User"...
Cr.dir "/SystemFS/Settings/PreConfiguration/Italy/User/Br"...
Cr.dir "/SystemFS/Settings/PreConfiguration/Morocco"...
Cr.dir "/SystemFS/Settings/PreConfiguration/Morocco/Registry"...
Cr.dir "/SystemFS/Settings/PreConfiguration/Morocco/User"...
Cr.dir "/SystemFS/Settings/PreConfiguration/Morocco/User/Br"...
Cr.dir "/SystemFS/Settings/PreConfiguration/Netherlands"...
Cr.dir "/SystemFS/Settings/PreConfiguration/Netherlands/NV"...
Cr.dir "/SystemFS/Settings/PreConfiguration/Netherlands/Registry"...
Cr.dir "/SystemFS/Settings/PreConfiguration/Netherlands/User"...
Cr.dir "/SystemFS/Settings/PreConfiguration/Netherlands/User/Br"...
Cr.dir "/SystemFS/Settings/PreConfiguration/Nordic"...
Cr.dir "/SystemFS/Settings/PreConfiguration/Nordic/NV"...
Cr.dir "/SystemFS/Settings/PreConfiguration/OrangeAT"...
Cr.dir "/SystemFS/Settings/PreConfiguration/OrangeAT/NV"...
Cr.dir "/SystemFS/Settings/PreConfiguration/Poland"...
Cr.dir "/SystemFS/Settings/PreConfiguration/Poland/NV"...
Cr.dir "/SystemFS/Settings/PreConfiguration/Poland/Registry"...
Cr.dir "/SystemFS/Settings/PreConfiguration/Poland/User"...
Cr.dir "/SystemFS/Settings/PreConfiguration/Poland/User/Br"...
Cr.dir "/SystemFS/Settings/PreConfiguration/Portugal"...
Cr.dir "/SystemFS/Settings/PreConfiguration/Portugal/NV"...
Cr.dir "/SystemFS/Settings/PreConfiguration/Portugal/Registry"...
Cr.dir "/SystemFS/Settings/PreConfiguration/Portugal/User"...
Cr.dir "/SystemFS/Settings/PreConfiguration/Portugal/User/Br"...
Cr.dir "/SystemFS/Settings/PreConfiguration/Slovakia"...
Cr.dir "/SystemFS/Settings/PreConfiguration/Slovakia/NV"...
Cr.dir "/SystemFS/Settings/PreConfiguration/Slovakia/Registry"...
Cr.dir "/SystemFS/Settings/PreConfiguration/Slovakia/User"...
Cr.dir "/SystemFS/Settings/PreConfiguration/Slovakia/User/Br"...
Cr.dir "/SystemFS/Settings/PreConfiguration/SouthAfrica"...
Cr.dir "/SystemFS/Settings/PreConfiguration/SouthAfrica/NV"...
Cr.dir "/SystemFS/Settings/PreConfiguration/SouthAfrica/Registry"...
Cr.dir "/SystemFS/Settings/PreConfiguration/SouthAfrica/User"...
Cr.dir "/SystemFS/Settings/PreConfiguration/SouthAfrica/User/Br"...
Cr.dir "/SystemFS/Settings/PreConfiguration/Spain"...
Cr.dir "/SystemFS/Settings/PreConfiguration/Spain/NV"...
Cr.dir "/SystemFS/Settings/PreConfiguration/Spain/Registry"...
Cr.dir "/SystemFS/Settings/PreConfiguration/Spain/User"...
Cr.dir "/SystemFS/Settings/PreConfiguration/Spain/User/Br"...
Cr.dir "/SystemFS/Settings/PreConfiguration/Swiss"...
Cr.dir "/SystemFS/Settings/PreConfiguration/Swiss/NV"...
Cr.dir "/SystemFS/Settings/PreConfiguration/Swiss/Registry"...
Cr.dir "/SystemFS/Settings/PreConfiguration/Swiss/User"...
Cr.dir "/SystemFS/Settings/PreConfiguration/Swiss/User/Br"...
Cr.dir "/SystemFS/Settings/PreConfiguration/UK"...
Cr.dir "/SystemFS/Settings/PreConfiguration/UK/NV"...
Cr.dir "/SystemFS/Settings/PreConfiguration/UK/Registry"...
Cr.dir "/SystemFS/Settings/PreConfiguration/UK/User"...
Cr.dir "/SystemFS/Settings/PreConfiguration/UK/User/Br"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/Austria/One"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/Austria/One/Registry"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/Ireland/Vodafone"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/Ireland/Vodafone/Registry"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/Kazakhstan/K-Mobile"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/Kazakhstan/K-Mobile/Registry"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/Spain/Telefonica"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/Spain/Telefonica/Registry"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/UK/Vodafone_PAYT"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/UK/Vodafone_PAYT/Registry"...
Cr.dir "/User"...
Wrt.file "/DB2/phonedb_data.00" (327680 bytes)... OK!
Wrt.file "/DB2/phonedb_indx.i0" (32768 bytes)... OK!
Wrt.file "/DB2/phonedb_logfile3" (38608 bytes)... OK!
Wrt.file "/Exe/Java/Games/Crazy penguin/CzaryPenguinCatapult_QVGA_v6.4.3_Touch.jad" (590 bytes)... OK!
Wrt.file "/Exe/Java/Games/Crazy penguin/CzaryPenguinCatapult_QVGA_v6.4.3_Touch.jar" (380228 bytes)... OK!
Wrt.file "/Exe/Java/Games/Monopoly/Monopoly_QVGA_v6.4.1_Touch.jad" (708 bytes)... OK!
Wrt.file "/Exe/Java/Games/Monopoly/Monopoly_QVGA_v6.4.1_Touch.jar" (630563 bytes)... OK!
Wrt.file "/Exe/Java/Games/Party Island - Bubble Popper/partybubblepopper.jad" (2210 bytes)... OK!
Wrt.file "/Exe/Java/Games/Party Island - Bubble Popper/partybubblepopper.jar" (884927 bytes)... OK!
Wrt.file "/Exe/Java/Games/PyramidBloxx/PyramidBloxx_QVGA_v6.4.1_Touch.jad" (625 bytes)... OK!
Wrt.file "/Exe/Java/Games/PyramidBloxx/PyramidBloxx_QVGA_v6.4.1_Touch.jar" (372377 bytes)... OK!
Wrt.file "/Exe/Java/Games/Wise Star/WiseStar_Touch.jad" (2038 bytes)... OK!
Wrt.file "/Exe/Java/Games/Wise Star/WiseStar_Touch.jar" (518470 bytes)... OK!
Wrt.file "/Registry/DualClock.ini" (1301 bytes)... OK!
Wrt.file "/Registry/MmsSetup.ini" (1000 bytes)... OK!
Wrt.file "/Registry/PshSetAccessPoint.ini" (157 bytes)... OK!
Wrt.file "/Registry/TapiSmsConfig.ini" (258 bytes)... OK!
Wrt.file "/Security/Domain1Certs/Sonera Class1 CA der-bin.cer" (804 bytes)... OK!
Wrt.file "/Security/Domain1Certs/Sonera Class2 CA der-bin.cer" (804 bytes)... OK!
Wrt.file "/Security/Domain1Certs/Sonera Operator CA der-bin.cer" (819 bytes)... OK!
Wrt.file "/SystemFS/Driver/STW_ISP_AIT848_128KB_v1.29_20090508.bin" (126976 bytes)... OK!
Wrt.file "/SystemFS/MediaSet/Frame/Camera/Frame/Image/pf_01.gif" (15105 bytes)... OK!
Wrt.file "/SystemFS/MediaSet/MovieMaker/videoeditor_transition_downright_qvga.png" (724 bytes)... OK!
Wrt.file "/SystemFS/MediaSet/MovieMaker/videoeditor_transition_fade.png" (344 bytes)... OK!
Wrt.file "/SystemFS/MediaSet/MovieMaker/videoeditor_transition_fade_qvga.png" (602 bytes)... OK!
Wrt.file "/SystemFS/MediaSet/MovieMaker/videoeditor_transition_heart.png" (9027 bytes)... OK!
Wrt.file "/SystemFS/MediaSet/MovieMaker/videoeditor_transition_heart_qvga.png" (23539 bytes)... OK!
Wrt.file "/SystemFS/MediaSet/MovieMaker/videoeditor_transition_rectangle.png" (6394 bytes)... OK!
Wrt.file "/SystemFS/MediaSet/MovieMaker/videoeditor_transition_rectangle_qvga.png" (14502 bytes)... OK!
Wrt.file "/SystemFS/MediaSet/MovieMaker/videoeditor_transition_revealdown.png" (391 bytes)... OK!
Wrt.file "/SystemFS/MediaSet/MovieMaker/videoeditor_transition_revealdown_qvga.png" (650 bytes)... OK!
Wrt.file "/SystemFS/MediaSet/MovieMaker/videoeditor_transition_revealright.png" (382 bytes)... OK!
Wrt.file "/SystemFS/MediaSet/MovieMaker/videoeditor_transition_revealright_qvga.png" (642 bytes)... OK!
Wrt.file "/SystemFS/MediaSet/MovieMaker/videoeditor_transition_splithorizonal.png" (401 bytes)... OK!
Wrt.file "/SystemFS/MediaSet/MovieMaker/videoeditor_transition_splithorizonal_qvga.png" (657 bytes)... OK!
Wrt.file "/SystemFS/MediaSet/MovieMaker/videoeditor_transition_splitvertical.png" (400 bytes)... OK!
Wrt.file "/SystemFS/MediaSet/MovieMaker/videoeditor_transition_splitvertical_qvga.png" (662 bytes)... OK!
Wrt.file "/SystemFS/MediaSet/MovieMaker/videoeditor_transition_upleft.png" (465 bytes)... OK!
Wrt.file "/SystemFS/MediaSet/MovieMaker/videoeditor_transition_upleft_qvga.png" (717 bytes)... OK!
Wrt.file "/SystemFS/MediaSet/MovieMaker/videoeditor_transition_upright.png" (505 bytes)... OK!
Wrt.file "/SystemFS/MediaSet/MovieMaker/videoeditor_transition_upright_qvga.png" (759 bytes)... OK!
Wrt.file "/SystemFS/MediaSet/MovieMaker/videoeditor_transition_wheel.png" (10865 bytes)... OK!
Wrt.file "/SystemFS/MediaSet/MovieMaker/videoeditor_transition_wheel_qvga.png" (28199 bytes)... OK!
Wrt.file "/SystemFS/MediaSet/MovieMaker/videoeditor_transition_wipedown.png" (421 bytes)... OK!
Wrt.file "/SystemFS/MediaSet/MovieMaker/videoeditor_transition_wipedown_qvga.png" (1322 bytes)... OK!
Wrt.file "/SystemFS/MediaSet/MovieMaker/videoeditor_transition_wiperight.png" (417 bytes)... OK!
Wrt.file "/SystemFS/MediaSet/MovieMaker/videoeditor_transition_wiperight_qvga.png" (845 bytes)... OK!
Wrt.file "/SystemFS/MediaSet/Widget/AccuWeather.wgt" (1396465 bytes)... OK!
Wrt.file "/SystemFS/MediaSet/Widget/GoogleSearch.wgt" (16170 bytes)... OK!
Wrt.file "/SystemFS/MediaSet/Widget/moreWidget.wgt" (394908 bytes)... OK!
Wrt.file "/SystemFS/Settings/PreConfiguration/Algeria/Registry/EditInputModeConfig.ini" (36 bytes)... OK!
Wrt.file "/SystemFS/Settings/PreConfiguration/Algeria/Registry/EmailSetup.ini" (2237 bytes)... OK!
Wrt.file "/SystemFS/Settings/PreConfiguration/Algeria/Registry/MmsSetup.ini" (998 bytes)... OK!
Wrt.file "/SystemFS/Settings/PreConfiguration/Algeria/Registry/MmsTmpl.ini" (55 bytes)... OK!
Wrt.file "/SystemFS/Settings/PreConfiguration/Algeria/Registry/MpSetting.ini" (288 bytes)... OK!
Wrt.file "/SystemFS/Settings/PreConfiguration/Algeria/Registry/ProtoAccount.ini" (860 bytes)... OK!
Wrt.file "/SystemFS/Settings/PreConfiguration/Algeria/Registry/PshSetAccessPoint.ini" (157 bytes)... OK!
Wrt.file "/SystemFS/Settings/PreConfiguration/Algeria/Registry/RemoteSyncConfig.ini" (285 bytes)... OK!
Wrt.file "/SystemFS/Settings/PreConfiguration/Algeria/Registry/TapiConfig.ini" (91 bytes)... OK!
Wrt.file "/SystemFS/Settings/PreConfiguration/Algeria/Registry/TapiSmsConfig.ini" (260 bytes)... OK!
Wrt.file "/SystemFS/Settings/PreConfiguration/Algeria/Registry/WCl
Old 02-18-2010, 01:26   #12 (permalink)
Kashif Khan's Avatar
Member: 88016
Thanks Meter: 320
support area is slow,can someone upload on rapidshare?
downloader + Flash file +drivers?
Old 02-27-2010, 12:15   #13 (permalink)
Member: 88016
Thanks Meter: 320
1. Turn off the target phone!!!
2. Select COM Port(USB or UART) , Baud Rate.
3. Push the Start Button.
4. Turn on the target phone!!!
* Connecting to target phone
Try to open COM7 >Success!!
- Turn on the target phone immediately!!!!
Listen for the BOOT signal > > > OK
Send the Download start signal > > > OK
Listen for the Download start ACK signal > > > OK
* NAND Flash Driver Download
preloader downloading > > > OK
NAND Flash driver downloading > > > OK
Flash Type Checking > > > OK
NAND Bad block check > > > 1 Bad block found
P.Block[886] ---> S.Block[1002]
OK
UART Download Mode > > > Available
* NAND : Preboot Download
Preboot Download start!!
Download Completed ( Elapsed Time : 0.3s)
* NAND : Boot1a Download
Boot1 Download start!!
* NAND : Boot1b Download
Boot1b Download start!!
Download Completed ( Elapsed Time : 0.4s)
* NAND : Boot2 Download
Boot2 Download start!!
Download Completed ( Elapsed Time : 2.4s)
* NAND : APPS Download
APPS Download start!!
Download Completed ( Elapsed Time : 289.6s)
* NAND : COMMS Download
COMMS Download start!!
Download Completed ( Elapsed Time : 36.6s)
* NAND : Sys_ind Download
Sysparm Ind Download start!!
Download Completed ( Elapsed Time : 0.6s)
* NAND : Patch Download
Patch Download start!!
Download Completed ( Elapsed Time : 0.5s)
* NAND : Rsrc Download
Rsrc Download start!!
Download Completed ( Elapsed Time : 189.6s)
* NAND : TFS Download
TFS Download start!!
TFS Format... OK
** Mounting TFS system...
** Start Downloading TFS file **
Sending NAND CheckSum:c7bd81a3
OK!
TFS time set OK!
Cr.dir "/DB"...
Cr.dir "/DB2"...
Cr.dir "/DB2/unlimitdb"...
Cr.dir "/Debug"...
Cr.dir "/Exe"...
Cr.dir "/Exe/Java"...
Cr.dir "/Exe/Java/Games"...
Cr.dir "/Exe/Java/Games/Asphalt 4"...
Cr.dir "/Exe/Java/Games/Crazy penguin"...
Cr.dir "/Exe/Java/Games/DJ Mix tour"...
Cr.dir "/Exe/Java/Games/Monopoly"...
Cr.dir "/Exe/Java/Games/Pyramid bloxx"...
Cr.dir "/Exe/Java/Links"...
Cr.dir "/Exe/Java/Locked Games"...
Cr.dir "/Exe/Java/Locked Games/Checkers Deluxe"...
Cr.dir "/Exe/Java/Locked Games/Content Explorer"...
Cr.dir "/Exe/Java/Locked Games/Google Maps"...
Cr.dir "/Exe/Mocha"...
Cr.dir "/Exe/Mocha/App"...
Cr.dir "/Exe/Mocha/Lib"...
Cr.dir "/Media"...
Cr.dir "/Media/Images"...
Cr.dir "/Media/Images/My photos"...
Cr.dir "/Media/Other files"...
Cr.dir "/Media/Sounds"...
Cr.dir "/Media/Sounds/Music"...
Cr.dir "/Media/Sounds/Ringtones"...
Cr.dir "/Media/Videos"...
Cr.dir "/Media/Videos/My video clips"...
Cr.dir "/Mount"...
Cr.dir "/Registry"...
Cr.dir "/Security"...
Cr.dir "/Security/Certs"...
Cr.dir "/Security/CM"...
Cr.dir "/Security/DefaultPrivateCert"...
Cr.dir "/Security/DefaultRootCACerts"...
Cr.dir "/Security/DEVCerts"...
Cr.dir "/Security/DEVCerts/Domain1Certs"...
Cr.dir "/Security/DEVCerts/Domain2Certs"...
Cr.dir "/Security/DEVCerts/Domain3Certs"...
Cr.dir "/Security/DEVCerts/RootCACerts"...
Cr.dir "/Security/Domain1Certs"...
Cr.dir "/Security/Domain2Certs"...
Cr.dir "/Security/Domain3Certs"...
Cr.dir "/Security/Keyinfo"...
Cr.dir "/Security/Keyinfo/Client"...
Cr.dir "/Security/Keyinfo/Client/RSA512"...
Cr.dir "/Security/Keyinfo/RCA"...
Cr.dir "/Security/Keyinfo/RCA/RSA512"...
Cr.dir "/Security/PROFILE"...
Cr.dir "/Settings"...
Cr.dir "/Settings/Default"...
Cr.dir "/Settings/Default/NV"...
Cr.dir "/SystemFS"...
Cr.dir "/SystemFS/Country"...
Cr.dir "/SystemFS/DB"...
Cr.dir "/SystemFS/Driver"...
Cr.dir "/SystemFS/Driver/Pitch"...
Cr.dir "/SystemFS/FFSCountry"...
Cr.dir "/SystemFS/Media"...
Cr.dir "/SystemFS/Media/Images"...
Cr.dir "/SystemFS/Media/Images/My photos"...
Cr.dir "/SystemFS/Media/Other files"...
Cr.dir "/SystemFS/Media/Sounds"...
Cr.dir "/SystemFS/Media/Sounds/Ringtones"...
Cr.dir "/SystemFS/Media/Sounds/Voice clips"...
Cr.dir "/SystemFS/Media/Videos"...
Cr.dir "/SystemFS/Media/Videos/My video clips"...
Cr.dir "/SystemFS/MediaSet"...
Cr.dir "/SystemFS/MediaSet/Frame"...
Cr.dir "/SystemFS/MediaSet/Frame/Camera"...
Cr.dir "/SystemFS/MediaSet/Frame/Camera/Frame"...
Cr.dir "/SystemFS/MediaSet/Frame/Camera/Frame/Image"...
Cr.dir "/SystemFS/MediaSet/Frame/Camera/Frame/Thumb"...
Cr.dir "/SystemFS/MediaSet/Frame/Camera/Mosaic"...
Cr.dir "/SystemFS/MediaSet/Frame/Camera/Mosaic/Image"...
Cr.dir "/SystemFS/MediaSet/Frame/Camera/Mosaic/Thumb"...
Cr.dir "/SystemFS/MediaSet/Frame/Camera/QuickView"...
Cr.dir "/SystemFS/MediaSet/Frame/Camera/Simulator"...
Cr.dir "/SystemFS/MediaSet/Frame/ImgEditor"...
Cr.dir "/SystemFS/MediaSet/Frame/ImgEditor/ThumbNail"...
Cr.dir "/SystemFS/MediaSet/MovieMaker"...
Cr.dir "/SystemFS/MediaSet/UCS"...
Cr.dir "/SystemFS/MediaSet/UCS/Default"...
Cr.dir "/SystemFS/MediaSet/Widget"...
Cr.dir "/SystemFS/Settings"...
Cr.dir "/SystemFS/Settings/OperatorSettings"...
Cr.dir "/SystemFS/Settings/OperatorSettings/Baltic"...
Cr.dir "/SystemFS/Settings/OperatorSettings/Baltic/BiteLT"...
Cr.dir "/SystemFS/Settings/OperatorSettings/Baltic/BiteLT/Registry"...
Cr.dir "/SystemFS/Settings/OperatorSettings/Baltic/BiteLV"...
Cr.dir "/SystemFS/Settings/OperatorSettings/Baltic/BiteLV/Registry"...
Cr.dir "/SystemFS/Settings/OperatorSettings/Baltic/ElisaEE"...
Cr.dir "/SystemFS/Settings/OperatorSettings/Baltic/ElisaEE/Registry"...
Cr.dir "/SystemFS/Settings/OperatorSettings/Baltic/EmtEE"...
Cr.dir "/SystemFS/Settings/OperatorSettings/Baltic/EmtEE/Registry"...
Cr.dir "/SystemFS/Settings/OperatorSettings/Baltic/LmtLV"...
Cr.dir "/SystemFS/Settings/OperatorSettings/Baltic/LmtLV/Registry"...
Cr.dir "/SystemFS/Settings/OperatorSettings/Baltic/OmniLT"...
Cr.dir "/SystemFS/Settings/OperatorSettings/Baltic/OmniLT/Registry"...
Cr.dir "/SystemFS/Settings/OperatorSettings/Baltic/Tele2EE"...
Cr.dir "/SystemFS/Settings/OperatorSettings/Baltic/Tele2EE/Registry"...
Cr.dir "/SystemFS/Settings/OperatorSettings/Baltic/Tele2LT"...
Cr.dir "/SystemFS/Settings/OperatorSettings/Baltic/Tele2LT/Registry"...
Cr.dir "/SystemFS/Settings/OperatorSettings/Baltic/Tele2LV"...
Cr.dir "/SystemFS/Settings/OperatorSettings/Baltic/Tele2LV/Registry"...
Cr.dir "/SystemFS/Settings/OperatorSettings/Default"...
Cr.dir "/SystemFS/Settings/OperatorSettings/Default/None"...
Cr.dir "/SystemFS/Settings/OperatorSettings/Default/None/Registry"...
Cr.dir "/SystemFS/Settings/OperatorSettings/Kazakhstan"...
Cr.dir "/SystemFS/Settings/OperatorSettings/Kazakhstan/Kcell"...
Cr.dir "/SystemFS/Settings/OperatorSettings/Kazakhstan/Kcell/Registry"...
Cr.dir "/SystemFS/Settings/OperatorSettings/Kazakhstan/Kmobile"...
Cr.dir "/SystemFS/Settings/OperatorSettings/Kazakhstan/Kmobile/Registry"...
Cr.dir "/SystemFS/Settings/OperatorSettings/Romania"...
Cr.dir "/SystemFS/Settings/OperatorSettings/Russia"...
Cr.dir "/SystemFS/Settings/OperatorSettings/Russia/Beeline"...
Cr.dir "/SystemFS/Settings/OperatorSettings/Russia/Beeline/Registry"...
Cr.dir "/SystemFS/Settings/OperatorSettings/Russia/Megafon"...
Cr.dir "/SystemFS/Settings/OperatorSettings/Russia/Megafon/Registry"...
Cr.dir "/SystemFS/Settings/OperatorSettings/Russia/MTS"...
Cr.dir "/SystemFS/Settings/OperatorSettings/Russia/MTS/Registry"...
Cr.dir "/SystemFS/Settings/OperatorSettings/Ukraine"...
Cr.dir "/SystemFS/Settings/OperatorSettings/Ukraine/Beeline"...
Cr.dir "/SystemFS/Settings/OperatorSettings/Ukraine/Beeline/Registry"...
Cr.dir "/SystemFS/Settings/OperatorSettings/Ukraine/Kyivstar"...
Cr.dir "/SystemFS/Settings/OperatorSettings/Ukraine/Kyivstar/Registry"...
Cr.dir "/SystemFS/Settings/OperatorSettings/Ukraine/Life"...
Cr.dir "/SystemFS/Settings/OperatorSettings/Ukraine/Life/Registry"...
Cr.dir "/SystemFS/Settings/OperatorSettings/Ukraine/MTS"...
Cr.dir "/SystemFS/Settings/OperatorSettings/Ukraine/MTS/Registry"...
Cr.dir "/SystemFS/Settings/OperatorSettings/Ukraine/Utel"...
Cr.dir "/SystemFS/Settings/OperatorSettings/Ukraine/Utel/Registry"...
Cr.dir "/SystemFS/Settings/OperatorSettings/Uzbekistan"...
Cr.dir "/SystemFS/Settings/OperatorSettings/Uzbekistan/MTS"...
Cr.dir "/SystemFS/Settings/OperatorSettings/Uzbekistan/MTS/Registry"...
Cr.dir "/SystemFS/Settings/OperatorSettings/Uzbekistan/UNITEL"...
Cr.dir "/SystemFS/Settings/OperatorSettings/Uzbekistan/UNITEL/Registry"...
Cr.dir "/SystemFS/Settings/PreConfiguration"...
Cr.dir "/SystemFS/Settings/PreConfiguration/Baltic"...
Cr.dir "/SystemFS/Settings/PreConfiguration/Baltic/NV"...
Cr.dir "/SystemFS/Settings/PreConfiguration/Baltic/Registry"...
Cr.dir "/SystemFS/Settings/PreConfiguration/Baltic/User"...
Cr.dir "/SystemFS/Settings/PreConfiguration/Baltic/User/Br"...
Cr.dir "/SystemFS/Settings/PreConfiguration/Default"...
Cr.dir "/SystemFS/Settings/PreConfiguration/Default/NV"...
Cr.dir "/SystemFS/Settings/PreConfiguration/Default/Registry"...
Cr.dir "/SystemFS/Settings/PreConfiguration/Default/User"...
Cr.dir "/SystemFS/Settings/PreConfiguration/Default/User/Br"...
Cr.dir "/SystemFS/Settings/PreConfiguration/Kazakhstan"...
Cr.dir "/SystemFS/Settings/PreConfiguration/Kazakhstan/NV"...
Cr.dir "/SystemFS/Settings/PreConfiguration/Kazakhstan/Registry"...
Cr.dir "/SystemFS/Settings/PreConfiguration/Kazakhstan/User"...
Cr.dir "/SystemFS/Settings/PreConfiguration/Kazakhstan/User/Br"...
Cr.dir "/SystemFS/Settings/PreConfiguration/Russia"...
Cr.dir "/SystemFS/Settings/PreConfiguration/Russia/NV"...
Cr.dir "/SystemFS/Settings/PreConfiguration/Russia/Registry"...
Cr.dir "/SystemFS/Settings/PreConfiguration/Russia/User"...
Cr.dir "/SystemFS/Settings/PreConfiguration/Russia/User/Br"...
Cr.dir "/SystemFS/Settings/PreConfiguration/Ukraine"...
Cr.dir "/SystemFS/Settings/PreConfiguration/Ukraine/NV"...
Cr.dir "/SystemFS/Settings/PreConfiguration/Ukraine/Registry"...
Cr.dir "/SystemFS/Settings/PreConfiguration/Ukraine/User"...
Cr.dir "/SystemFS/Settings/PreConfiguration/Ukraine/User/Br"...
Cr.dir "/SystemFS/Settings/PreConfiguration/Uzbekistan"...
Cr.dir "/SystemFS/Settings/PreConfiguration/Uzbekistan/Registry"...
Cr.dir "/SystemFS/Settings/PreConfiguration/Uzbekistan/User"...
Cr.dir "/SystemFS/Settings/PreConfiguration/Uzbekistan/User/Br"...
Cr.dir "/SystemFS/Settings/SimAutoSettings"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/Algeria"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/Algeria/Djezzy"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/Algeria/Djezzy/Registry"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/Algeria/Mobilis"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/Algeria/Mobilis/Registry"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/Algeria/Nedjma"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/Algeria/Nedjma/Registry"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/Australia"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/Australia/Crazy"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/Australia/Crazy/Registry"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/Australia/H3G"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/Australia/H3G/Registry"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/Australia/Optus"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/Australia/Optus/Registry"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/Australia/Telstra"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/Australia/Telstra/Registry"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/Australia/Virgin"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/Australia/Virgin/Registry"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/Australia/Vodafone"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/Australia/Vodafone/Registry"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/Austria"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/Austria/A1"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/Austria/A1/Registry"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/Austria/Bob"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/Austria/Bob/Registry"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/Austria/H3G"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/Austria/H3G/Registry"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/Austria/Orange"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/Austria/Orange/Registry"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/Austria/T-Mobile"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/Austria/T-Mobile/Registry"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/Austria/Tele.ring"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/Austria/Tele.ring/Registry"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/Austria/Yesss!"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/Austria/Yesss!/Registry"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/Belgium"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/Belgium/Base"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/Belgium/Base/Registry"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/Belgium/Mobistar"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/Belgium/Mobistar/Registry"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/Belgium/Proximus"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/Belgium/Proximus/Registry"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/Bulgaria"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/Bulgaria/M-Tel"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/Bulgaria/M-Tel/Registry"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/Cyprus"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/Cyprus/CYTA"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/Cyprus/CYTA/Registry"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/Cyprus/MTN"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/Cyprus/MTN/Registry"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/Czech"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/Czech/Eurotel"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/Czech/Eurotel/Registry"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/Czech/O2"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/Czech/O2/Registry"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/Czech/T-Mobile"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/Czech/T-Mobile/Registry"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/Czech/Vodafone"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/Czech/Vodafone/Registry"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/Default"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/Default/None"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/Default/None/Registry"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/Denmark"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/Denmark/3"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/Denmark/3/Registry"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/Denmark/Sonofon"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/Denmark/Sonofon/Registry"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/Denmark/TDC"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/Denmark/TDC/Registry"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/Denmark/Telenor"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/Denmark/Telenor/Registry"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/Denmark/Telia"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/Denmark/Telia/Registry"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/Denmark/Telmore"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/Denmark/Telmore/Registry"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/Estonia"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/Estonia/Elisa"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/Estonia/Elisa/Registry"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/Estonia/EMT"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/Estonia/EMT/Registry"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/Estonia/Tele2"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/Estonia/Tele2/Registry"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/Finland"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/Finland/DNA"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/Finland/DNA/Registry"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/Finland/Elisa"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/Finland/Elisa/Registry"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/Finland/Saunalahti"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/Finland/Saunalahti/Registry"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/Finland/Sonera"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/Finland/Sonera/Registry"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/France"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/France/AUC"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/France/AUC/Registry"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/France/Bouygtel"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/France/Bouygtel/Registry"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/France/Carrefour"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/France/Carrefour/Registry"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/France/NRJ"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/France/NRJ/Registry"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/France/NRJ(ORANGE)"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/France/NRJ(ORANGE)/Registry"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/France/Orange"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/France/Orange/Registry"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/France/SFR"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/France/SFR/Registry"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/France/TELE2"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/France/TELE2/Registry"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/France/VirginMobile"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/France/VirginMobile/Registry"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/Germany"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/Germany/E-Plus"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/Germany/E-Plus/Registry"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/Germany/O2"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/Germany/O2/Registry"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/Germany/T-Mobile"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/Germany/T-Mobile/Registry"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/Germany/Vodafone"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/Germany/Vodafone/Registry"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/GermanyDebitel"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/GermanyDebitel/E-Plus"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/GermanyDebitel/E-Plus/Registry"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/GermanyDebitel/O2"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/GermanyDebitel/O2/Registry"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/GermanyDebitel/T-Mobile"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/GermanyDebitel/T-Mobile/Registry"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/GermanyDebitel/Vodafone"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/GermanyDebitel/Vodafone/Registry"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/Greece"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/Greece/Cosmote"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/Greece/Cosmote/Registry"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/Greece/TIM"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/Greece/TIM/Registry"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/Greece/Vodafone"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/Greece/Vodafone/Registry"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/Greece/Vodafone_Prepaid"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/Greece/Vodafone_Prepaid/Registry"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/Greece/Wind"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/Greece/Wind/Registry"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/Hungary"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/Hungary/Pannon"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/Hungary/Pannon/Registry"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/Hungary/T-Mobile"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/Hungary/T-Mobile/Registry"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/Hungary/Vodafone"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/Hungary/Vodafone/Registry"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/Iceland"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/Iceland/Nova"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/Iceland/Nova/Registry"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/Iceland/Siminn"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/Iceland/Siminn/Registry"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/Iceland/Vodafone_Iceland"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/Iceland/Vodafone_Iceland/Registry"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/Ireland"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/Ireland/H3G"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/Ireland/H3G/Registry"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/Ireland/Meteor"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/Ireland/Meteor/Registry"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/Ireland/O2"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/Ireland/O2/Registry"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/Ireland/Vodafone_PAYG"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/Ireland/Vodafone_PAYG/Registry"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/Ireland/Vodafone_Postpay"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/Ireland/Vodafone_Postpay/Registry"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/Italy"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/Italy/H3G"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/Italy/H3G/Registry"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/Italy/TIM"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/Italy/TIM/Registry"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/Italy/Vodafone"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/Italy/Vodafone/Registry"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/Italy/Wind"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/Italy/Wind/Registry"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/Italy/Wind_Biz"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/Italy/Wind_Biz/Registry"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/Kazakhstan"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/Kazakhstan/Beeline"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/Kazakhstan/Beeline/Registry"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/Kazakhstan/Kcell"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/Kazakhstan/Kcell/Registry"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/Kazakhstan/NEO"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/Kazakhstan/NEO/Registry"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/Korea"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/Korea/Gumi"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/Korea/Gumi/Registry"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/Korea/Suwon"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/Korea/Suwon/Registry"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/Latvia"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/Latvia/Bite"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/Latvia/Bite/Registry"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/Latvia/LMT"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/Latvia/LMT/Registry"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/Latvia/Tele2"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/Latvia/Tele2/Registry"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/Lithuania"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/Lithuania/Bite"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/Lithuania/Bite/Registry"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/Lithuania/Omnitel"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/Lithuania/Omnitel/Registry"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/Lithuania/Tele2"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/Lithuania/Tele2/Registry"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/Luxembourg"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/Luxembourg/LuxGSM"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/Luxembourg/LuxGSM/Registry"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/Luxembourg/Tango"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/Luxembourg/Tango/Registry"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/Luxembourg/Vox Mobile"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/Luxembourg/Vox Mobile/Registry"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/Malta"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/Malta/Vodafone"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/Malta/Vodafone/Registry"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/Morocco"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/Morocco/MAT"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/Morocco/MAT/Registry"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/Morocco/MED"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/Morocco/MED/Registry"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/Netherlands"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/Netherlands/KPN"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/Netherlands/KPN/Registry"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/Netherlands/Orange"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/Netherlands/Orange/Registry"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/Netherlands/T-Mobile"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/Netherlands/T-Mobile/Registry"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/Netherlands/Telefort"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/Netherlands/Telefort/Registry"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/Netherlands/Vodafone"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/Netherlands/Vodafone/Registry"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/Norway"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/Norway/Netcom"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/Norway/Netcom/Registry"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/Norway/Network N"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/Norway/Network N/Registry"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/Norway/TDC"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/Norway/TDC/Registry"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/Norway/Tele2"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/Norway/Tele2/Registry"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/Norway/Telenor"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/Norway/Telenor/Registry"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/Poland"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/Poland/Era"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/Poland/Era/Registry"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/Poland/Era_TakTak_Prepay"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/Poland/Era_TakTak_Prepay/Registry"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/Poland/Heyah"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/Poland/Heyah/Registry"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/Poland/Orange"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/Poland/Orange/Registry"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/Poland/Play"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/Poland/Play/Registry"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/Poland/Plus"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/Poland/Plus/Registry"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/Portugal"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/Portugal/Optimus"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/Portugal/Optimus/Registry"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/Portugal/TMN"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/Portugal/TMN/Registry"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/Portugal/Vodafone"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/Portugal/Vodafone/Registry"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/Romania"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/Romania/Connex"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/Romania/Connex/Registry"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/Romania/Cosmorom"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/Romania/Cosmorom/Registry"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/Romania/Orange"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/Romania/Orange/Registry"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/Romania/Vodafone"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/Romania/Vodafone/Registry"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/Romania/Vodafone_Prepay"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/Romania/Vodafone_Prepay/Registry"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/Russia"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/Russia/Beeline"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/Russia/Beeline/Registry"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/Russia/Megafon"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/Russia/Megafon/Registry"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/Russia/MTS"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/Russia/MTS/Registry"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/Slovak"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/Slovak/O2"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/Slovak/O2/Registry"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/Slovak/Orange"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/Slovak/Orange/Registry"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/Slovak/T-Mobile"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/Slovak/T-Mobile/Registry"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/Slovenia"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/Slovenia/Mobitel"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/Slovenia/Mobitel/Registry"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/Slovenia/SI-MOBIL"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/Slovenia/SI-MOBIL/Registry"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/Slovenia/Vodafone"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/Slovenia/Vodafone/Registry"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/SouthAfrica"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/SouthAfrica/CellC"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/SouthAfrica/CellC/Registry"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/SouthAfrica/MTN"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/SouthAfrica/MTN/Registry"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/SouthAfrica/Virgin"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/SouthAfrica/Virgin/Registry"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/SouthAfrica/Vodacom"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/SouthAfrica/Vodacom/Registry"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/Spain"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/Spain/Amena"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/Spain/Amena/Registry"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/Spain/Euskaltel"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/Spain/Euskaltel/Registry"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/Spain/movistar"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/Spain/movistar/Registry"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/Spain/Orange"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/Spain/Orange/Registry"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/Spain/Vodafone"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/Spain/Vodafone/Registry"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/Spain/Yoigo"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/Spain/Yoigo/Registry"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/Sweden"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/Sweden/3"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/Sweden/3/Registry"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/Sweden/Tele2"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/Sweden/Tele2/Registry"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/Sweden/Telenor"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/Sweden/Telenor/Registry"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/Sweden/Telia"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/Sweden/Telia/Registry"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/Switzerland"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/Switzerland/Orange"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/Switzerland/Orange/Registry"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/Switzerland/Sunrise"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/Switzerland/Sunrise/Registry"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/Switzerland/Swisscom"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/Switzerland/Swisscom/Registry"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/Tunisia"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/Tunisia/Tunisiana"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/Tunisia/Tunisiana/Registry"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/Tunisia/Tunisie_telecom"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/Tunisia/Tunisie_telecom/Registry"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/UK"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/UK/Asda"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/UK/Asda/Registry"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/UK/BT_Mobile"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/UK/BT_Mobile/Registry"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/UK/H3G"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/UK/H3G/Registry"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/UK/O2"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/UK/O2/Registry"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/UK/O2_Postpaid"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/UK/O2_Postpaid/Registry"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/UK/O2_Prepaid"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/UK/O2_Prepaid/Registry"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/UK/O2_Prepay"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/UK/O2_Prepay/Registry"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/UK/Orange"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/UK/Orange/Registry"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/UK/T-Mobile"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/UK/T-Mobile/Registry"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/UK/Tesco"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/UK/Tesco/Registry"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/UK/Virgin_Mobile"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/UK/Virgin_Mobile/Registry"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/UK/Vodafone_Contract"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/UK/Vodafone_Contract/Registry"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/UK/Vodafone_PAYG"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/UK/Vodafone_PAYG/Registry"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/Ukraine"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/Ukraine/Beeline"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/Ukraine/Beeline/Registry"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/Ukraine/Kyivstar"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/Ukraine/Kyivstar/Registry"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/Ukraine/Kyivstar_A&B"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/Ukraine/Kyivstar_A&B/Registry"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/Ukraine/Kyivstar_Djuice"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/Ukraine/Kyivstar_Djuice/Registry"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/Ukraine/Life"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/Ukraine/Life/Registry"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/Ukraine/MTS"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/Ukraine/MTS/Registry"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/Ukraine/Mts_*****"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/Ukraine/Mts_*****/Registry"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/Ukraine/Utel"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/Ukraine/Utel/Registry"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/Uzbekistan"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/Uzbekistan/Buztel"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/Uzbekistan/Buztel/Registry"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/Uzbekistan/MTS"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/Uzbekistan/MTS/Registry"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/Uzbekistan/Unitel"...
Cr.dir "/SystemFS/Settings/SimAutoSettings/Uzbekistan/Unitel/Registry"...
Cr.dir "/SystemFS/SlavFFSCountry"...
Cr.dir "/SystemFS/Test"...
Cr.dir "/SystemFS/Test/Sound"...
Cr.dir "/SystemFS/User"...
Cr.dir "/SystemFS/User/Ax"...
Cr.dir "/SystemFS/User/BluetoothPrint"...
Cr.dir "/SystemFS/User/Br"...
Cr.dir "/SystemFS/User/Cognima"...
Cr.dir "/SystemFS/User/Cognima/shozu"...
Cr.dir "/SystemFS/User/Ct"...
Cr.dir "/SystemFS/User/Exe"...
Cr.dir "/SystemFS/User/Exe/Java"...
Cr.dir "/SystemFS/User/Exe/Mocha"...
Cr.dir "/SystemFS/User/Exe/Mocha/App"...
Cr.dir "/SystemFS/User/Exe/Mocha/Lib"...
Cr.dir "/SystemFS/User/Fonts"...
Cr.dir "/SystemFS/User/IMS"...
Cr.dir "/SystemFS/User/MmApp"...
Cr.dir "/SystemFS/User/MmApp/MovieMaker"...
Cr.dir "/SystemFS/User/Mp"...
Cr.dir "/SystemFS/User/Msg"...
Cr.dir "/SystemFS/User/Msg/Tmpl"...
Cr.dir "/SystemFS/User/MTP"...
Cr.dir "/SystemFS/User/Mx"...
Cr.dir "/SystemFS/User/OPW"...
Cr.dir "/SystemFS/User/OPW/msg"...
Cr.dir "/SystemFS/User/OPW/sys"...
Cr.dir "/SystemFS/User/OPW/tmp"...
Cr.dir "/SystemFS/User/OPW/voda"...
Cr.dir "/SystemFS/User/Psh"...
Cr.dir "/SystemFS/User/Psh/Default"...
Cr.dir "/SystemFS/User/Qs"...
Cr.dir "/SystemFS/User/Theme"...
Cr.dir "/SystemFS/User/Theme/Default"...
Cr.dir "/SystemFS/User/Theme/Install"...
Cr.dir "/SystemFS/User/Widget"...
Cr.dir "/User"...
Cr.dir "/User/Ax"...
Cr.dir "/User/BluetoothPrint"...
Cr.dir "/User/Br"...
Cr.dir "/User/Cognima"...
Cr.dir "/User/Cognima/shozu"...
Cr.dir "/User/Ct"...
Cr.dir "/User/Exe"...
Cr.dir "/User/Exe/Java"...
Cr.dir "/User/Exe/Mocha"...
Cr.dir "/User/Exe/Mocha/App"...
Cr.dir "/User/Exe/Mocha/Lib"...
Cr.dir "/User/Fonts"...
Cr.dir "/User/IMS"...
Cr.dir "/User/MmApp"...
Cr.dir "/User/MmApp/MovieMaker"...
Cr.dir "/User/Mp"...
Cr.dir "/User/Msg"...
Cr.dir "/User/Msg/Tmpl"...
Cr.dir "/User/MTP"...
Cr.dir "/User/Mx"...
Cr.dir "/User/OPW"...
Cr.dir "/User/OPW/msg"...
Cr.dir "/User/OPW/sys"...
Cr.dir "/User/OPW/tmp"...
Cr.dir "/User/OPW/voda"...
Cr.dir "/User/Psh"...
Cr.dir "/User/Psh/Default"...
Cr.dir "/User/Qs"...
Cr.dir "/User/Theme"...
Cr.dir "/User/Theme/Default"...
Cr.dir "/User/Theme/Install"...
Cr.dir "/User/Widget"...
Writing a TFS Version...
Wrt.file "/DB2/unlimitdb/phonedb_vol2.00" (16384 bytes)... OK!
Wrt.file "/DB2/aslite.cfg" (37 bytes)... OK!
Wrt.file "/DB2/phonedb_data.00" (688128 bytes)... OK!
Wrt.file "/DB2/phonedb_indx.i0" (81920 bytes)... OK!
Wrt.file "/DB2/phonedb_loganchor" (296 bytes)... OK!
Wrt.file "/DB2/phonedb_logfile5" (67659 bytes)... OK!
Wrt.file "/DB2/phonedb_mobile_lite.db" (8 bytes)... OK!
Wrt.file "/DB2/phonedb_temp.t0" (16384 bytes)... OK!
Wrt.file "/DB2/svcversion.ini" (4 bytes)... OK!
Wrt.file "/Exe/Java/Games/Asphalt 4/Asphalt4_GUMI_QVGA_v6.5.5_Touch_WCG_withLibrary.ja d" (674 bytes)... OK!
Wrt.file "/Exe/Java/Games/Asphalt 4/Asphalt4_GUMI_QVGA_v6.5.5_Touch_WCG_withLibrary.ja r" (492333 bytes)... OK!
Wrt.file "/Exe/Java/Games/Asphalt 4/icon.png" (1555 bytes)... OK!
Wrt.file "/Exe/Java/Games/Crazy penguin/CzaryPenguinCatapult_QVGA_v6.5.2_CIS_Touch.jad" (590 bytes)... OK!
Wrt.file "/Exe/Java/Games/Crazy penguin/CzaryPenguinCatapult_QVGA_v6.5.2_CIS_Touch.jar" (337713 bytes)... OK!
Wrt.file "/Exe/Java/Games/DJ Mix tour/DJMixTour_SUWON_QVGA_v6.5.1_CIS_Touch.jad" (599 bytes)... OK!
Wrt.file "/Exe/Java/Games/DJ Mix tour/DJMixTour_SUWON_QVGA_v6.5.1_CIS_Touch.jar" (487133 bytes)... OK!
Wrt.file "/Exe/Java/Games/DJ Mix tour/icon.png" (594 bytes)... OK!
Wrt.file "/Exe/Java/Games/Monopoly/icon.png" (2683 bytes)... OK!
Wrt.file "/Exe/Java/Games/Monopoly/Monopoly_QVGA_v6.5.2_CIS_Touch.jad" (561 bytes)... OK!
Wrt.file "/Exe/Java/Games/Monopoly/Monopoly_QVGA_v6.5.2_CIS_Touch.jar" (591515 bytes)... OK!
Wrt.file "/Exe/Java/Games/Pyramid bloxx/PyramidBloxx_QVGA_v6.5.2_CIS_Touch.jad" (605 bytes)... OK!
Wrt.file "/Exe/Java/Games/Pyramid bloxx/PyramidBloxx_QVGA_v6.5.2_CIS_Touch.jar" (308353 bytes)... OK!
Wrt.file "/Exe/Java/Locked Games/Checkers Deluxe/checkers_deluxe_sm_f480.jad" (348 bytes)... OK!
Wrt.file "/Exe/Java/Locked Games/Checkers Deluxe/checkers_deluxe_sm_f480.jar" (90719 bytes)... OK!
Wrt.file "/Exe/Java/Locked Games/Checkers Deluxe/icon.png" (211 bytes)... OK!
Wrt.file "/Exe/Java/Locked Games/Content Explorer/ContentExplorer_QVGA_0.16.6.jad" (692 bytes)... OK!
Wrt.file "/Exe/Java/Locked Games/Content Explorer/ContentExplorer_QVGA_0.16.6.jar" (297066 bytes)... OK!
Wrt.file "/Exe/Java/Locked Games/Google Maps/GoogleMaps.jad" (966 bytes)... OK!
Wrt.file "/Exe/Java/Locked Games/Google Maps/GoogleMaps.jar" (591394 bytes)... OK!
Wrt.file "/Exe/Java/Locked Games/Google Maps/icon43x38.png" (3457 bytes)... OK!
Wrt.file "/Exe/Java/jwc_properties.ini" (2712 bytes)... OK!
Wrt.file "/Exe/Java/KJxDispatch.ini" (85 bytes)... OK!
Wrt.file "/Media/Sounds/Music/Beyond Samsung.mp3" (4688910 bytes)... OK!
Wrt.file "/Media/Sounds/Music/Flash Flash.mp3" (4891236 bytes)... OK!
Wrt.file "/Media/Sounds/Music/Nothing Left To Say.mp3" (4931798 bytes)... OK!
Wrt.file "/Registry/DevWlanProfile.ini" (2581 bytes)... OK!
Wrt.file "/Registry/DualClock.ini" (1273 bytes)... OK!
Wrt.file "/Registry/EditInputModeConfig.ini" (36 bytes)... OK!
Wrt.file "/Registry/EmailSetup.ini" (2237 bytes)... OK!
Wrt.file "/Registry/ImsPclSetup.ini" (28 bytes)... OK!
Wrt.file "/Registry/ImsPoC.ini" (19 bytes)... OK!
Wrt.file "/Registry/ImsPoCSettings.ini" (0 bytes)... OK!
Wrt.file "/Registry/ImsProfiles.ini" (23 bytes)... OK!
Wrt.file "/Registry/ImsReg.ini" (650 bytes)... OK!
Wrt.file "/Registry/ImsSetup.ini" (617 bytes)... OK!
Wrt.file "/Registry/ImsXDMSetup.ini" (0 bytes)... OK!
Wrt.file "/Registry/MmsSetup.ini" (998 bytes)... OK!
Wrt.file "/Registry/MmsTmpl.ini" (55 bytes)... OK!
Wrt.file "/Registry/MpSetting.ini" (288 bytes)... OK!
Wrt.file "/Registry/MsgSetting.ini" (42 bytes)... OK!
Wrt.file "/Registry/P2PVshConfig.ini" (122 bytes)... OK!
Wrt.file "/Registry/PostcardSetup.ini" (884 bytes)... OK!
Wrt.file "/Registry/ProtoAccount.ini" (860 bytes)... OK!
Wrt.file "/Registry/PshSetAccessPoint.ini" (165 bytes)... OK!
Wrt.file "/Registry/RemoteSyncConfig.ini" (285 bytes)... OK!
Wrt.file "/Registry/TapiConfig.ini" (91 bytes)... OK!
Wrt.file "/Registry/TapiSmsConfig.ini" (260 bytes)... OK!
Wrt.file "/Registry/WClock.ini" (1123 bytes)... OK!
Wrt.file "/Security/Certs/ca-cert.der" (745 bytes)... OK!
Wrt.file "/Security/Certs/my_cert.der" (782 bytes)... OK!
Wrt.file "/Security/Certs/my_key.der" (319 bytes)... OK!
Wrt.file "/Security/Certs/pca-cert.der" (746 bytes)... OK!
Wrt.file "/Security/Certs/verisign.der" (774 bytes)... OK!
Wrt.file "/Security/Certs/verisign_class3.der" (576 bytes)... OK!
Wrt.file "/Security/Certs/verisign_rsa.der" (568 bytes)... OK!
Wrt.file "/Security/Domain2Certs/samsungkey.der" (953 bytes)... OK!
Wrt.file "/Security/Domain3Certs/GeoTrust_CA_for_UTI.der" (910 bytes)... OK!
Wrt.file "/Security/Domain3Certs/VeriSignClass3_PPCA.crt" (576 bytes)... OK!
Wrt.file "/Security/Domain3Certs/VeriSignClass3_PPCA_G2.crt" (774 bytes)... OK!
Wrt.file "/Security/Domain3Certs/VeriSignClass3_PPCA_G3.crt" (1054 bytes)... OK!
Wrt.file "/Security/Keyinfo/Client/RSA512/wap_root.bin" (163 bytes)... OK!
Wrt.file "/Security/Keyinfo/RCA/RSA512/cawap_root.bin" (163 bytes)... OK!
Wrt.file "/Security/Keyinfo/RCA/RSA512/cawap_root.pri" (346 bytes)... OK!
Wrt.file "/Security/PROFILE/WIM.profile" (2909 bytes)... OK!
Wrt.file "/Security/wmls.conf" (7680 bytes)... OK!
Wrt.file "/Security/wtls.conf" (496 bytes)... OK!
Wrt.file "/SystemFS/Country/Open_Slav" (12 bytes)... OK!
Wrt.file "/SystemFS/Driver/STW_ISP_AIT848_128KB_v1.2A_20090601.bin" (126976 bytes)... OK!
Wrt.file "/SystemFS/FFSCountry/F480I_Open_Europe_Slav_FS" (12 bytes)... OK!
Wrt.file "/SystemFS/Media/Images/Candle Lights.bmp" (691256 bytes)... OK!
Wrt.file "/SystemFS/Media/Images/Colored Canyon.bmp" (691256 bytes)... OK!
Wrt.file "/SystemFS/Media/Images/Green Theme.bmp" (691256 bytes)... OK!
Wrt.file "/SystemFS/Media/Images/Hills and Streams.bmp" (691256 bytes)... OK!
Wrt.file "/SystemFS/Media/Images/Red Prestone.bmp" (691256 bytes)... OK!
Wrt.file "/SystemFS/Media/Images/Saffron.bmp" (691256 bytes)... OK!
Wrt.file "/SystemFS/Media/Images/Sunset.bmp" (691256 bytes)... OK!
Wrt.file "/SystemFS/Media/Images/Water Drop.bmp" (691256 bytes)... OK!
Wrt.file "/SystemFS/Media/Sounds/Ringtones/1960's.mp3" (495739 bytes)... OK!
Wrt.file "/SystemFS/Media/Sounds/Ringtones/Animato Tone.mp3" (94242 bytes)... OK!
Wrt.file "/SystemFS/Media/Sounds/Ringtones/Basic Piped Ring.mp3" (52544 bytes)... OK!
Wrt.file "/SystemFS/Media/Sounds/Ringtones/Bugs' Song.mp3" (534080 bytes)... OK!
Wrt.file "/SystemFS/Media/Sounds/Ringtones/City Light.mp3" (524288 bytes)... OK!
Wrt.file "/SystemFS/Media/Sounds/Ringtones/Classic Bell.mp3" (69509 bytes)... OK!
Wrt.file "/SystemFS/Media/Sounds/Ringtones/Cloudy Tone.mp3" (74643 bytes)... OK!
Wrt.file "/SystemFS/Media/Sounds/Ringtones/Color Lounge.mp3" (517914 bytes)... OK!
Wrt.file "/SystemFS/Media/Sounds/Ringtones/Elegant Arrival.mp3" (46862 bytes)... OK!
Wrt.file "/SystemFS/Media/Sounds/Ringtones/Glass Bell Tone.mp3" (87728 bytes)... OK!
Wrt.file "/SystemFS/Media/Sounds/Ringtones/Highway 101.mp3" (566286 bytes)... OK!
Wrt.file "/SystemFS/Media/Sounds/Ringtones/Late Nite.mp3" (285282 bytes)... OK!
Wrt.file "/SystemFS/Media/Sounds/Ringtones/Le Club.mp3" (270976 bytes)... OK!
Wrt.file "/SystemFS/Media/Sounds/Ringtones/Look Back.mp3" (268474 bytes)... OK!
Wrt.file "/SystemFS/Media/Sounds/Ringtones/Maze Of City.mp3" (542173 bytes)... OK!
Wrt.file "/SystemFS/Media/Sounds/Ringtones/Samsung Tune.mp3" (431178 bytes)... OK!
Wrt.file "/SystemFS/Media/Sounds/Ringtones/Slowly.mp3" (384891 bytes)... OK!
Wrt.file "/SystemFS/Media/Sounds/Ringtones/Sunny Day.mp3" (262208 bytes)... OK!
Wrt.file "/SystemFS/Media/Sounds/Ringtones/The Floor.mp3" (252702 bytes)... OK!
Wrt.file "/SystemFS/Media/Sounds/Ringtones/Waterdrop Tone.mp3" (117103 bytes)... OK!
Wrt.file "/SystemFS/MediaSet/Frame/Camera/Frame/Image/pf_01.gif" (13768 bytes)... OK!
Wrt.file "/SystemFS/MediaSet/Frame/Camera/Frame/Image/pf_02.gif" (5309 bytes)... OK!
Wrt.file "/SystemFS/MediaSet/Frame/Camera/Frame/Image/pf_03.gif" (20905 bytes)... OK!
Wrt.file "/SystemFS/MediaSet/Frame/Camera/Frame/Image/pf_04.gif" (12114 bytes)... OK!
Wrt.file "/SystemFS/MediaSet/Frame/Camera/Frame/Image/pf_05.gif" (9749 bytes)... OK!
Wrt.file "/SystemFS/MediaSet/Frame/Camera/Frame/Image/pf_06.gif" (4111 bytes)... OK!
Wrt.file "/SystemFS/MediaSet/Frame/Camera/Frame/Image/pf_07.gif" (25979 bytes)... OK!
Wrt.file "/SystemFS/MediaSet/Frame/Camera/Frame/Image/pf_08.gif" (18077 bytes)... OK!
Wrt.file "/SystemFS/MediaSet/Frame/Camera/Frame/Image/pf_09.gif" (17334 bytes)... OK!
Wrt.file "/SystemFS/MediaSet/Frame/Camera/Frame/Image/pf_10.gif" (8593 bytes)... OK!
Wrt.file "/SystemFS/MediaSet/Frame/Camera/Frame/Image/pf_11.gif" (26660 bytes)... OK!
Wrt.file "/SystemFS/MediaSet/Frame/Camera/Frame/Image/pf_12.gif" (6080 bytes)... OK!
Wrt.file "/SystemFS/MediaSet/Frame/Camera/Frame/Image/pf_13.gif" (26613 bytes)... OK!
Wrt.file "/SystemFS/MediaSet/Frame/Camera/Frame/Image/pf_14.gif" (22947 bytes)... OK!
Wrt.file "/SystemFS/MediaSet/Frame/Camera/Frame/Image/pf_15.gif" (16507 bytes)... OK!
Wrt.file "/SystemFS/MediaSet/Frame/Camera/Frame/Image/pf_16.gif" (8307 bytes)... OK!
Wrt.file "/SystemFS/MediaSet/Frame/Camera/Frame/Image/pf_17.gif" (14926 bytes)... OK!
Wrt.file "/SystemFS/MediaSet/Frame/Camera/Frame/Image/pf_18.gif" (19877 bytes)... OK!
Wrt.file "/SystemFS/MediaSet/Frame/Camera/Frame/Image/pf_19.gif" (21613 bytes)... OK!
Wrt.file "/SystemFS/MediaSet/Frame/Camera/Frame/Image/pf_20.gif" (7890 bytes)... OK!
Wrt.file "/SystemFS/MediaSet/Frame/Camera/Frame/Thumb/pf_01.gif" (1939 bytes)... OK!
Wrt.file "/SystemFS/MediaSet/Frame/Camera/Frame/Thumb/pf_02.gif" (1619 bytes)... OK!
Wrt.file "/SystemFS/MediaSet/Frame/Camera/Frame/Thumb/pf_03.gif" (2455 bytes)... OK!
Wrt.file "/SystemFS/MediaSet/Frame/Camera/Frame/Thumb/pf_04.gif" (3198 bytes)... OK!
Wrt.file "/SystemFS/MediaSet/Frame/Camera/Frame/Thumb/pf_05.gif" (1617 bytes)... OK!
Wrt.file "/SystemFS/MediaSet/Frame/Camera/Frame/Thumb/pf_06.gif" (1839 bytes)... OK!
Wrt.file "/SystemFS/MediaSet/Frame/Camera/Frame/Thumb/pf_07.gif" (2090 bytes)... OK!
Wrt.file "/SystemFS/MediaSet/Frame/Camera/Frame/Thumb/pf_08.gif" (2362 bytes)... OK!
Wrt.file "/SystemFS/MediaSet/Frame/Camera/Frame/Thumb/pf_09.gif" (2256 bytes)... OK!
Wrt.file "/SystemFS/MediaSet/Frame/Camera/Frame/Thumb/pf_10.gif" (1584 bytes)... OK!
Wrt.file "/SystemFS/MediaSet/Frame/Camera/Frame/Thumb/pf_11.gif" (1973 bytes)... OK!
Wrt.file "/SystemFS/MediaSet/Frame/Camera/Frame/Thumb/pf_12.gif" (2792 bytes)... OK!
Wrt.file "/SystemFS/MediaSet/Frame/Camera/Frame/Thumb/pf_13.gif" (2844 bytes)... OK!
Wrt.file "/SystemFS/MediaSet/Frame/Camera/Frame/Thumb/pf_14.gif" (2695 bytes)... OK!
Wrt.file "/SystemFS/MediaSet/Frame/Camera/Frame/Thumb/pf_15.gif" (2646 bytes)... OK!
Wrt.file "/SystemFS/MediaSet/Frame/Camera/Frame/Thumb/pf_16.gif" (1657 bytes)... OK!
Wrt.file "/SystemFS/MediaSet/Frame/Camera/Frame/Thumb/pf_17.gif" (2289 bytes)... OK!
Wrt.file "/SystemFS/MediaSet/Frame/Camera/Frame/Thumb/pf_18.gif" (2715 bytes)... OK!
Wrt.file "/SystemFS/MediaSet/Frame/Camera/Frame/Thumb/pf_19.gif" (2693 bytes)... OK!
Wrt.file "/SystemFS/MediaSet/Frame/Camera/Frame/Thumb/pf_20.gif" (1822 bytes)... OK!
Wrt.file "/SystemFS/MediaSet/Frame/Camera/Mosaic/Image/pmf_01_4.gif" (2660 bytes)... OK!
Wrt.file "/SystemFS/MediaSet/Frame/Camera/Mosaic/Image/pmf_02_9.gif" (3509 bytes)... OK!
Wrt.file "/SystemFS/MediaSet/Frame/Camera/Mosaic/Image/pmf_03_3.gif" (2780 bytes)... OK!
Wrt.file "/SystemFS/MediaSet/Frame/Camera/Mosaic/Image/pmf_04_2.gif" (2083 bytes)... OK!
Wrt.file "/SystemFS/MediaSet/Frame/Camera/Mosaic/Image/pmf_05_3.gif" (2572 bytes)... OK!
Wrt.file "/SystemFS/MediaSet/Frame/Camera/Mosaic/Image/pmf_06_3.gif" (1991 bytes)... OK!
Wrt.file "/SystemFS/MediaSet/Frame/Camera/Mosaic/Image/pmf_07_2.gif" (1935 bytes)... OK!
Wrt.file "/SystemFS/MediaSet/Frame/Camera/Mosaic/Image/pmf_08_3.gif" (2350 bytes)... OK!
Wrt.file "/SystemFS/MediaSet/Frame/Camera/Mosaic/Image/pmf_09_3.gif" (2729 bytes)... OK!
Wrt.file "/SystemFS/MediaSet/Frame/Camera/Mosaic/Image/pmf_10_3.gif" (2701 bytes)... OK!
Wrt.file "/SystemFS/MediaSet/Frame/Camera/Mosaic/Image/pmf_11_3.gif" (2476 bytes)... OK!
Wrt.file "/SystemFS/MediaSet/Frame/Camera/Mosaic/Image/pmf_12_3.gif" (3050 bytes)... OK!
Wrt.file "/SystemFS/MediaSet/Frame/Camera/Mosaic/Image/pmf_13_3.gif" (3352 bytes)... OK!
Wrt.file "/SystemFS/MediaSet/Frame/Camera/Mosaic/Image/pmf_14_2.gif" (1974 bytes)... OK!
Wrt.file "/SystemFS/MediaSet/Frame/Camera/Mosaic/Image/pmf_15_5.gif" (3090 bytes)... OK!
Wrt.file "/SystemFS/MediaSet/Frame/Camera/Mosaic/Image/pmf_16_2.gif" (2407 bytes)... OK!
Wrt.file "/SystemFS/MediaSet/Frame/Camera/Mosaic/Image/pmf_17_6.gif" (3360 bytes)... OK!
Wrt.file "/SystemFS/MediaSet/Frame/Camera/Mosaic/Image/pmf_18_3.gif" (2922 bytes)... OK!
Wrt.file "/SystemFS/MediaSet/Frame/Camera/Mosaic/Thumb/pmf_01_4.gif" (1380 bytes)... OK!
Wrt.file "/SystemFS/MediaSet/Frame/Camera/Mosaic/Thumb/pmf_02_9.gif" (1678 bytes)... OK!
Wrt.file "/SystemFS/MediaSet/Frame/Camera/Mosaic/Thumb/pmf_03_3.gif" (1884 bytes)... OK!
Wrt.file "/SystemFS/MediaSet/Frame/Camera/Mosaic/Thumb/pmf_04_2.gif" (1494 bytes)... OK!
Wrt.file "/SystemFS/MediaSet/Frame/Camera/Mosaic/Thumb/pmf_05_3.gif" (1391 bytes)... OK!
Wrt.file "/SystemFS/MediaSet/Frame/Camera/Mosaic/Thumb/pmf_06_3.gif" (1545 bytes)... OK!
Wrt.file "/SystemFS/MediaSet/Frame/Camera/Mosaic/Thumb/pmf_07_2.gif" (1534 bytes)... OK!
Wrt.file "/SystemFS/MediaSet/Frame/Camera/Mosaic/Thumb/pmf_08_3.gif" (1741 bytes)... OK!
Wrt.file "/SystemFS/MediaSet/Frame/Camera/Mosaic/Thumb/pmf_09_3.gif" (1553 bytes)... OK!
Wrt.file "/SystemFS/MediaSet/Frame/Camera/Mosaic/Thumb/pmf_10_3.gif" (1875 bytes)... OK!
Wrt.file "/SystemFS/MediaSet/Frame/Camera/Mosaic/Thumb/pmf_11_3.gif" (1535 bytes)... OK!
Wrt.file "/SystemFS/MediaSet/Frame/Camera/Mosaic/Thumb/pmf_12_3.gif" (1936 bytes)... OK!
Wrt.file "/SystemFS/MediaSet/Frame/Camera/Mosaic/Thumb/pmf_13_3.gif" (2048 bytes)... OK!
Wrt.file "/SystemFS/MediaSet/Frame/Camera/Mosaic/Thumb/pmf_14_2.gif" (1552 bytes)... OK!
Wrt.file "/SystemFS/MediaSet/Frame/Camera/Mosaic/Thumb/pmf_15_5.gif" (1924 bytes)... OK!
Wrt.file "/SystemFS/MediaSet/Frame/Camera/Mosaic/Thumb/pmf_16_2.gif" (1471 bytes)... OK!
Wrt.file "/SystemFS/MediaSet/Frame/Camera/Mosaic/Thumb/pmf_17_6.gif" (1667 bytes)... OK!
Wrt.file "/SystemFS/MediaSet/Frame/Camera/Mosaic/Thumb/pmf_18_3.gif" (1856 bytes)... OK!
Wrt.file "/SystemFS/MediaSet/Frame/Camera/QuickView/PolaroidBg_H.gif" (1255 bytes)... OK!
Wrt.file "/SystemFS/MediaSet/Frame/Camera/QuickView/PolaroidBg_V.gif" (1255 bytes)... OK!
Wrt.file "/SystemFS/MediaSet/Frame/Camera/Simulator/CaptureBitmapLandscape.jpg" (55382 bytes)... OK!
Wrt.file "/SystemFS/MediaSet/Frame/Camera/Simulator/CaptureBitmapPanorama.jpg" (35263 bytes)... OK!
Wrt.file "/SystemFS/MediaSet/Frame/Camera/Simulator/CaptureBitmapPortrait.jpg" (75209 bytes)... OK!
Wrt.file "/SystemFS/MediaSet/Frame/Camera/Simulator/PolaroidBg.gif" (1255 bytes)... OK!
Wrt.file "/SystemFS/MediaSet/Frame/ImgEditor/ThumbNail/06_image_editor_frame01_thumbnail.png" (9172 bytes)... OK!
Wrt.file "/SystemFS/MediaSet/Frame/ImgEditor/ThumbNail/06_image_editor_frame02_thumbnail.png" (8839 bytes)... OK!
Wrt.file "/SystemFS/MediaSet/Frame/ImgEditor/ThumbNail/06_image_editor_frame03_thumbnail.png" (7618 bytes)... OK!
Wrt.file "/SystemFS/MediaSet/Frame/ImgEditor/ThumbNail/06_image_editor_frame04_thumbnail.png" (9194 bytes)... OK!
Wrt.file "/SystemFS/MediaSet/Frame/ImgEditor/ThumbNail/06_image_editor_frame05_thumbnail.png" (8397 bytes)... OK!
Wrt.file "/SystemFS/MediaSet/Frame/ImgEditor/ThumbNail/06_image_editor_frame06_thumbnail.png" (5328 bytes)... OK!
Wrt.file "/SystemFS/MediaSet/Frame/ImgEditor/ThumbNail/06_image_editor_frame07_thumbnail.png" (7191 bytes)... OK!
Wrt.file "/SystemFS/MediaSet/Frame/ImgEditor/ThumbNail/06_image_editor_frame08_thumbnail.png" (9505 bytes)... OK!
Wrt.file "/SystemFS/MediaSet/Frame/ImgEditor/ThumbNail/06_image_editor_frame09_thumbnail.png" (7794 bytes)... OK!
Wrt.file "/SystemFS/MediaSet/Frame/ImgEditor/ThumbNail/06_image_editor_frame10_thumbnail.png" (7338 bytes)... OK!
Wrt.file "/SystemFS/MediaSet/Frame/ImgEditor/ThumbNail/06_image_editor_frame11_thumbnail.png" (7647 bytes)... OK!
Wrt.file "/SystemFS/MediaSet/Frame/ImgEditor/ThumbNail/06_image_editor_frame12_thumbnail.png" (6207 bytes)... OK!
Wrt.file "/SystemFS/MediaSet/Frame/ImgEditor/ThumbNail/06_image_editor_frame13_thumbnail.png" (7082 bytes)... OK!
Wrt.file "/SystemFS/MediaSet/Frame/ImgEditor/ThumbNail/06_image_editor_frame14_thumbnail.png" (5768 bytes)... OK!
Wrt.file "/SystemFS/MediaSet/Frame/ImgEditor/ThumbNail/06_image_editor_frame15_thumbnail.png" (5432 bytes)... OK!
Wrt.file "/SystemFS/MediaSet/Frame/ImgEditor/ThumbNail/06_image_editor_frame16_thumbnail.png" (6258 bytes)... OK!
Wrt.file "/SystemFS/MediaSet/Frame/ImgEditor/ThumbNail/06_image_editor_frame17_thumbnail.png" (5637 bytes)... OK!
Wrt.file "/SystemFS/MediaSet/Frame/ImgEditor/ThumbNail/06_image_editor_frame18_thumbnail.png" (3899 bytes)... OK!
Wrt.file "/SystemFS/MediaSet/Frame/ImgEditor/ThumbNail/06_image_editor_frame19_thumbnail.png" (6663 bytes)... OK!
Wrt.file "/SystemFS/MediaSet/Frame/ImgEditor/ThumbNail/06_image_editor_frame20_thumbnail.png" (9955 bytes)... OK!
Wrt.file "/SystemFS/MediaSet/Frame/ImgEditor/06_image_editor_frame01.png" (59941 bytes)... OK!
Wrt.file "/SystemFS/MediaSet/Frame/ImgEditor/06_image_editor_frame02.png" (42934 bytes)... OK!
Wrt.file "/SystemFS/MediaSet/Frame/ImgEditor/06_image_editor_frame03.png" (37480 bytes)... OK!
Wrt.file "/SystemFS/MediaSet/Frame/ImgEditor/06_image_editor_frame04.png" (42597 bytes)... OK!
Wrt.file "/SystemFS/MediaSet/Frame/ImgEditor/06_image_editor_frame05.png" (47719 bytes)... OK!
Wrt.file "/SystemFS/MediaSet/Frame/ImgEditor/06_image_editor_frame06.png" (20738 bytes)... OK!
Wrt.file "/SystemFS/MediaSet/Frame/ImgEditor/06_image_editor_frame07.png" (40591 bytes)... OK!
Wrt.file "/SystemFS/MediaSet/Frame/ImgEditor/06_image_editor_frame08.png" (57470 bytes)... OK!
Wrt.file "/SystemFS/MediaSet/Frame/ImgEditor/06_image_editor_frame09.png" (55307 bytes)... OK!
Wrt.file "/SystemFS/MediaSet/Frame/ImgEditor/06_image_editor_frame10.png" (41388 bytes)... OK!
Wrt.file "/SystemFS/MediaSet/Frame/ImgEditor/06_image_editor_frame11.png" (48238 bytes)... OK!
Wrt.file "/SystemFS/MediaSet/Frame/ImgEditor/06_image_editor_frame12.png" (28224 bytes)... OK!
Wrt.file "/SystemFS/MediaSet/Frame/ImgEditor/06_image_editor_frame13.png" (37644 bytes)... OK!
Wrt.file "/SystemFS/MediaSet/Frame/ImgEditor/06_image_editor_frame14.png" (26994 bytes)... OK!
Wrt.file "/SystemFS/MediaSet/Frame/ImgEditor/06_image_editor_frame15.png" (28906 bytes)... OK!
Wrt.file "/SystemFS/MediaSet/Frame/ImgEditor/06_image_editor_frame16.png" (52882 bytes)... OK!
Wrt.file "/SystemFS/MediaSet/Frame/ImgEditor/06_image_editor_frame17.png" (36977 bytes)... OK!
Wrt.file "/SystemFS/MediaSet/Frame/ImgEditor/06_image_editor_frame18.png" (14105 bytes)... OK!
Wrt.file "/SystemFS/MediaSet/Frame/ImgEditor/06_image_editor_frame19.png" (25839 bytes)... OK!
Wrt.file "/SystemFS/MediaSet/Frame/ImgEditor/06_image_editor_frame20.png" (52277 bytes)... OK!
Wrt.file "/SystemFS/MediaSet/MovieMaker/blackframe.jpg" (1023 bytes)... OK!
Wrt.file "/SystemFS/MediaSet/MovieMaker/blackframe_qvga.jpg" (230454 bytes)... OK!
Wrt.file "/SystemFS/MediaSet/MovieMaker/videoeditor_transition_bars.png" (1059 bytes)... OK!
Wrt.file "/SystemFS/MediaSet/MovieMaker/videoeditor_transition_bars_qvga.png" (1865 bytes)... OK!
Wrt.file "/SystemFS/MediaSet/MovieMaker/videoeditor_transition_checkboard.png" (474 bytes)... OK!
Wrt.file "/SystemFS/MediaSet/MovieMaker/videoeditor_transition_checkboard_qvga.png" (1047 bytes)... OK!
Wrt.file "/SystemFS/MediaSet/MovieMaker/videoeditor_transition_circle.png" (10033 bytes)... OK!
Wrt.file "/SystemFS/MediaSet/MovieMaker/videoeditor_transition_circle_qvga.png" (26118 bytes)... OK!
Wrt.file "/SystemFS/MediaSet/MovieMaker/videoeditor_transition_disolve.png" (58288 bytes)... OK!
Wrt.file "/SystemFS/MediaSet/MovieMaker/videoeditor_transition_disolve_qvga.png" (119029 bytes)... OK!
Wrt.file "/SystemFS/MediaSet/MovieMaker/videoeditor_transition_downleft.png" (518 bytes)... OK!
Wrt.file "/SystemFS/MediaSet/MovieMaker/videoeditor_transition_downleft_qvga.png" (780 bytes)... OK!
Wrt.file "/SystemFS/MediaSet/MovieMaker/videoeditor_transition_downright.png" (466 bytes)... OK!
Wrt.file "/SystemFS/MediaSet/MovieMaker/videoeditor_transition_downright_qvga.png" (724 bytes)... OK!
Wrt.file "/SystemFS/MediaSet/MovieMaker/videoeditor_transition_fade.png" (344 bytes)... OK!
Wrt.file "/SystemFS/MediaSet/MovieMaker/videoeditor_transition_fade_qvga.png" (602 bytes)... OK!
Wrt.file "/SystemFS/MediaSet/MovieMaker/videoeditor_transition_heart.png" (9027 bytes)... OK!
Wrt.file "/SystemFS/MediaSet/MovieMaker/videoeditor_transition_heart_qvga.png" (23539 bytes)... OK!
Wrt.file "/SystemFS/MediaSet/MovieMaker/videoeditor_transition_rectangle.png" (6394 bytes)... OK!
Wrt.file "/SystemFS/MediaSet/MovieMaker/videoeditor_transition_rectangle_qvga.png" (14502
Old 09-27-2010, 13:03   #14 (permalink)
kashifshehzad's Avatar
Member: 221463
Thanks Meter: 179
thanks so much.................
The Following User Says Thank You to kashifshehzad For This Useful Post:
Old 09-30-2010, 07:29   #15 (permalink)
Member: 1309301
Thanks Meter: 31
.::::: Ust Pro II NEW UPDATE 30.0.20 :::::.
WILL RELEASE ON 30th of SEPTEMBER But unfortunately vahid has not mention the year
fast update year by year
The Following User Says Thank You to .::MICRO GSM::. For This Useful Post:
samsung b3313 user code removed successfully. telecomindia Z3X-Team Products 4 12-27-2013 10:42
MOTO V9 User Code Removed by Flashing Sydney_Unlocker Scout 2 10-30-2009 15:43
Samsung i600 user code remove??? Unlocker AL UST Pro II 3 01-16-2009 14:39
DB2020 flashing + user code removing + K320 flashing with Cruiser logs here Mainboard Main Sales Section 0 12-18-2006 15:25
1610 User code remove nester3 Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 4 12-16-2006 09:37
Page generated in 1.18069 seconds with 9 queries
